Modem on: Forgotten way of being an energy guzzler?
Discussion in 'Environmental Discussion' started by Chuck., Jul 7, 2013.
  1. hill
    8,812
    Yes & no . . . no not specific when I thought, "etc" stuff - but yea, the cable box IS what ever they have - and if you unplug them - it takes several minutes for them to reboot & sync with the company. As for the modum stuff ... yes it has to run all the time because ours needs to constantly push data onto the cloud, as well as (stated in prior post) other functions. The brite side (as Sage mentioned) is these devices are pretty low power.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    hmm. I unplugged the turkey I found in my hotel room, and within I'll guess 10 - 15 seconds of plugging in the TV had a picture.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    I definitely need to perform that test at the next opportunity.
  4. icarus
    icarus Senior Member
    4,884
    976
    earth
    I put all the TV electronics on a pow strip except the DVR. It takes but a minute to fire up the system, time I will give up to save KWHs.
    Icarus
  5. austingreen
    austingreen Senior Member
    13,677
    4,214
    Austin, TX, USA
    The US spent about $400B in 2011 on electricity. If we shut off all these modems, the article says we what? Might save $1B, 0.25%. That seems really minor. If we switch to add 1% to renewable energy, it likely won't save money but it would reduce pollution by over 4 times having everyone turn off these devices.
    Swap 5% of the power from coal to natural gas, as has occurred recently in the US, and reduce ghg emissions from electricity production by 2.5%, that is 10x more reduction than turning off these devices. Turn off your modem if you want, but keep the significance in perspective.
  6. SageBrush
    11,627
    2,533
    Southwest Colorado
    The article is advocating for more efficient devices, not turning them off. Their goal is 25% less power.
    So they are hoping for a $250 million dollar savings from a $400 Billion electricity bill.
    Now, I don't know if my setup is typical, but it uses half the power they assumed. So as far as I am concerned, they are advocating for a $125 million dollar savings (unknown if possible) on a $400 Billion national electric bill. That works out to be a 0.03125% savings. Or put another way, if in fact it was possible to engineer a 25% power savings over what I have now, and the device lasts about 3 years, the incremental marginal cost ignoring R&D could be no more than $3.88 per device before the upgrade costs more than the electricity saved.
    Silliness, really. I do however agree that all these devices should have typical use power ratings disclosed. I suspect more to the point is advocating for efficient power supplies and transformers, although that might be happening through competitive markets anyway.
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I'm not sure where my modem is. I just plug my wireless router into the cable outlet in the baseboard.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Sounds like you have a combo device. Modem and router in one package.
  9. hill
    8,812
    My bad ... I should have more clearly stated that I was talking about unplugging our cable box. The very low draw on our other hardware would never make it worthwhile to unplug any of it.
    austingreen likes this.
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    I think we are talking about the same thing. I unplugged/plugged a Comcast supplied box that sits between the wall outlet and the TV. The hotel used to plug the TV directly into the wall, but Comcast now requires the intermediary box. I presume it is there for monitoring/piracy-prevention but I don't know for sure.
  11. jhinsc
    1,167
    259
    South Carolina
    I don't think so. I bought the router myself years ago and plugged it in when we went to a two computer/laptop household. Without it, just plugged the cable from the computer into the baseboard outlet.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    Huh, that is unusual. Do you live in an Apt ?
    I'm curious what the plug that inserts into the wall looks like:
    1. Telephone plug ?
    2. Oversized telephone plug ?
    3. The type used for cable TV ?
    4. Something else ?
  13. austingreen
    13,677
    4,214
    Austin, TX, USA
    A modem is likely running behind that baseboard outlet, it is just hidden. I wouldn't worry too much about it though as long as it keeps working.
  14. jhinsc
    1,167
    259
    South Carolina
    The plug outlet looks like any other wall cable outlet, except I had most outlets in the home placed in the baseboards since they're tall enough. Built much of home interior myself - just can't recall what the cable company did to hook us up. It could be in the attic, but it's a not a conditioned space.
  15. SageBrush
    11,627
    2,533
    Southwest Colorado
    Does the connector look like this ?
  16. jhinsc
    1,167
    259
    South Carolina
    Yes - for the end that plugs to the outlet.
    EDIT - I take that back. Now that I think about it, I think it might be an RJ12 or RJ45 connector that plugs into the wall. I'll have to check when I get home tonight.
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Then I am amazed you can connect directly to a laptop. If you get a chance, I'd like to see a photo of the laptap with this kind of connector jack.
  18. jhinsc
    1,167
    259
    South Carolina
    I edited my post immediately after posting it. It actually looks like a phone jack. I'm not very technical - sorry for the confusion.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    I want to be untechnical like you, if it means I can build my own house :)
    jhinsc likes this.
