Mobil 1 0w-16 on store shelves now, 1st dibs anyone?
Discussion in 'Gen 3 Prius Main Forum' started by Grit, May 9, 2019.
  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Earlier reply I said this oil was next, well that wasn’t the truth. I’ll stay redline no thicker than 20 weight when at normal operating temps.
    Just imagine any other car, then use a lighter oil, some people would think you’re crazy to do that. I can’t see this weight providing adequate lubrication in the long run, some even moved up to 30 or even 40.
    edthefox5, Bay Stater and RMB like this.
  2. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
    Understand you can’t compare the new 0w16 weight to 0w20 as they aren’t on the same scale.
    Different chemistry with new properties
    Case of apples and oranges
    Honda has back dated a lot of old cars to use this or even so called 0w8
    Bay Stater and Grit like this.
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Just pour water into your engine, it will be fine! (n);)
    Grit likes this.
  4. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Joele3, Merkey and orenji like this.
  5. a_gray_prius
    2,927
    783
    IL
    Mobil has been running a $12 mail-in rebate for 5-qt quantities of Mobil 1 for the past 5 or so years. With the rebate, final cost of a 5qt jug at walmart's $26 means it's $14.
    #1: I don't think Aunt Jemima is even maple syrup, I'm pretty sure it's a blend of mostly corn syrup.
    #2: I suppose when the oil runs out, you can count on Canada's strategic maple syrup reserve (which saw a high-profile theft in recent years)
    MexicanChip, Mendel Leisk and Grit like this.
  6. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Not good, they didn't even put waffles or pancakes in the engine (n)
    Bay Stater and Raytheeagle like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    Don’t they bring the griddle out in the next one:ROFLMAO::p:ROFLMAO::p.
    Grit and Bay Stater like this.
  8. JC91006
    16,769
    8,567
    Just looked at the new RAV4 hybrid, takes this thin oil. No wonder they can squeeze out 40mpg
    Grit, orenji, Bay Stater and 3 others like this.
  9. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Yeah, for how long?! Oil burner at 100K. :eek:
    Grit, orenji and StarCaller like this.
  10. Bay Stater
    534
    771
    Central Mass
    Verified today, Walmart in Mass has 0W-16
    Grit likes this.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Unless http://www.mobiloil.com says to use it in one of my vehicles, nope, not going to try it. Falls out of their application and hence warranty.
    moto g(7) power ?
  12. Mendel Leisk
    41,466
    I would wait till Toyota ok's it. And then a while longer, let others be the pioneers.
  13. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I’ll wait for Orenji’s blessing also, he rolls with 0w-40 only, which is the true synthetic.
    edthefox5 and Rmay635703 like this.
  14. Mendel Leisk
    41,466
    I'm hearing the siren call of 5W30. :whistle:
  15. hill
    8,808
    someone above is think 0w 16 is not specifically what manufacturer want to see you use. Isn't it the same with 0w-40?
  16. orenji
    5,887
    3,488
    0W-40 is approved as well as 50 weight just not reflected in the USA service manual - you know CAFE standards.
    jzchen likes this.
  17. Mendel Leisk
    41,466
  18. Stangar
    Stangar Active Member
    174
    174
    Palmdale, CA
    I enjoy these threads but always wonder what engineering backgrounds, degrees or experiences would qualify YOU to select/use a different weight oil than what the manufacturers have determined as the best weight for fuel mileage and reliable long engine life.
    Attila Fekete and Jesse Bechtold like this.
  19. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I took Spanish as foreign language option in high school and college. If you search for a Mexican Owners Manual you will find thicker oil options, not thinner as far as I'm aware, but thicker...
    moto g(7) power ?
    Jesse Bechtold likes this.
  20. Jesse Bechtold
    Jesse Bechtold New Member
    22
    Tucson, AZ
    Yes! Living in southern Arizona this would be good to maybe have slightly my thicker oil in the summer, but I normally only do an oil change once a year. Once every 7,000 miles.
    iPhone ?
