Mobil1 0W20 Oil analysis reports
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TheForce, Jul 27, 2007.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The fuel residual is up, but the TBN is still quite good. You can try increasing the interval in 2,000-3,000 increments until you start seeing a dip in TBN and/or an increase in wear metals
    Yes
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Must be because the numbers are pretty close since the first oil change.
    [edit] did not see jayman's post about the additive.
  3. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    34
    Seattle
    It appears you are doing a fine job getting your minerals, but need to work on getting
    more vitamin C and D - :)
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Just got my analysis today. This is the Third oil change using my Hymotion battery. I ran for 10k miles this time. Estimated time on engine ~3k miles. The rest was all electric. :D
    MI/HR on Oil 9,998
    MI/HR on Unit 50,042
    Sample Date 11/02/06
    ALUMINUM 12
    CHROMIUM 0
    IRON 10
    COPPER 4
    LEAD 5
    TIN 0
    MOLYBDENUM 79
    NICKEL 0
    MANGANESE 1
    SILVER 0
    TITANIUM 0
    POTASSIUM 2
    BORON 54
    SILICON 19
    SODIUM 8
    CALCIUM 1566
    MAGNESIUM 10
    PHOSPHORUS 544
    ZINC 541
    BARIUM 0
    SUS Viscosity @ 210°F 44.0
    cSt Viscosity @ 100°C 5.7
    Flashpoint in °F 210
    Fuel % 8.8
    Antifreeze % 0
    Water % TR
    Insolubles % 0.5
    TBN 4.0
    I'm guessing that my high fuel content is because I really never let the engine get hot enough to burn out the gas. I dont think I have a fuel system problem. I'll have to figure out a way to get the engine hot once a week or so to get that fuel out of the oil. I'm going back to 5k miles this next oil change.
    To those that are running extended EV mode with their plug in you may want to make sure to get the engine hot for a while so you have less fuel in the oil.
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Pretty sharp of the oil analysis guys to consider inadequate engine heat as the reason for dilution.
  6. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Well I did mention in my first oil analysis when I converted my car that I converted it to a PHEV. Also for the last three reports I listed an estimated engine run time on the total miles on oil since I do a lot of EV driving.
  7. Bill60546
    Bill60546 Member
    388
    Chicago
    I own a 04 with 70K miles. Does anyone see any issues with changing to synthetic oil at this time? Brand?
    Many thanks!
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Some owners saw increased oil consumption after switching to synthetic at high mileage. You have to weigh that risk against the potential benefit (if any). If I were you I won't bother. Just my 2 cents.
  9. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    Not many choices out there for 0w20. Mobil 1, Valvoline, Castrol, Honda, Toyota, AMSOil, Redline. None are cheap, but you ought to have a longer oil change interval as long as you don't have a consumption problem (not common).
  10. CBarr31
    CBarr31 Active Member
    436
    225
    Charlotte, NC
    Bill,
    I asked that same question awhile back in the thread listed below and the consensus was the benefits would be negligible at best and the problems could be considerable.
    I hope this helps.
    http://priuschat.com/forums/gen-ii-...igh-mileage-switch-synthetic-any-benefit.html
    Happy driving,
    Chris
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    New oil analysis today. I tried running the engine more this time. Fuel dilution is down but still high. I'm going for another 5k miles this time around.
    MI/HR on Oil 5,040
    MI/HR on Unit 55,082
    Sample Date 11/10/29
    ALUMINUM 5
    CHROMIUM 0
    IRON 6
    COPPER 2
    LEAD 0
    TIN 1
    MOLYBDENUM 97
    NICKEL 0
    MANGANESE 0
    SILVER 0
    TITANIUM 0
    POTASSIUM 0
    BORON 60
    SILICON 20
    SODIUM 6
    CALCIUM 2349
    MAGNESIUM 13
    PHOSPHORUS 700
    ZINC 782
    BARIUM 0
    SUS Viscosity @ 210°F 51.1
    cSt Viscosity @ 100°C 7.6
    Flashpoint in °F 300
    Fuel % 4.3
    Antifreeze % 0
    Water % 0.0
    Insolubles % 0.3
    TBN 5.6
  12. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    I am due for an oil change. Do we have a "sticky" on recommended synthetic oil types for Gen-II? I am still using 5W-30 Mobil-1. I see the 0W-20 is longer lasting oil (now used in new Prii). But I have use up my 5W-30 supply anyway. 0W-20 has winter MPG benefit (+? MPG) but in hot summer may be concern? I have 97K miles on an 2006.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    0W-20 isn't a longer lasting oil, Toyota give the change interval distances on the GenIII to encourage you to use 0W-20. They have to because the used 0W-20 for their gumnt fuel economy tests.
    How long an oil lasts is much more a function of the oil's quality than it's viscosity.
    Odds are there is no problem using 0W-20 in a Gen II during the summer, but you are wise to be suspicious until you have solid evidence that it's OK.
  14. wjtracy
    11,368
    3,608
    Northern VA (NoVA)
    OK XS, I am going with 0w-30 advanced fuel economy Mobil-1. Pretty sure that is suggested as valid replacement for Prius Gen II.
    That should be good compromise.
