Moans & groans: new struts & shocks
Discussion in 'Prius v Technical Discussion' started by PixelKing, Apr 27, 2024.
Tags:
  1. PixelKing
    PixelKing Junior Member
    Dunedin, FL
    My 2012 Prius V with 130k mi. sounds like an old man. I had the shocks replaced on the rear and struts on the front. It still moans & groans on speed bumps and turning sometimes.
    Where else do I look?
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Rubber bushings may be shot, or ‘perished’, as the Brits say.
  3. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Yes, post 2.
    Visually look at every rubber bushing you can see related to a suspension movement.
    Ideally one would remove said bushings and lubricate (or replace if damaged).
    An "easy" way is to purchase a can of aerosol silicon spray and spray every rubber bushing you can see.
    Lastly, from your description, I would be inclined to again write the moans and groans are related to suspension movement.
    Outside this opinion, there are hood, trunk, door weatherstrips, exhaust and body mount rubber too.
    I would not think these sounds are related to any undercarriage panels or engine components.
    Of course, if the noises were not there before your shock change, well, the shock rubber mounts would be suspect.
    Good hunting :)
  4. BiomedO1
    BiomedO1 Senior Member
    4,589
    2,409
    Left Coast
    As an old man; I take offense to that statement!!!! Just kidding, couldn't help myself - enough moaning & groaning.....:D:LOL::ROFLMAO:
    When they did your front struts, did they use a "ready strut" or a bare strut, where they moved everything over; including your old rubber goods? Kenny has the right idea - spray all suspension rubber goods with silicone lube. This is only a temporary fix. You'll still need to replace the offending rubber part for a permanent fix.
