Featured Model 3 has 310 mile range
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Jul 29, 2017.
  1. Fred_H
    Fred_H Misoversimplifier
    562
    488
    28
    Germany
    I am fairly certain that the Teslas have oil in the transmission that should be changed periodically. I hope they do not claim to have kamikaze "lifetime" transmission fluid.
    So of course Teslas have free (none) engine oil changes, but I doubt that all transmission oil changes are free.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Plenty of vehicles - Prii included - simply don't have any type of transmission fluid or gear oil listed in their maintenance schedule.
    markabele and Zythryn like this.
  3. frodoz737
    frodoz737 Top Wrench
    4,801
    2,560
    33
    What you didn't know...Toyota WS is magic. :LOL:
    m.wynn likes this.
  4. Zythryn
    Zythryn Senior Member
    6,411
    4,412
    As explained by others, it was meant as a joke, which is why I used :p.
    Tesla doesn't use that joke, as apparently it isn't a very good one:(
    And yes, as others have noted, Teslas have other machine parts that require some lubricants, but obviously has no traditional oil changes.
    Prodigyplace likes this.
  5. hill
    9,036
    I'm fairly certain, too ....
    that you're kidding, right?
  6. bisco
    52,847
    You think the tranny is oilless?:cool:
  7. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I believe regular ole Dex 6... The gear reduction must be getting an oil bath.
    #387 m.wynn, Aug 25, 2017
  8. hill
    9,036
    You're bad ...
  9. hill
    9,036
    pretty sure ... as soon as I can find the dipstick, no doubt squeezed somewhere between the drive motor & drive lines, I'll let you know for certain.
    of COURSE updates are always free - as the only thing necessary, is to push them through the cars' LTE cellular connection. It doesn't require driving your hump down to a service center. You get notified, either by your phone's app - or on the car's display screen. Like so ....
    once the update is done, you get an on-screen message that says what the latest fix or upgrade is.
    #389 hill, Aug 25, 2017
  10. Trollbait
    12,824
    My last two cars with traditional automatics didn't have a dip stick.
  11. hill
    9,036
    Most likely, very few trannys have sticks. That was supposed to be part of the nonexistence tranny oil humor.
    #391 hill, Aug 25, 2017
    m.wynn likes this.
  12. bisco
    52,847
    tesla tranny has a dipstick, that's the curious part. to make sure it's empty?
  13. hill
    9,036
    Feel free to draw an arrow on the photo - @ post #289 exactly where th3 heck that is.
  14. bisco
    52,847
    my computer doesn't go back that far.
  15. Fred_H
    562
    488
    28
    Germany
    No, not kidding, I just had the impression that 3PriusMike thought there is absolutely no oil in a Tesla, and wanted to remind him of the gearbox.
    It's probably right behind the ignition coil.
    Here's the latest maintenance plan:
    Maintenance Plans | Tesla
    It includes "Drive Unit(s) fluid service" at 1 year / 12,500 miles.
    3PriusMike likes this.
  16. m.wynn
    684
    1,230
    Queensbury, NY
    Oops, I'm a little slow!:LOL::D:D.....
  17. bwilson4web
    16,531
    It looks like Tesla also uses the 'sealed' transmission design approach. But every gear stage will take ~3% of the power. By inspection, one pipe looks like a lubricant pipe feeding the top of the first gear stage. The rest can live with what 'slings down.'
    hill, Trollbait and Prodigyplace like this.
  18. Trollbait
    12,824
    There is a black cap in the back top middle near the oil line Bob pointed out, and what appears to be a hole in line with it at the front.
    Tesla probably considers the gear oil lifetime like my transmission fluid.
    markabele and hill like this.
  19. Fred_H
    562
    488
    28
    Germany
    My interpretation of the maintenance plan for the model S (Maintenance Plans | Tesla) is that it repeats every 50k miles. So after the initial post break-in oil change at 12,500 mi., it would be repeated at 62,500; 112,500; 162,500; 212,500 etc.
    Comparing to the Prius, with which we are most familiar with:
    On one hand, the Tesla transmissions appear to have fewer gears and bearings than the Prius, which would speak for longer change intervals.
    On the other hand, the higher vehicle weight and and much smaller oil capacity of the Tesla (https://teslamotorsclub.com/tmc/posts/2031323/) would speak for much shorter change intervals.
    So the 50k mi. for the Model S, compared to the 60-100k mi. for the Prius seems about right.
    Assuming the Model 3 is similar, then the simple drain and fill transmission maintenance costs for material and labor would come out roughly the same as for the Prius. And of course for the Tesla there are no engine oil changes, engine filters, nor spark plugs needed.
  20. Zythryn
    6,411
    4,412
    Sort of. My understanding is that they check the lubrication of the two ball bearings ( four if AWD). Not sure about the non motor lubrication.
