Mods I've done to reduce drag
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 299K, Jan 21, 2020.
  1. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    you could try drilling holes in the frame, that would reduce some weight
    the more the merrier :LOL:
  2. 299K
    299K Junior Member
    30
    Cleveland, OH
    Already enough metal shed due to road salt here.
    I lost a geo metro to frame rust, god rest it.
  3. VFerdman
    VFerdman Senior Member
    1,200
    1,218
    Western Massachusetts
    Well, that would defeat my mod as even with vise grips, the drag will return as soon as the car moves. :) :) :)
    Tim Jones likes this.
    52,772
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    I removed my brake pads and shoes to reduce drag.
    VFerdman likes this.
  6. fuzzy1
    10,687
    When using D cells for jump starting, add at least a 9th cell for better results. It won't exceed the voltage rating of anything on the 12V system.
    I refuse give any advice about using small cells to completely replace the 12V battery.
  7. bisco
    52,772
    maybe thats why i'm getting the warning lights (n)
  8. ice9
    ice9 Active Member
    581
    346
    norfolk va
    2018 Prius
    I removed my lead boots.
  9. dolj
    dolj Senior Member
    8,633
    4,386
    Wellington, New Zealand
    I loaded up the Prius with three adults (two of them female) and all their luggage; the trunk was full as was the spare rear seat.
    Drove about 5,000 miles that trip and got some of the best MPGs that car ever made.
    Go figure.
  10. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    I put on a stubby antenna
    Raytheeagle and xliderider like this.
  11. 299K
    299K Junior Member
    30
    Cleveland, OH
    I had a similar experience. More weight lowers ride height, dont know if that would cause aerodynamic gains over the added weight penalty. I drive more conservative with others in the car, I think that explains the increased mpg.
  12. 299K
    299K Junior Member
    30
    Cleveland, OH
    That's cute, looks like a uhf antenna tho. How is your radio reception? I am eventually going to remove mine and speed tape the hole. I'll try a dipole inside along the top of the windshield.
  13. 299K
    299K Junior Member
    30
    Cleveland, OH
    Im open to trying. Anyone know the max current draw of the 12v system?
  14. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Honestly I dont really listen to the radio to judge it, but the couple times that i have, the reception was fine.
  15. George W
    George W Senior Member
    934
    519
    San Antonio
    Since the 12-volt is protected by a hundred amp fuse, that would be my guess
    fuzzy1 likes this.
