Monitor/Display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by senior33, Dec 9, 2011.
  1. senior33
    senior33 New Member
    Endwell,New York
    All of a sudden I cannot adjust my heat level, nor turn the unit off. My local mechanic has told me the entire unit may have to be replaced at a cost of 1.8K.
    Before this problem started my wife had attached our GPS to the screen that was displaying the heat/a/c etc setting. Could this have caused this function screen to fail?
    Senior33
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I am assuming the attaching of the GPS unit to the screen was done with some type of suction cup device?
    If so, the missus has violated Rule #1 when it comes to touch screen devices, which is...
    NEVER USE A SUCTION CUP ON A LCD TOUCH SCREEN!
    Unfortunately as tough as they may seem, the screens are actually kinda still in the handle with care part of their development. They will take some abuse, don't jab the screen too hard, but hanging a bouncing weight off of the unit is one of the best ways to trash the screen. I also assume you are out of warranty? If so ouch, you might try a Auto Dismantler, or even eBay, if you do the work yourself you could save considerable on the labor charge.
    Let us know how you make out!
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  4. cnschult
    cnschult Active Member
    772
    97
    Michigan
    do none of the steering wheel HVAC buttons work?
    I can't even remember the last time I had to touch my LCD screen.
    that's the problem with the generation 3 Prius, they made the outside look gorgeous but they did stupid things with the cupholders, location of the nav screen and took away key steering wheel buttons.
    I'm gonna order all the gen 3 body panels and replace my body panels ;-)
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    You mean you never swich between Energy screen and consumption screen?
  6. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    I use the "Info" button on the steering wheel to switch between them!
  7. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Yep. IIRC, people w/more stripped down 2nd gens have no Info button on the steering wheel.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    I have a Pack #2 07 and no Info button on my steering wheel.
    I would have liked that alot. I have just SKS and single disc.
  9. PhilWray
    PhilWray Member
    82
    28
    Malaysia
    Ooops - Sorry!
