Mobile Mechanic San Francisco area Recommendation?
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Jan 15, 2020.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    Do any of you have a mobile mechanic in the San Francisco area you can recommend ?
    I want to do my own work but I need someone that know what they are doing so the job doesn't take weeks to do
    Thank You
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    What are you looking to do:whistle:?
    SFO and Rob43 like this.
  3. Taxi/Limo
    526
    107
    Change out my brake fluid (The dealer said I need to )
    Change out my front bumper cover replace the left blinker assembly
  4. Mendel Leisk
    42,253
    Did dealership give you a quote? They'll typically charge around $100~125. If it's a lot more, try some others.
    It takes about an hour to DIY, plus the time to raise the car and remove wheels. Two pints of Toyota DOT3 fluid is what I use, costs around $7 (CDN) per pint for me.
    Have you watched @NutzAboutBolts video? Very helpful.
    You do need to be careful, have the car in "invalid mode". Don't just hire some cowboy who thinks he/she knows better.
    Some Repair Manual info attached. Note, they recommend to start with front/right go counterclockwise:
    SFO and NutzAboutBolts like this.
  5. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    Brake Fluid gone bad already?
    How many miles and how old is your Prius?
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Did you upgrade the 2010, or just add a Prime to your fleet? o_O
  7. Taxi/Limo
    526
    107
    2010 with 79k miles no record of fluid being changed ever
    Thanks
    #7 Taxi/Limo, Jan 16, 2020
  8. Taxi/Limo
    526
    107
    I don't understand
  9. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  10. Taxi/Limo
    526
    107
    Walnut Creek Toyota gave me a 160 dollar quote
    Thanks for the information
    Out of curiosity do I really need to worry about exchanging brake fluid since this 2010 has 79k on it?
    There is no record of the fluid being changed yet
    Does the fact that the brake pedal goes down more than before have anything to do with fluid?
    Thanks
  11. Taxi/Limo
    526
    107
  12. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    The real question: When if ever were your front brake pads changed out for new ones ?
    Rob43
  13. Taxi/Limo
    526
    107
    No Record of this
  14. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    OK.
    Brake Pads:
    There's a reasonable chance that your front brake pads have never been replaced. "If" you have a brake pedal that has a bit more travel than you'd like, most likely it's due to pads that are near the end of their life.
    Brake Fluid:
    Let's assume that you have the original brake fluid. Yes, you are realistically past the lifespan of your brake fluid. So change it too.
    Rotors:
    Most likely they're within spec...
    Rob43
    Taxi/Limo likes this.
  15. Mendel Leisk
    42,253
    Brake going down is likely due to water/air getting into the brake fluid? Pad wear should not effect pedal travel or firmness.
    Toyota USA recommends a "fuller" brake inspection, every 30K miles or tri-yearly. They don't really spell out what that entails, apart from a mention rotor inspection in the schedule:
    My interpretation is, that's a good time to pull off the caliper, clean/lube the pads and caliper pins.
    Toyota USA says nothing about brake fluid changes. However, Toyota Canada has, in the last decade, started saying to change it, tri-yearly or 48K kms (30K miles). This is an excerpt from the 2014 model year schedule:
    Note too the Canadian schedule for brake service ("fuller" inspection) is 32K kms or 24 months. That said, I stick with the aforementioned US interval, we are low miles, months invariably come first. Also, our car is garage stored, and our winters are relatively mild.
    Nice schedule btw, I'll attach a pdf, it's an excerpt from the full Owner's Manual Supplement. With the advent of 4th gen, that same publication has completely deleted the service schedule; you have to go online to see it, and not graph format, just one service interval at a time...
    For a counterpoint: Honda Canada, for as long as I can remember, recommends brake fluid change tri-yearly, regardless of mileage.
    SFO likes this.
  16. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    Oh, it most certainly does.
    Rob43
    SFO likes this.
  17. Mendel Leisk
    42,253
  18. Rob43
    Rob43 Senior Member
    1,373
    1,050
    2013 Prius v wagon
    I want you to think about this...
    Rob43
  19. Mendel Leisk
    42,253
    Less able to dissipate heat?
  20. Taxi/Limo
    526
    107
    Why only front pads?
    I still haven't heard any recommendations for a mobile mechanic
