Featured Model 3 doesn't get CU recomendation
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by mikefocke, May 21, 2018.
  1. hill
    9,014
    Ford C-Max Energi discontinued, C-Max Hybrid to continue assembly until mid-2018
    My wife agrees w/ your list & its descending order - but it may not be what others want/need.
    Ford .... can't figure what they're up to ... they're #17 (right behind gm) on the satisfaction survey list - post #40.
    #61 hill, May 27, 2018
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I don't think I'm going out on a limb here to say most people want choices.
    Honda's learning the hard way: " And here comes Honda with their touch-screen interface. Mind you, Honda is generally a champ at reinventing things. After all, that carmaker was born from tinkering, rethinking the status quo, and over-engineering stuff. But when they came up with the idea that it was best to re-engineer the ever-so important volume knob on their touch-screen interface, they transformed a system that was originally designed to avoid driver distraction into one of the most frustrating and counter-intuitive infotainment systems offered in today’s automotive industry."
    2016 Honda Fit: Where's the Volume Knob Honda?
    "If you want to turn the volume up, you swipe your finger up the strip. But one swipe doesn't take you from silence to full blast. To reach what I consider normal listening volume, I have swipe up about three times. Finer adjustments mean you have to carefully slide up or down by very small increments — a task that occupies more of my attention than I prefer while operating a horseless carriage. To lower the volume in a hurry, like if you think you hear distant sirens, it's swipe swipe swipe again.
    So here's my fix. It's a knob on a suction cup....."
    How I'd Fix the Volume Control - 2016 Honda Civic Long-Term Road Test
    Tracksyde and Tideland Prius like this.
  3. mikefocke
    4,073
    1,858
    Sanford, NC
    To go back to the original braking issue, a "software" fix for the Model 3 is being transmitted even as we speak and CU has said they will test a car or cars after the fix.
    Sports cars typically stop in 110-120 feet. And repeated applications of brakes when coming down the mountains is a necessity sometimes.
    In my hybrid, I've been in regen mode via the shifter but also applying mechanical brakes for thousands of feet of drop around mountain curves with truck safety emergency braking pull off lanes are every half mile and in the rain and fog. The car wanted to run about 50, I wanted 35 and trucks would emerge out of the fog at 25. Brake fade is not something you want to experience. Nor is boiling brake fluid due to long application of brakes in extreme heat. Change the brake fluid every few years.
    So I call BS on any attempt to say fade is something only auto reviewers care about.
    #63 mikefocke, May 27, 2018
    bwilson4web likes this.
    52,785
    is the model 3 a sports car, or the next gen camry/accord?
  5. El Dobro
    El Dobro A Member
    7,102
    3,282
    The Volt has it, but I keep forgetting to use it. :D
  6. Trollbait
    12,807
    Its segment is the same as the BMW 3 series is in. So compact luxury sports sedan.
    Did Musk or Tesla say this?
    On another note, your experience is argument for a transmission with more gears.
  7. hill
    9,014
    brake fade on an ev - especially those with huge amounts of regenerative capability is really a non-issue. We've driven our EV down some horrendous (long) grades & never even needed to cover the brake pedal, strictly using the one pedal driving method. It almost seems like those huge discs /caliper housings are just for adding a cool red paint color.
    Tracksyde and bwilson4web like this.
  8. Tideland Prius
    16,672
    This is what I liked about the Fusion Hybrid - the different available screens in the instrument cluster (I forgot the names now but they basically range from "basic" to "hypermiler" in terms of information display)
  9. bwilson4web
    16,513
    Back to the original subject, Consumer Reports made this YouTube:
    One measure of quality is how well the vendor addresses problems. There will be problems but if handled quickly and professionally, that is an important mark of quality.
    fotomoto, Tracksyde and Trollbait like this.
  10. bisco
    52,785
    this will be a big boost for cr's rep. and many will feel they forced tesla to do something the may not have wanted to do.
  11. mikefocke
    4,073
    1,858
    Sanford, NC
    I don't have any problem with the concept of the key card. You use those every time you check in to a hotel room. Now if the card had a diagram of where to place the card, that might solve a bit of the valet parking issue. Certainly is a rich world problem, isn't it.
    Similarly the controls interface is a classic geeks run amuck problem. We can do this neat thing which looks great in a demo. And the young tech savvy guys will love it. And the fan boys. But in the real world when I hand this car to my wife/kid/father/staff/valet and it is so different from any normal car they have ever driven, does it work? I don't think that is a question they asked themselves and now they are trapped with the hardware they have.
    On a normal car, without too much thinking I can control lights/headlights on/off and brightness, cruise control on/off and speed plus resume or even increase a bit, wipers on/off and speed front and rear and washers, as well as turn signals. 4 stalks, pretty much the same place on most cars and clearly marked with mostly universally recognized symbols, no language specialized programming necessary. And to view those switches (stalks) the eyes only travel directly down from the road/traffic view and not over and down.
    I thought CU looked good on the review and its video summary and Musk looked as good as he could given that something that should have been discovered by sample testing a year ago wasn't right. You gotta be dumb or arrogant to not replicate all the tests you know the reviewers will do and benchmark your results against theirs. The only product whose development I ever managed from day one I insisted on quantitative benchmark tests against the competition and we didn't go to the next function until we were equal (or better in the ones that really mattered). That is kind of basic product development practice. Why produce something that will flunk a test?
    orenji likes this.
