Modifying Turn Signal Volume for Seniors
Discussion in 'Gen 3 Prius Accessories and Modifications' started by lex, Nov 18, 2019.
  1. lex
    lex 2005 Prius, always garaged
    119
    16
    Fresno
    Parents drive a pristine 2010 and occasionally do not notice the turn indicators has been left on after a maneuver. The fact -- as others have noted in a few past posts found -- that the signal click sound is among the quietest, certainly does not help. This is a very common problem for seniors, even when hearing aids are not called for.
    There is a program developed by AAA and the AARP called "CarFit" that mentions modifying turn signal volume, but after an hour searching online, we're not seeing who would perform this modification. Would be great if the Forum could provide a clue and refer us.
  2. Fifen
    Fifen Member
    77
    33
    Utah
    I looked in obd custom settings. Couldn't find anything about turn signal volume
    SM-G965U ?
    52,803
    hearing aids, you'll be amazed at what you were missing
    Fifen and PriusCamper like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,418
    5,416
    Pacific Northwest, USA
    There's limits to accommodating disabilities when it comes to an elderly person safely operating a motor vehicle... Maybe there's a way to make the click louder, but more important, let your parents know that if they don't want to lose their drivers license they're going to have to be on top of stuff like this. If they're too out of it to hear and see the blinker is still on long after making a turn or changing lanes, then they're fast approaching the reality of being too out of it to drive themselves safely anymore. Not seeing and hearing a blinker light right in front of you is not much different than not seeing or hearing an emergency service vehicle on an urgent call running a red light right in front of 'em. They gotta notice that stuff!
    #4 PriusCamper, Nov 18, 2019
  5. bisco
    52,803
    self driving cars
  6. PriusCamper
    13,418
    5,416
    Wrong forum... :) At least for the moment... But I sure do hope we're all old in grumpy in that forum together someday...
  7. bisco
    52,803
    i hope i'm still above ground when you're old and grumpy :)
    dig4dirt likes this.
  8. lex
    119
    16
    Fresno
    Thanks for the response. There are devices such as this - a replacement turn signal relay that adds a small transducer (speaker) to amplify the sound: http://www.turnalarm.com/
    If anyone has replaced the relay here, please advise on its location and difficulty to swap out?
    scona and bisco like this.
  9. bisco
    52,803
    i like that universal one. seems easiest to install and control
  10. lex
    119
    16
    Fresno
    Can you please explain how to install?
  11. bisco
    52,803
    no, i was just looking at the website. i would contact them. it says motion sensor, so maybe it just picks up on the blinker stalk movement
  12. bisco
    52,803
    there's a link to installation instructions
    the motion sensor mounts to the turn signal lever. the unit with sound and light mounts on the dash
    too bad it doesn't have a volume control
  13. Elektroingenieur
    2,515
    3,288
    Three Touring
    For later readers, note that on fourth-generation Prius and Prius Prime cars, the volume can be customized using a Toyota Techstream diagnostic system (or equivalent). The setting is Meter/Gauge System > Flasher Sound Volume Adjustment, and according to the Repair Manual (more info), there are three levels: “Large,” “Medium,” or “Small.” Medium is the default.
