missing sd card on prius 2017
Discussion in 'Gen 4 Prius Audio and Electronics' started by h-edris, Apr 27, 2017.
  1. tucatz
    tucatz Active Member
    501
    417
    Manzanita, Oregon
    Four Touring
    When I purchased my 2016 in November the SD card was missing. I noticed this durIng the delivery inspection checklist because the navigation did not work. My salesperson said "no problem", opened the door to the nearest Prius on the lot, removed the SD card from that car and put it in my car. I almost started to protest. But it works, I've had no problems whatsoever.
    Side note: it is absolutely amazing that all of this information fits on a scrap of plastic and silicon smaller than my thumbnail!
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I have a really old full height 80MB HD the size of a shoebox. I love to put a 16GB microSD card on top of it for comparison. 200x the storage in /200+ the size.
    tucatz and RCO like this.
  3. pjm877
    pjm877 Member
    340
    84
    austin, tx
    that card is a 16gb card... I have a 128GB same size in my dash Cam... I remember the 5Mb size of a shoe box hard drive that was in a IBM PCXT... Cost a bargain price of $5,000 usd with PC DOS .. you could warm bread on that monster
  4. DanMan32
    3,799
    27
    Tampa Bay, FL
    I had a Seagate 20MB in my XT clone. The 80MB shoebox was the same Seagate technology but with 4x the platters. Came off of a server. Those things were prone to head drift due to thermal environment or how it was mounted.
  5. chenderson2
    chenderson2 Member
    94
    57
    Houston
    Can I ask where in the car that is located? The reason I ask is that today my 2017 Prius Prime had a message that it could not find the maps SD card and that I should check it. I turned off the car and restarted it and everything is now working, but I could not locate the SD compartment and the owner's manual does not mention it at all.
  6. Prodigyplace
    12,712
    11,848
    Central Virginia
    Their profile says "bay area" so, I assume California. Why? do you think you got the car that was robbed? :eek:
  7. Elektroingenieur
    2,515
    3,288
    Three Touring
    For the Prius Prime Advanced, with the 11-inch display, the microSD card slot is on the bottom of the head unit, as shown on page 274 of the Navigation System Owner’s Manual (PDF), which is separate from the main Owner’s Manual for the car.
    For Prius and Prius Prime cars that have the 7-inch display, the microSD card slot is on the front of the head unit, as shown on page 261 of the corresponding version of the Navigation System Owner’s Manual (PDF).
    Prodigyplace likes this.
  8. chenderson2
    chenderson2 Member
    94
    57
    Houston
    Thanks for the information. I didn't actually search through the manual, but only looked at the contents and index and SD card is not listed either place.
    Elektroingenieur likes this.
  9. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Anyone tried this? Does it work? If anyone can help me to shared the data of the SD card with me, I really need it, I have 2017 prius. And I'm searching for the SD card since I got my prius with no luck, can you please share the SD card content with me?
    Thank you
  10. Duddy03
    Duddy03 Junior Member
    22
    Crossville, TN
    2018 Prius Prime
    I have a 2018 Prime. I bought an updated micro SD card (86271-0E073). The first card did not work but was replaced by the vender. It contains over 37,000 files but took several attempts to get it inserted properly. However, the nav does not work properly. The map appears but I am unable to select a destination. I have been working this problem since last November. Any ideas? A major nav system updated was requested recently by the head unit, but it neither helped or hindered the situation. No "Installation" process was started when the card was inserted. Could the card be installed improperly, but the system fails to detect the problem? Any troubleshooting suggestions would be appreciated.
  11. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Can you please if possible share with me the files so I can check whether I can copy it to SD card
  12. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    I have 2017 prius, imported from Michigan, can you share the files with me so I can try it