  12. austingreen
    austingreen Senior Member
    13,713
    4,231
    Austin, TX, USA
    I don't think cr has a good reputation when it comes to cars or electronics. Tesla is a well managed fast reacting company. Look at how long toyota took to add a brake interlock. Hey a broken digital clock is never right (and never taken for wrong since you know its broken :eek:), but those stopped analog clocks are right twice a day. Seems some software problem, that didn't exist during the car and driver review cropped up on the CR car. Not much more to say.
    The cockpit of the model 3 is definitely different. I seem to hear the most complaints from people that would never buy the car. CR probably would have us all driving cars that looked like 1990s corolla's and civics if their reviews were what people wanted in a car. Tesla probably would have done well to plan for 150K cars in 2018 instead of shoot for 400K cars, then fail. Hopefully the initial software problems will be fixed before I get my car. I don't think tesla would have been right to give the car a cockpit like a camry. Still there might be a desire for a couple more buttons or knobs and maybe even a heads up display.
    BMW, Lexus, Mercedes all have had more problems with their interface, but Tesla needs to learn from their mistakes.
    Tracksyde likes this.
  13. bisco
    52,785
    there is more to say, and it has been said by tesla. the brakes were not effective enough, cr caught it, and tesla fixed it. did i miss something?
  14. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    Yeah, the voice commands work well. But I'm comparing to my 2012 Prius and 2011 Sienna (which is worse than the Prius). But I think most voice commands are entertainment center related or navigation related. I dont recall any voice commands for anything car related? But as far as navigation, its been pretty good with the voice recognition. The collective hope is that eventually, you'll be able to tell the car to set your wiper speed, stuff like that.
    The 129Wh/mi was displayed on the screen. There are 2 trip meters (Trip A and Trip B, which I renamed to 'Lifetime') and then it shows one trip meter for current trip and one for "since last charge". The 129Wh/mi was from my trip to work from home. From what I've gathered, this number shows all electricity use while in D, but not what is consumed in P? (so if you sit in the car with the AC running for 10m and then leave, that wont count against your drive.. but the AC use while driving will count).
    3PriusMike, bisco and austingreen like this.
  15. Tideland Prius
    16,672
    It depends on the MFD function. On the Gen 2, you could use voice recognition to set the climate control temperature. On the Gen 3, you can't because the climate control is separated from the MFD.
  16. bwilson4web
    16,513
    Source: Tesla Model 3 Gets CR Recommendation After Braking Update - Consumer Reports
    Consumer Reports now recommends the Tesla Model 3, after our testers found that a recent over-the-air (OTA) update improved the car’s braking distance by almost 20 feet.
    The software update came a week after Consumer Reports published test results that showed stopping distances for the Model 3 that were significantly longer than any other contemporary car. That braking performance, along with issues with the Model 3’s controls and ride comfort, initially prevented the car from getting a CR recommendation.
    Last week, after CR’s road test was published, Tesla CEO Elon Musk vowed that the automaker would get a fix out within days.
    Until now, that type of remote improvement to a car’s basic functionality had been unheard of. “I’ve been at CR for 19 years and tested more than 1,000 cars,” says Jake Fisher, director of auto testing at Consumer Reports, “and I’ve never seen a car that could improve its track performance with an over-the-air update.”
    Excellent results.
  17. hill
    9,014
    My favorite part;
    I'm sure the drama will continue nevertheless. It makes for good blog sales.
    austingreen likes this.
  18. austingreen
    13,713
    4,231
    Austin, TX, USA
    We have some other information too. Perhaps the model 3 should have slightly less range and grippier tires.
    Stopping Distance and Grip With 18- and 19-inch Tires - 2017 Tesla Model 3 Long-Term Road Test
    This was on may 25, which may be before the software update. I'm curious how cr did so much worse than edmunds, motortrend, and car and driver. The continental tires seem to stop and hold better than the michelins that tesla chose.
    I'm thinking I'll probably end up with the dual motor at the end of the year, and they will have that sucker handling and braking better, but the performance of even the pre-january rwd cars seems really good, but may need replacement tires to stop and corner faster.
  19. padroo
    padroo Senior Member
    2,763
    2,253
    There are people who like CR and people who don't. I have been a subscriber for many years and respect their opinion. I respect it but that doesn't mean I have to agree. I feel a lot of the safety features we have in our cars are because of companies like CR. I try to keep an open mind. At one time I wanted a Tesla and as time has went by I have changed my mind. I wish Tesla company well.
    fotomoto likes this.
  20. 3PriusMike
    3,101
    2,421
    Silicon Valley
    This is both good and bad news for Tesla.
    Good in that they are able to solve a problem like this so quickly via OTA updates.
    Bad in that how could something so safety critical, like braking, have been overlooked to this extent if it is so easy to adjust?
    Is it that they did something as simple as adjusting the amount of regen vs friction braking?
    You would think that they would have had a few dozen safety critical parameters that they spent months tuning properly after the prototypes were shown a year ago.
    Mike
