modes
Discussion in 'Gen 2 Prius Main Forum' started by msandsm, Dec 2, 2015.
  1. msandsm
    msandsm Junior Member
    I'm pretty new to Prius, and I'm not the most technical person, so please be patient with my questions. ☺️ I own a 2007 Touring model, and I'm confused when people talk about "pressing the button for EV mode, or ECO mode". Can someone tell me exactly what these are, and where? I've never noticed any buttons with those labels, or one with PWR either. Could it be that the 2007 doesn't have them, or am I just looking in the wrong place?
    I'm soon going to be driving I-5 to Seattle, which passes Mt Shasta at about 4300 ft. I want to get the best mileage I can, so I've been searching this forum for "mountain driving." Saw many differing opinions, but am wondering about the various "modes" people are talking about, as well as the "B" position on the shifter, and how they affect joy MPG.
    I appreciate anyone taking the time to answer my questions. (I might also mention that I rarely use forums and so am unfamiliar with most of their workings. Should this have been a reply, as I've done, or a new thread?)
  2. Mendel Leisk
    42,361
    I think those buttons were introduced with 3rd gen, 2010 model year?
    Don't worry, you're not missing much. I just leave it in the aforementioned "normal" mode, the other modes don't really do much, mainly change gas pedal feel.
  3. fuzzy1
    10,720
    You can use 'B' mode to avoid overuse of the brake pedal when descending Siskiyou Pass. Otherwise, don't use B as it will cut MPG, and has no benefit on flat roads.
    As Mendel mentioned, the other modes didn't appear until 2010.
    johnnyb588 likes this.
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Correct, use B where you would normally use L (someone at Toyota was too honest to call it L as it is not a Lower gear, just engine Braking) going down long, steep hills.
  5. Mendel Leisk
    42,361
    Criteria for using B mode is long downhill grades, ie: don't use it as a substitute for day-to-day braking. It's only needed where there's a likelihood of the hybrid battery becoming fully charged by regenerative braking, and the car switching to all friction brake, and a lot more downgrade still ahead of you.
    Like coming down a ski hill, for example.
  6. bisco
    52,878
    great post, all the best on your trip!(y)
  7. lexidium
    lexidium Active Member
    304
    144
    manchester
    On my 2008 spirit (UK), the EV button is on the lower dash just under the steering wheel - next to the intelligent assist parking button.
    Whether it's the same on US models I don't know.
    It would show you on the diagram in the manual.
    Data Daedalus likes this.
  8. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    The UK 2008 Prius TSpirit does indeed come with an EV button :D. However, bizarrely, this option was not included in the US equivalent Touring models o_O. Just like they have heated side mirrors on Swedish Gen 2 Prii, and we don't get that in the damp and cold UK :unsure:
  9. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    I frequently make drives with ~7000-ft elevation changes, and I rarely, if ever engage B even on those drives. I suppose every Prius will be unique, but it usually takes stretches of a bout 15 miles and a few thousand feet in elevation change in order for my battery to become so charged that it needs to engage B mode. Your car should automatically apply engine braking if the HV battery is in danger of becoming overcharged, so the only reason for applying B mode I can think of is not HV battery protection, but rather speed control on descents.
    For instance, there is a hill on my drive where the speed limit is 55mph, but coasting will take me to 90mph+ if I don't press my brakes. Engaging B mode early on the hill will keep me in a reasonable speed range. However, rather than mess with that I just tap the brake pedal every now and then to keep my speed in check. No B mode for me.
    #9 johnnyb588, Dec 7, 2015
  10. fuzzy1
    10,720
    ^^ 'B' mode is to protect the mechanical brakes, not the traction battery.
    The need depends on the slope too, not just the absolute elevation change. 2000 feet in 15 miles is just 2.5%, that is not bad and highway speed air drag can scrub much of that energy. I occasionally drop that elevation in 7 miles, much steeper, and my battery fills up in the first two miles even with B engaged.
    Earlier this year, a new member from Hawaii overheated and seriously damaged his brakes twice before learning here that B mode is required on his road. The weaker automatic engine braking was not enough to protect his mechanical brakes on his 4000+ foot descent.
    A couple days ago, I went through some National Park Service volunteer training under our new overseer. As part of the program, we get use of an official government truck while on duty, donated by another office that doesn't usually work the same days we do. Coming back to HQ is a 2600 foot descent in 11 miles, a 4.5% average slope at an average speed under 25 mph, so very little energy is scrubbed to air drag. We are required to downshift to protect the brakes. Excessive brake wear compared to the other staff, or failure to report overheated brakes -- these will be discovered by the park's mechanics -- may result in loss of the vehicle from this program.
    giora and johnnyb588 like this.
  11. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Question, then. If B has nothing to do with the SOC, why does it automatically engage on long downhills even when I am not using the brakes? Honest question. I just assumed it had to do with the SOC (as well as saving the brakes) because mine automatically engages.
