mobile-1 15k good to 4k milles only
Discussion in 'Gen 2 Prius Technical Discussion' started by epoch_time, Mar 26, 2012.
  1. epoch_time
    epoch_time Active Member
    240
    112
    las vegas
    I've been using mobile-1 full synthetic 5-30W extended preformance oil in my gen II prius since it had 2300 miles on it... now is has 41,500 miles on it.
    I notice valve/lifter/cam noise developing at 4 to 5000 miles on mobile synthetic extended oil, which tells me the oil is breaking down.
    When I change oil the valve/lifter/cam noise goes away for another 4 to 5k miles...The mobile syn oil then breaks down and valve/cam/lifter noise creaps back...
    I will probably stick with mobile-1 extended but will not let it wear beyond 5000 miles....
    A search on the internet about mobile-1 synthetic says it is no longer is a group IV oil (true synthetic) but a group III lower cost to produce fake synthetic...
    Here is an interesting link with oil analisys comparing many mobile-1 types against plain old pensoil dino oil.... shows dino oil to have less iron and lead wear...
    http://forums.nasioc.com/forums/showthread.php?t=1265711
    Dont let current mobile-1 stay in engine longer than 5000 miles and most of all dont go to dino oil either..
    But keep a keen ear out for engine noise from inadaquite lubrication...
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    If you don't think Mobil 1 is working too well for you then why keep on using it when there are literally dozens of alternatives? Why not not try something like "Castrol Edge" or "Penzoil Platinum" or even "Valvoline Synpower", on your next change and let us know how it holds up after 5000 miles.
    douglasjre likes this.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Somewhat similar thread under Gen3 Maintenance under Toyota vs Mobil 1.
    One poster says a very expensive Amsoil he finds solves that problem
    I note the reference cited is 2007 and seems less than authoritative
    Also I tend to doubt breakdown but hear a lot a about fuel getting into Prius lube system
    That could explain a loss of visc
  4. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    I tend to agree with this last statement as I was appalled at the sniff of my first Prius dipstick. I don't know if this is due to the Atkinson cycle or what but it definitely smells like gas to me.
  5. epoch_time
    240
    112
    las vegas
    I can confirm that fuel is getting into the gen II oil pan..
    I've been siphoning 2.5 ounces of oil every 2500 miles to keep oil level at the prefeered mark on dipstick (3/16 inch below full mark)..
    Prius always runs great averaging 54 mpg...
    The fuel in oil contributing to mobile-1 syn breakdown..
  6. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Ok now the real reasons come out. :)
    Look it's technically not even "breakdown", it's just being diluted. Breakdown is some kind of permanent physical or chemical degradation of the oil due to time temperature and mechanical stress/shearing. Fuel dilution on the other hand can be fully reversed by just getting the oil up to it's correct operating temperature! You must drive a lot of very short trips and rarely (if ever) get that poor son of a bitch up to a decent operating temperature.
    Now 2.5 ounces over 2500 miles is 5% fuel dilution over 5000 miles (and that's at a minimum, because any oil loss/burning will correspond to even more fuel added). That's a lot of fuel dilution.
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ...interesting technique re: siphoning off. I've thought about that.
    As far as the fuel entrainment in the oil, from what I know it is just naturally how the Gen-II Prius config works.
    Actually I already bought Mobil-1 Extended Performance for my next refill. I am planning to refill 3-qts, which usually gives me enough. After 4k I will consider adding 1/2-qt of heavier lube possibly Mobil-1 High Mileage 5W-30 to give it some thickening to balance off the fuel dilution.
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Do note that the Prius doesn't have "hydraulic valve lifters", so the original posters thoughts are bogus. It uses fixed disks to set the clearances.
    The "lifter noise" could be real or imagined. ;)
  9. ZitterZap
    ZitterZap Member
    76
    28
    Houston, TX
    Same things happened to me this time. I have been using Mobil 1 synthetic (extended) and also have been changing oil every 10k miles and filter every 5k miles. But this time around 5k I felt the throttle response was a bit weird. I change my oil and filter and its back to normal.
    I think the quality of Mobil 1 has degraded. I will be changing oil every 5k now.
  10. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I guess if you've got 5% fuel dilution that could be enough to thin the oil and reduce it's effectiveness to the point where the engine is a little noisier. I generally find that a stouter oil gives more cushioning and slightly less noise.
  11. epoch_time
    240
    112
    las vegas
    Very interesting developement here....
    Yesterday I drove on the freeway for about 35 miles after which the cam/lifter/valve noise quited down and the prius drove just like it had an oil change!
    My orignal post was about mobile syn oil break down..At 4k miles.....
    After longer drive with engine operating continously (30 minute freeway drive) oil now seems like new!! engine even has more power jusl like getting an oill change and nice and quiet engine again!!!
    All my previous driving was stop and go city driving under 40 mph with one hour duration (ready mode) with each startup. Half that hour the engine is actually off. 50/50 engine on/off.. all though the engine seems fully warmed up 166 degrees (scan gauge temp but winter months) the oil may have not been fully warmed up...lots of cold winter air on oil pan?
