mixing diff grade oils
Discussion in 'Gen 2 Prius Technical Discussion' started by AllenZ, Dec 5, 2011.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    I generally use 5W-30 synthetic oil for my 2004 Prius with 150K miles, in Chicago area. It seems like consumes 1 quart oil/4000 miles
    Last winter I used 0W-20 synthetic and found that it consumes at least one quart oil in 2000 miles.
    I wonder if I mix 0W-20 with 5W-30 half/half, what effective grade it will turn into?
    Based on my oil consumption, mileage, and 1500/week rate, what's your recommendation for early Jan. oil change?
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Why not just use a good 0W30 synthetic?
  3. AllenZ
    640
    63
    Chicago
    'cause I already have those two... Need to put them to use.
    BTW, how long you think the oil can store at home before it "expires"? I heard tires better used in less than 6 years.
  4. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok I gotcha. Chicago has pretty cold winters right. Roughly how low are you expecting your starting temperatures to get down to, 5F? 10F?
    At 1500 miles per week I'd say the oil is getting a pretty good workout. Personally I'd prefer a 30 weight oil in there for this type of duty, but I understand you've got the cold start issue. Maybe try 2.5 qts of 5W30 and 1 qrt of 0W20 which would probably just give you a thin 5W30.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Good questions. Ans = 2.5W-25? do not know. We could do viscosity blend calcs, but I assume average is close enough for goverment work. I am going with 0W-30 Mobil-1 Advanced Fuel Economy but not sure they still make that grade, its older, as I am as bad as you on long storage. Hopefully shelf life is good.
    Your consumption rate sounds high. What brand are you using?
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    One quart in 4000 miles is not really too bad for an engine with 150,000 miles that's doing 1500 per week. I mention the weekly mileage because many cars use significantly more oil at freeway speeds compared with lower speed driving.
    Sure the situation's not ideal, but it's not all that bad. :)
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Here's another option. If you're not experiencing any cold start issues with the 5W30 then just keep using that as your main fill, and use the 0W20 for top-offs. By the time you need to top-off there's probably a little bit of oxidization thickening started, so the 0W20 should maintain a good viscosity.
    I'm doing a similar thing, but in reverse, here at the moment. I've got some 10W40 that I need to use up so I'm using it for top-off in summer. However I only need about 1/2 pint of top-off per 4000 miles, so it's going to take a while to use it up. :)
  8. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    use 0-20 all year long since the cars where new. I have never added a ltr. between changes. Normally go 14,000 thousand kilometers before oil and filter change. Filter on my HCH is every other change but every change on the Prius. I would not mix all-though I can't really see it hurting anything! Hal
  9. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Oil does have a shelf life, but it's longer than most people would keep it. It keeps even better in the plastic containers than it did in the old metal cans. I wouldn't use it after 10 years, but I have no facts to back that opinion up with.
    I had a bunch of Mobil 1 10W30 I wanted to use up so I mixed it one litre per change with Mobil 1 5W30 in the Prius. The lighter 5W20 and 0W20 will escape a little faster and be burned. I don't notice the oil level dropping over the standard change interval, probably because fuel is replacing the lost oil, or it just isn't burning enough to notice. Currently I'm using 5W30 for all 3 1/2 litres. I suspect it's colder here than in Chicago, on average.
    If you do mix it I wouldn't worry too much about the two being incompatible. These days most oils are compatible with each other. Early synthetics weren't.
  10. AllenZ
    640
    63
    Chicago
    Help me understand this: Why high mileage engines burn more oil? Piston Ring getting loose (so gap increase) is the only thing I can think of, if oil does not leak through seals.
    Guess freeway driving increase oil temp, make it thinner and so burns more. I actually drive mostly on local, but I pick up briskly, get to 40mph and turn to stealth mood. That might also contribute to the oil burning?
  11. AllenZ
    640
    63
    Chicago
    I always use the Super Tech, if you call it a "brand" :) Yes it's the cheapest Full Synthetic I can find on market. The 5 QT in Walmart is now $22+, used to be $17 just a year ago.
    Maybe it is a good idea to switch a brand and compare result. Many people here stick with Mobile One, but I don't know why.
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yes, all the clearances increase as the engine ages, piston rings and valve guides are the main routes that oil gets into the combustion chamber and lost (burnt). Burning a small amount of oil doesn't harm the engine. It might even do a bit of good at self limiting the wear by increasing the upper cylinder lubrication.
    That's what I usually put it down to. I used to have an old Audi that liked to drink oil. Around town it was pretty mild but out on the freeway I had to check the oil level just about every time I got petrol.
    Ok the freeway was just an assumption due to the amount of miles you travel per week. I was thinking a long commute but now I see your job must involve driving. So I guess you're driving most of the day and your oil stays pretty warm?
  13. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I don't think Mobil One would change your oil consumption very much. It might be better if you're doing long drain intervals, but I think ST is ok.
    I'm starting to think the best plan is just to stick with the 5W30, 1 quart in 4000 miles is ok, and use up the 0W20 for topping off.
  14. Hal W
    Hal W New Member
    872
    53
    Some engines use that much oil from the get go! Valve guides some times let oil by as well as the rings. How many miles on your 04 Allen? Hal
  15. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...well I was just thinking that Mobil-1 has High Mileage formula in 5W-30 and supposedly helps to reduce oil consumption. I'd be a little afraid to blend different brands, but I think this might be part of a blend with 0W-20.
  16. AllenZ
    640
    63
    Chicago
    It's 151K already.
    I mostly drive local, just for commute to work these days. Plus some weekends driving, total probably 1500 miles/month.
    On my last job, I commute 130m/d (90% freeway). That's the reason I finally bought Prius. Otherwise, I had to put 5.5 gal/day into my V8 4.0 Lexus LS400. I saved about $3000 on gas in 40K miles. Drive another 70K my Prius is literary free, less maintenance cost.
    I hope the oil consumption situation will not getting much worse in future. Otherwise I might as well do something about it now.
  17. AllenZ
    640
    63
    Chicago
    I am not sure what's the "High Mileage Oil" label mean really. Does it simply mean thicker oil like 10W-40 or something? I did not use the high mileage oil because those are not synthetic.
  18. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok that clears it up a bit. In your original post you said:
  19. Hal W
    Hal W New Member
    872
    53
    Sometimes a change of brands can do the trick. I would stay with synthetic if that is what you are using. Toyota has their own synthetic now and that is what I use. It is 6.95 a ltr. here in Canada so would probably be less in the US. Check it out Allen. 4000 miles to burn a quart of oil is not terrible! Hal
  20. AllenZ
    640
    63
    Chicago
    I wonder who OEM for them...