    And fyi, when I say mine automatically engages, it doesn't actually go to B on the dash display. It is just that the car is obviously using engine braking to slow the vehicle's descent.
    #11 johnnyb588, Dec 7, 2015
  12. fuzzy1
    10,720
    B mode does not automatically engage. Period. If it doesn't show B in the dashboard, you are not in it.
    When gliding with foot off the gas, the car produces a light synthetic drag from regeneration. Normally this energy is dumped into the battery. When that is full, the engine is spun up to low-moderate rpm to burn it off. But this drag is much weaker than B mode drag.
    I did some comparison testing on a hill earlier this year. After the battery filled, B mode held the car close to speed limit by spinning the engine up to 4600 rpm. Switching to D mode dropped the engine to 2000 rpm, and the car began speeding up significantly due to insufficient drag.
    In full B mode drag at high rpm, the engine screams like a banshee, or a turbine jet engine, or a giant vacuum cleaner. Some readers here have actually switched out of B because they thought the engine was on a path to self destruction.
  13. Mendel Leisk
    42,361
    Yup on that last paragraph. It takes will power to stay in B on a steep down grade, sometimes I chicken out.
    fuzzy1 likes this.
  14. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Perhaps I'm mistaken, but when my car automatically engine brakes on extended declines, there is no RPM difference between D and B. I've never done it while monitoring the RPMs via software, but the D engine braking is enough to prevent me from accelerating when at about 75 on a 7% decline. There is no discernible difference between D and B at that point for me. It goes full banshee in either mode.
  15. Mendel Leisk
    42,361
    Could be different, second gen vs third?
    Per Fuzzy1, when I'm coming down our local ski hill on a steep grade, there is a definite change going between B and D. I can see the rpm jump, then down (with ScanGuage), and even not looking you can feel/hear what's going on. Go into B and it really holds you back, and the revs get high, sometimes alarmingly so.
    #15 Mendel Leisk, Dec 7, 2015
    johnnyb588 and fuzzy1 like this.
  16. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I don't mean to be argumentative, but your perception that there isn't a difference, doesn't mean there isn't a difference.
    I just default to the rather obvious thought that Toyota wouldn't bother to give us a "B" option, if the whole action was handled automatically anyway. Ergo...there has to be a difference, even if you aren't noticing it or it isn't noticeable to you.
  17. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Interesting. Anybody have any idea what type of overuse it takes to overheat the brakes on a Gen 2? My trek doesn't appear to have threatened to cause any damage, but I've been through a ton of vertical ascents/descents that are pretty much the most severe in the US (pass through the Sierra Nevadas, Lake Tahoe, the Mogollon Rim), so I'd imagine I'm constantly at risk.
    I get what you're saying, but I disagree with the notion that they wouldn't give you manual control over an automatic feature (especially when the action serves more than one purpose, such as to protect the regen brakes and to limit the SOC). Auto manufacturers do that all the time.
    However, after reading up a bit more on B mode and the automatic discharge I'm experiencing, they do appear to be separate functions (although they have very similar effects).
    #17 johnnyb588, Dec 7, 2015
    The Electric Me likes this.
  18. fuzzy1
    10,720
    Which roads around Tahoe? I will say that I-80 and Highway 50 are not in the 'most severe' class. While I've been on some others, it hasn't been enough to remember in detail.
    The most severe I have been on was Pikes Peak road in Colorado. Prevailing traffic was too slow to get the engine spun up for adequate braking. Some other cars were geared down to the right speed for themselves, but it wasn't right for my Prius, and passing was not an option.
  19. Mendel Leisk
    42,361
    Gotta say I've never seen the car cease to charge, at least the display says it is.
    Our previous Civic Hybrid reached that threshold often, and the transition was definite, bordered on dangerous: the column of green blips indicating charging would suddenly diminish, then disappear, and you immediately needed to increase braking pressure to maintain status quo.
  20. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Pikes Peak is a doozy, yes. That's probably the most severely graded road I've driven (not in my Prius though). 7,700 to 14,100 in about 20 miles. That's about 6% average, if my math is correct, and there are sections that have got to be around 10%. Haven't been there in forever, but that's a beautiful place. That type of elevation changes the game as well. I can tell my lungs are starving for air at anything much about 10,000, so I can't image how hard it is for a little Prius to chug up a mountain at 14,000!
    As for Tahoe, it was SR431 that I recently drove in my Prius. It's not Pikes, but when I said "pretty much the most severe," I meant only to say that there aren't many places in the continental US where you're going to go from ~4,500 to ~9,000 and back to ~6,200 within 24 miles (and about 7 or 8 miles of that is relatively flat, so the steep stuff is actually fairly steep by any standards).
    #20 johnnyb588, Dec 7, 2015
