Missing HV Vent Tube??
Discussion in 'Gen 3 Prius Technical Discussion' started by Noahdoge, Jan 26, 2022.
Tags:
  1. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
    3B9BF6A0-B44A-4F94-A658-9EBA830CE2F7.jpeg I was replacing the bus bars on my 2012 Prius and I noticed something. There’s no vent tubes?? I’ve never messed with the HV battery and I’ve never had it serviced. I’m guessing it came like that from factory. How bad is this, I’ve owned the car since 2015 and put on 120k miles
  2. PriusCamper
    PriusCamper Senior Member
    13,201
    5,346
    Pacific Northwest, USA
    Yea... They phased out the vent tubes around about 2012 because the hybrid cooling fan does a good enough job at sucking fumes out of car in a battery failure when pack heats up. I suspect main reason for this is the known problem of NiMH fumes coming out of the vents reacting to rubber in the vent tubes and creating a yucky electrical smell inside the car and people complain about it.
    Noahdoge likes this.
  3. Noahdoge
    219
    148
    Mississippi
    Thanks I appreciate that! Makes perfect sense now.
  4. fuzzy1
    10,603
    The only vent tube on my 2012 is on the 12V battery. I'm not seeing any indications that NiMH battery venting has anywhere near the potential toxicity of lead-acid venting.
  5. Tombukt2
    Tombukt2 Senior Member
    13,594
    2,457
    Durham NC
    After 10 I think the vent tubes are gone. Good riddance not needed nimh fumes are nothing to worry with You have a fan back there running anytime the battery's doing anything worthwhile and that fan is sucking anything back in that area of the car and putting it straight out the back vent cigarette smoke battery fumes dog breath doesn't matter that fan is whipping that stuff right out of there pretty quick
  6. bisco
    52,536
    too bad all the people who gad to replace their smelly vent tubes didn't know this
