Model 3 in the wild
Discussion in 'Tesla' started by bisco, Aug 10, 2018.
  1. bisco
    52,521
    i haven't, and tbh, i don't know how much longer we'll be here. it's beautiful, but the acre is becoming to much to take care of.
    if only i could talk my wife into moving to a certain state with plentiful sunshine and no snow.:cool:
    Raytheeagle likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Im pulling for you;).
    Currently in PA with my folks where it is rainy constantly and prohibiting work we had planned:(.
    But had a nice family get together in between torrential downpours(y).
    52,521
    yep, been feeling like bali around here the last couple weeks. i'm starting to sprout.
  4. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    There’s definitely stuff growing here that moisture promotes:eek:.
    I’ve been spoiled away from the humidity:(.
    The old farm house without ac is a bit of a sleeping challenge in this weather:cool:.
  5. hill
    8,970
    culturing a little feta cheese between the toes, eh?
  6. bisco
    52,521
    not only.:whistle:
  7. bisco
    52,521
    how do they do it? my biggest fear is the a/c breaks down in the middle of a heat wave and it takes a couple days to fix it. i'd be in a hotel, or at least the pip.:D
  8. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    There’s a lot of mushrooms growing around here in not normal places:cool:.
    Probably not the only fungus I would imagine:whistle:.
  9. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Years of experience ;).
    They have a window unit for their bedroom:cool:.
    When they added on the rooms for my brothers room and mine above the garage (not insulated), they installed the slide horizontal windows, not the open vertical style. So no way to add a window unit:(.
    I just have the fan cranking full blast as a stop gap;).
    Winters are better as you can layer the blankets up(y).
  10. bisco
    52,521
    but you would have to compare no a/c to no heat. that's a lot of blankets!:eek:
  11. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    It could be a lot of blankets, but there are other ways to stay warm in the winter:).
    I was born in December, so there had to probably be at least one cold late February or early March evening ;).
    We bring out the flannel sheets too as a stop gap(y).
  12. bisco
    52,521
    yeah, a lot of kids were born 9 months after the blizzard of '78.:whistle:
  13. Trollbait
    12,719
    When the skunks moved out of our neighborhood, the rabbits moved in.:mad:
    I suggest looking into a channel drain in front of the garage. Divert the water before it gets in.
    bisco and Raytheeagle like this.
  14. bisco
    52,521
    unfortunately, it is condensation and rain dripping off the car. nothing coming from outside, that would be an easier fix.
    when we get weeks of rain and humidity, it is constantly like this. when it is less humid, it dries up pretty quickly by leaving the garage doors open.
    snow melting off the car creates even more water.
  15. bisco
    52,521
    if you look at my post #9, in the picture, there is a thick rubber seal on the bottom of the garage doors, a 1" drop at the outside edge of the concrete, and a sloped concrete entry pad and sloped driveway. all that was designed correctly.
    what happened inside? i guess they were just careless when floating the cement.
  16. Trollbait
    12,719
    Even if done right, it sounds like you would still have water on the garage floor, just in different spots.
    A floor blower should help in drying puddles out.
  17. bisco
    52,521
    probably. pitched to the front, it might be a bit less. in the olden days, some pitched to the center with a drain, now illegal.
  18. Trollbait
    12,719
    Was going to mention a floor drain. I guess they are illegal because of oil and other leaks of stuff we don't want getting out in the environment.
  19. bisco
    52,521
    exactly.
    i've been eyeballing the perforated rubber floor tile systems.
  20. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    Really?!? Seems a bit ridiculous to me as the problem isn't the floor drain, it's the leaks. Speaking from experience, when a brake line fails, brake fluid will get into the environment and that won't be your biggest worry at that particular moment.
