Mixing battery cells
Discussion in 'Gen 2 Prius Main Forum' started by morre76, Sep 27, 2025.
Tags:
  1. morre76
    morre76 Junior Member
    25
    IL
    I’ve read in many posts that it’s not possible to mix Gen 2 and Gen 3 modules unless you replace the entire pack.
    However, from my own experience, it can actually be done. On my 2008 model, I replaced 4 modules with ones manufactured in 2014 (at the time, I wasn’t aware of any supposed limitations).
    Now, another module has failed, and the only replacements I can find are 2014 Lexus module.
    Will they work? Do they also contain 6 internal cells?
    #1 morre76, Sep 27, 2025
  2. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    You're mixing up modules and cells. A module contains six cells. A Prius has 28 modules all up.
    Check the voltage of the Lexus modules, and if they look visually the same as your Gen 2/Gen 3 modules, they should be okay..
  3. morre76
    25
    IL
    Thanks, you are right.
    I edited it.