    I think the diluted oil under my city driving has found a low resistance path to the prius oil pump. circulating only the diluted contaminated oil through the prius engine. Not mixing with the good oil until I had an extended engine run conditon on a 30 mile freeway drive which hadn't happened before..
    I have been siphoning out accumulated oil out of the dip stick port as my prius seems to breed oil (fuel contaminated oil) keeping oil level at the sweet spot on diip stick...
    If my oil level is still on the increase after what I have learneed.. I hope now to be siphoning off only the fuel contaminated oil that should be floating provide the engine sits (off) long enough????
    My research shows fuel to be lighter than gasoline;
    unleaded 6.216 pounds per gallon.
    Premium 6.350 pounds per gallon.
    Oil weighs 6.84 pounds per gallon
    The weighs of gasoline was confirmed from two internet sites..
    The weight of oil was only found on one web site....
    So additional research may be needed.....
  12. sub3marathonman
    sub3marathonman Active Member
    557
    75
    Why not do a Used Oil Analysis with Blackstone Labs ( Blackstone Labs )?
    It could provide a real help to see exactly what has been happening, as opposed to wondering. I think you will want to spend the little bit more and have the TBN tested too, as that number is important to determine if the oil is OK or needs to be changed.
    I know I would be interested to hear the results of it, since all the driving has been city stop and go.
  13. epoch_time
    240
    112
    las vegas
    I've got about 100 freeway miles now on 4k mobile-1
    and the prius has gained even more preformance and is quiet and running just like its had an oil change.
    although the oil level is about 1/16 inch from full I will be siphoning off the excess 2/16 inch (aproximately 2 oz) which will be the first siphone with this current oil fill...
    previous fills i've had to siphone two different times in 6500 miles (5oz total siphone) and oil was probably at near full mark when changed at 6800 miles.
    Durring the current oil fill I've tried to keep air/heater blower on low (excluding warmup) durring daytime driving which keeps the dc/dc converter at 13.78 volts as opposeed to 13.21 daytime volts without blower on..(nightime voltage is always 13.75 volts).....
    This is not a defect of the prius dc/dc converter thats the way all genII prius charging systems work.....Battery fully charged no load on system battery is trickle charged at 13.2 volts....any load on 13volt system dc/dc regulator switches to 13.8 double trickle mode....
    I had hoped the higher voltage would provide more complete combustion of fuel in the engine....and the accumulation of excess oil seems half as much from the previous oil fill......I cannot say absolutely that
    the additional ignition coil voltage is the reason but higher voltage should help....(theoretecly)..
    Note gen III voltage cycles between 14.2 to 14.9 volts for reasons beyond be. But perhaps gen III has less fuel contamination???
    Oh now for the real reason for this post.....
    If anyone decides to try siphoning oil from prius engine...be advised this can be just an messy as your worst oil change.... I've been using aquarium air hose purchased at walmart and discarding after use...
    The slightest bit of dirt injected into your prius engine will surely negate any positive efforts.....and pulling that last inch of tubing from dipstick port always flicks oil somewhere.....My fear hear is that comtaminated oil is probably high in acid content and may eat through cooling hoses, fan belt, aircondition hoses..and the likes......
    Walmart also sells a turkey baster that looks like a giant hypodermic needle that I use it conjuction with aquarium air hose for oil siphoning... not a perfect combination but somewhat okl.....the seal from hypo to hose could be tighter (wish).
    If your are insistant on doing any of this nonsense try and keep the oil flowing in one direction by crimping off hose to eliminate any back wash that could further contaminate engine oil..... although aquarium air hose is transparent and clean looking who knows what microscopic junk is inside the hose......
    And when removing that last inch of hose from diphole keep hand and absorbint paper towell right against dipstick tube to prevent oil flicking somewhere...
    That all I have to say about that (siphoning)..
    But Mobil-1 synthetic oil is the best Imho....And I will be using it for a long long time....
  14. epoch_time
    240
    112
    las vegas
    Here is a follow up on my fuel contaminated mobil-1 5-30w extended oil at 4.2kmiles..
    I siphoned off 8 oz of mobil-1 from the top layer of pan oil (fuel is supposed to float)..this dropped the oil level from the full mark to about 1/2 inch below full mark...
    I then drove the prius (8oz low oil level) noteing a much quieter engine.
    This 8oz removal was after prius sat for 7 hours..
    and the removed oil did smell of gas but not bad but
    noticeable...
    The next day after prius sat for 8 hours I siphoned off 16 more oz of top surface mobil-1 oil... this second batch of siphoned oil smelled identical to the first siphoned batch...
    I didn't really think this wouid work as well as it did with the prius setting for only 7-8 hours.. an idle prius for a day or two would nodought allow more fuel to float to top surface..for better removal...
    After siphoning the second batch I added approx 22 oz of new mobil 5-30 extended oil from a single 32 oz bottle purchased at walmart for 7.80 and was shocked at the color of this new oil almost clear like water....
