Moisture in Taillights
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mrb1, Dec 28, 2012.
  1. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Get it fixed before other problems occur
  2. Dan Danser
    Dan Danser Junior Member
    Florence, AZ
    Four Touring
    If they are vented, then why does the fog not go away? I have a 2016 and only the right one is fogged, It has been fogged up for 6 plus months. Never clears.
  3. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    After a rain, check whether you have water in the bottom of the 12-volt battery's space, which I did. The problem is that rainwater draining off the roof and hatch is routed through the tight space between taillight housing and body shell. When that passage clogs with leaves, dirt, pollen, etc., guess what happens?
