Missing Rear Windshield Wiper Assembly
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Clintzero, Jan 27, 2021.
  1. Clintzero
    Clintzero New Member
    Hawthorne, CA
    2013 Prius v wagon
    Hi all,
    I recently bought a 2013 Prius V to replace my trusty 2009 Prius (whose catalytic converter was tragically stolen). In all the excitement of getting a new car and looking over the important parts, I overlooked a relatively minor missing part.
    The car is a salvage title with a replaced rear hatch. That doesn't bother me, especially at the low price I paid, but when the hatch was replaced, they neglected to install a new rear wiper assembly. Instead there's just a plug in the hole where the wiper should be installed. I'm not afraid to disassemble the hatch and put one in myself, but I am worried that the fluid line that runs to the wiper fluid reservoir is going to be missing. Does anyone have any experience messing with the rear wiper assembly, or possibly have photos of what a correctly assembled one looks like so I can at least figure out what all is missing and needs replaced?
    I just took a look and at a minimum I'm definitely missing the motor. There's an electrical plug just dangling there unattached. When I removed the panel at the top of the hatch I found what looked like the termination of the fluid line, so at least it's nearby, assuming I correctly identified it.
    View of the exterior: IMG-0956.JPG
    View of the interior behind the plug: IMG-0955.JPG
    View of the fluid line I found behind the top panel of the hatch: IMG-0954.JPG
  2. Clintzero
    Hawthorne, CA
    2013 Prius v wagon
    Update: It turns out I'm dumb and that fluid line leads directly into the rear of the sprayer. As far as I can tell the whole rear wiper fluid system is still connected and present, it just won't spray for some reason. When I actuate it with the switch I can hear the pump motor run, but no fluid comes out (and yes, I checked the wiper fluid level and there's plenty). Maybe there's a clog in the line? The front wiper fluid sprays normally.
    As for the actual wiper assembly, It seems I just need everything listed on this diagram and I'll be good to go: a1_852626 (1).jpg
    Unless anybody is aware of something I'm not accounting for?
    52,861
    try cleaning the nozzle with a pin or thin wire
  4. Clintzero
    Hawthorne, CA
    2013 Prius v wagon
    I soaked the spray nozzle with some Simple Green and stuck a safety pin in there, but to no avail.
  5. bisco
    52,861
    i think the tube runs through the head liner, tough location. try disconnecting under the hood to make sure it is working there, then at the back, before digging into the car.
  6. Mendel Leisk
    42,352
    For what it’s worth, that rear wiper is not very useful or effective. Maybe for snow. Or clean up on heavily salted roads. And the sweep area is token.
  7. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Maybe not in Cali, but out here, the rear washer line would probably be frozen, after the alcohol in solution evaporates out...
  8. Clintzero
    Hawthorne, CA
    2013 Prius v wagon
    I drive in all kinds of conditions all over the place, so it's worth fixing for me.
    I'm considering pulling the fluid hose off at the rear hatch and blowing my air compressor through it. Simple as the concept is, I'd still have to remove the spoiler to access the hose with more than two fingers because Toyota engineers are sadistic baby-handed monsters. Anybody know if blowing out the line in that direction might have any unintended side effects? Like damaging the pump? I'd disconnect from the front and blow from there, but I'd have to remove the passenger side quarter panel to reach the base of the fluid reservoir where the hoses connect to the pumps. That seems like an excessive amount of work.
  9. Clintzero
    Hawthorne, CA
    2013 Prius v wagon
    Update: The rear washer fluid sprayer just started working out of nowhere. It must have heard I was planning to hook it up to the air compressor and got scared.
    Joele3 and Air_Boss like this.
  10. Air_Boss
    4,259
    1,197
    New Yawk
    It heard you might use a bigger hammer.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I bet the line was just empty, and needed to be primed/filled.
    The air compressor idea is a moot point now, but for archival purposes I'll offer this: I'd advise against it. There's almost certainly a check valve inline so that the line keeps it's prime and you don't have to run the pump for 30 seconds every time you want to spray at the rear of the car. The fittings along the route (elbows, t's, etc.) are likely just barbed with compression being the only thing holding the line on. If you build up pressure with compressed air, you're likely to blow the line off one or more of those connections. Which means you'll be tearing out the headliner so you can re-connect that line.
    I learned this when clearing sunroof drain lines on my 4Runner. They tend to get clogged by environmental debrit, then the sunroof drain pan overflows. It's an easy 5 min affair to clean the clogs with a stiff piece of wire, but people get too heavy handed and try to clear them with compressed air. They end up with water draining inside the A-pillar and all over the dash and floor. A real mess, and a real pain to correct.
    Air_Boss likes this.
  12. Mendel Leisk
    42,352
    Maybe try suction? If needed.
  13. Boomer 2298
    Boomer 2298 Junior Member
    36
    Edinboro, PA USA
    how cold is it where you live?
  14. Clintzero
    Hawthorne, CA
    2013 Prius v wagon
    I think you're probably right on all accounts. Glad I hit the magic number of minutes running the spray pump before trying anything drastic. It takes a surprisingly long time for the fluid to fill that line.
    tvpierce likes this.