    I stopped momentarly while pouring into funnel...(did someone sell me water instead of oil)).... I have never seen mobil-1 look clear like this...I previously always purchased 5 quart jugs at walmart where the mobil oil looks yellow...... could the single bottles be different quality justifing the higher price ???????
    Anyway drove the car on freeway for about 75 miles...
    Prius drives wonderfull .... engine nice and quiet.....
    4.2 kmile mobil-1 oil seems like new and only a slight hint of gas smell on dip stick.....I'm hopeing new oil that I added will help float remaining fuel to top of pan after an extended inactive resting prius...I will siphone a little more and see if gas smell goes away completely (hopeing)..
    OTHER DRIVING HABBITS OF MINE THAT PROBABLY CONTRIBUTE TO FUEL IN OIL ... i SET AT PARK WITH PRIUS IN READY MODE ABOUT 1/2 HOUR PER DAY AND ALL CITY DRIVING....
    i BELIEVE MY INJECTORS ARE LEAKING SLIGHTLY WHILE AT THE PARK EVERYDAY AND AT TRAFFIC LIGHTS.........MY ACCUMULATION OF OIL (CONTAMINATION) STARTED AT AROUND 29000 MILES ON PRIUS ....WHILE MY DRIVING HABBITS HAVE NOT CHANGED SINCE OWNERSHIP....i BELIEVE THE INJECTORS ARE WEARING AND DON'T BELIEVE INJECTORS CAN HOLD BACK 60PSI FUEL FOREVER.....
    I PLAN ON SIPHONING ABOUT 1.5-2.0 OZ FROM MY PRIUS EVERY 1000 MILES OR SO.(AND REPLENTISHING)...CAUSE i DONT WANT TO CHANGE MY DRIVING HABBITS.....AND i LOVE THE SOUND OF A QUIET PRIUS ENGINE......iT SOUNDS EXACTLY LIKE IT DID WHEN I BOUGHT IT......
  15. richard schumacher
    7,683
    1,066
    United States
    Fuel should not be getting into the oil nearly that fast. Siphoning oil addresses one symptom but not the cause. You need to get the problem diagnosed properly and repaired before some expensive engine damage occurs.
  16. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    ....agree with Richard I see very little oil level change.
  17. markw.austin
    markw.austin New Member
    Virginia
    Entering this discussion late BUT I 100% can tell you what is causing fuel in your oil.
    I have encountered the exact same thing on an old Nissan 240 that I have, and it can apply to ANY fuel injected vehicle.
    You have a leaking fuel injector!
    When your engine shuts off, for stoplights, while coasting, or turned off at night, you have an injector that is not closing properly.
    This causes "bleed down" to occur, dumping fuel on top of the cylinder.
    Because Piston Rings do not seal 100%, the fuel bypasses the rings and drips down to the oil pan. thus filling your oil with fuel.
    This is also common in Diesel engines. Carbon or "crap" in the fuel can cause the injector to not close properly, or the thing just gets old and doesn't seal shut.
    It's next to impossible to tell which injector is doing this so:
    How to fix: Replace your fuel injectors. Pretty simple to do too. should cost about $45 to $120 per injector.
  18. epoch_time
    240
    112
    las vegas
    I would like to clear something up here.
    I have been siphoning top oil out of my prius several days in a row not because the oil is being diluted this fast,
    but to get fuel accumulated over 4 thousand miles out of oil...
    And I dont know how much still setting time without driving is nessary to get all fuel out of oil...
    I dont think anything is wrong with my prius other than mine doesn't burn any oil making it obvious that oil is being contaminated by fuel.\
    I broke in my prius engine very well so as not to burn oil...
    Also my girlfriend has gen III prius with 10k miles now. and with 2k miles on recent oil change her oil smells exactly like my gen ii prius
    with 2k miles of oil dilution with fuel..
    So I am siphoning oil out of both prius's.....
    I find two days of setting allows fuel to seperate nicely and float to top surface.....
  19. epoch_time
    240
    112
    las vegas
    Extra info on our prius's.
    I have about 8500 miles on mobile 5-30 extended. Having siphoned out 2 quarts, 4 ounces at a time my oil looks brand new.
    I started my first siphon at about 4000 miles when I noted valve train noise.
    All my driving is city stop and go...After siphoning my first 4 ounces from girl friends gen III prius...We drove to pioche for the solar eclipse
    and the long drive burned off all residual fuel contamination from here prius and her oil smelled perfect...
    I believe all internal combustion owners should be siphoning fuel off there top oil... especially with todays thinner oil 0-20 etc.
    If you drive long distances with continous engine running your probably ok not siphoning...
    But to put your mind at rest siphon top oil into empty plastic water bottle then siphone bottom oil into another empty water bottle..
    after parked for 24 hours and smell the difference.......Bottom oil smells only like oil ...
  20. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Did you mean you siphoned out 2 quarts in total during 4000 ~ 8500 miles and the oil level maintained the same since last oil change? That's half of the oil capacity! Something is wrong.
