Modifications done under $100
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pholife, Aug 31, 2012.
  1. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Thanks SDTundra. So is this a spray on, or you dip it in a can? Did you pull the emblems off, and if so, where did you get the adhesive to reapply them?
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Spray on. Leave the emblems on. Mask the area, and remove overspray.
    Search this site and you will find plenty of threads.
    PriusCamper likes this.
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    easier if you remove the emblems :)[​IMG]
  4. Corwyn
    2,171
    659
    23
    Maine
    Much easier if you DON'T remove the emblems.
    I removed (and didn't put back) some of my emblems. Blackened the rest in place. It took longer to remove and clean up, than it did to blacken. And I ruined the HSD badge in the process.
  5. ucsmfu
    1,498
    420
    canada
    it's hard to remove the overspray if you don't remove the emblems, and also, sometimes the plasti-dip peels off when you are doing the letters.
    For all the badges, what you do is use a heat gun to heat up the badge, than use badminton string or fishing string and push it from the edges, the badges will come off very easily.
    Than use goo-gone to remove the double side tape residue, plasti dip the badges and add new double side tape to the badges.
    This way, you will get perfect blacked out emblems and badges :)
  6. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Yeah, I did not remove the HSD one and you can tell it didnt come out perfect. The PRIUS badge was removed and I used automotive trim adhesive to reapply it. When you do it just make sure you apply a thin first coat and dont hold the can too close or in one spot for a long period as it will run...
  7. Corwyn
    2,171
    659
    23
    Maine
    I had no troubles removing the overspray. A toothpick got in all the narrow crevices, and it peeled back from the background with no troubles. Less than 3 minutes per badge gave me perfect black emblems. Newspaper and painter's tape is all I used.
  8. D Colegrove
    D Colegrove New Member
    Oh my word! How did you change your backup beep to a single beep?
  9. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Scroll down to the posts by JerryLoz here. You can get the Elmscan5 toolcheap from Amazon, or you can try to get your dealer to do it for you free.
  10. EdyJun
    EdyJun Junior Member
    58
    Los Angeles
    How do you like the Tein sprints, and can you give details ?
  11. sdtundra
    1,314
    194
    Sacramento, CA
    Tein springs are nice....at first I didnt really notice a huge difference in ride height but after parking next to an identical car you can tell the drop. The ride wasn't rougher at Toyota's recommended pressure before and after the install and my dad borrowed the car for a trip to SF in June and didnt even realize the car was lowered until 3 days ago when I told him.
    The ride did get rougher recently as I inflated the tires to 44/42 but its still bearable.
    No MPG difference detected, still getting above 48 driving it like a normal car and 53+ trying basic techniques.
    BEFORE
    AFTER
    csp1971, ockevin and F8L like this.
  12. EdyJun
    58
    Los Angeles
    Looks good.... I am looking for a soft spring, after the 17s and 38/36 psi the ride is not as smooth.... looking to get the smoothness back.. ideas ?
  13. sdtundra
    1,314
    194
    Sacramento, CA
    Well, the ride is going to be rougher with 17's due to decreased tire sidewall. Try lowering the pressure a bit to 35/33 and see what happens. Unfortunately higher MPG doesnt always equal high comfort.
    You may try airbags but that will be expensive...($3999 just for the bolt on kit no install) or go custom.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The TRD springs are pretty soft and don't drop the car too much.
  15. ucsmfu
    1,498
    420
    canada
    Can't go wrong with the Trds
    The ride is abit bumpy which is normal.
    If you want a more comfortable ride you should get the Michelin mxm4 tires
  16. Absolutly Red Hot
    155
    83
    91
    SoCal
    Painted my Hubcaps semi Gloss Black $6.00 in paint to match the window tint. Looks better then stock. 1013121947a.jpg
  17. Xaran
    Xaran Junior Member
    95
    Prius Chat Store, install is double sided tape 5 minutes
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Or the Ecopia EP422 if you want a really comfortable ride and don't mind a softer handling tire. These things are kinda crazy.
  19. Kirklan760
    Kirklan760 New Member
    This may be a dumb question but which Tein spring are on your car? H-tech? S-Tech? I love he way it looks!!!!
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    His car does look sweet even with the OE wheels!
