Moisture underneath throttle body
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Travis Davis, Apr 26, 2017.
  1. Travis Davis
    Travis Davis New Member
    27
    Seattle
    IMG_0103.JPG Is it normal for there to be some kind of moisture inside of the throttlebody? I'm thinking the answer is no and that I should try to clean out as much of that gunk as possible but I just wanted to get some opinions. Also is this just normal wear and tear for a car with this many miles on it? Or does it mean that there some kind of bad damage?
  2. JC91006
    16,933
    8,643
    It's normal to have a little oil in there. How often do you change your oil? Looks really dark
    SM-N900P ?
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    It is an artifact of the Atkinson Cycle engine. The intake valves stay open late so fuel-air mixture flows back out into the intake manifold, perhaps even beyond the throttle body. This is much slower than the fuel-air mixture going into the engine so fuel 'falls out' of the mixture and puddles at the bottom of the intake manifold. Nothing is wrong.
  4. Travis Davis
    27
    Seattle
    I just bought the vehicle. Previous owners had it done every 5-6K at the dealer religiously. Oil that's in it currently is only about 1K old and still looks like it just came out of a bottle
  5. Travis Davis
    27
    Seattle
    So should I try and soak up that fluid while I'm cleaning the throttlebody?
  6. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Or not... It's always gonna find it's way back there again, anyway. I mop it up when I clean the throttle body, as do many around here, but it's kind of silly to when you think about it. Atkinson weirdness is what it is.
  7. Mendel Leisk
    42,271
    Thanks to all who explained this. I've noticed this too, figured it was normal, but no clue how it got there.
  8. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    There's more than just oil in there. Is that left-over gunk from the throttle cleaning?
    Mine always has a small puddle of clean engine oil and I leave it alone.
  9. Mendel Leisk
    42,271
    I've only cleaned throttle body throat with a carb cleaner moistened cloth, still see that dark pool down there.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Yep that's dealer vat oil. The worst. Black burnt gunk. The car always has a pool of oil in the bottom of the TB.
    Don't bother cleaning it. The color of the oil will reflect the quality if the oil.
    Btw it's an almost certainty the car eats oil. Keep careful eye on oil level till u get a handle on how bad it is,
    Check the oil every few days before u start the car in the morning. That will reflect true level. If u roll into gas station and pull the dipstick it will always read a little low lots of oil stored in top of engine for the VVT system.
    Takes a while to drain back. Keep oil at full mark always.
