More "Check hybrid system. Stop the vehicle in a safe place." alerts
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MyCarIsBlue, Nov 10, 2014.
  1. Dennis Chamberlin
    Dennis Chamberlin New Member
    2015 Prius Plug-in
    That is the case here. It has happened twice and the car went to dealer today. They have diagnosed a faulty charger and have ordered a new one. I guess replacement is a big job, taking all day. In the meantime, the car is OK to drive. No charge at Capitol Toyota, Salem.
    I asked about the "Stop car, check system" messages. He said OK to drive the car if it starts, runs OK and no obvious signs of destructive trouble, etc.. Get service appointment soon.
    The car no longer seems to take a charge. Either the charger has failed totally, or may be disconnected / disabled.
    Curiously, the last three successful charges have given me a bit more EV estimated miles (15 or 16) than I have been getting. Makes me wonder if the battery is benefiting from some kind of break-in process, or if the failing charger might have overcharged it a bit.
    51,901
    sad that toyota hasn't been able to weed out the faulty chargers before installing them in new cars, since discovering the defect. probably the warmer weather increasing your ev estimate. all the best with your repair!(y)
  3. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
    They're all stuck somewhere by the side of the road...?
    rxlawdude and bisco like this.
  4. Dennis Chamberlin
    2015 Prius Plug-in
    Bad charger was diagnosed. New one ordered, and backordered. Said it could be days or weeks, and OK to drive the car with the messages displaying if no other sign of trouble.
  5. bisco
    51,901
  6. TrinaF.
    TrinaF. Junior Member
    74
    23
    Southern California
    I've come back occasionally. I'm up to 10,000 miles and not had any issues since the replacement of the charger. Seems Toyota should do a recall to me.
  7. bisco
    51,901
  8. Dennis Chamberlin
    2015 Prius Plug-in
    New charger delivered and installed 3-26-15. Seems to work fine. The dealer that performed the service, (not the same one I bought the car from) Capitol Toyota in Salem, OR. treated me well, communicated well, and had the car finished on time. I wish I knew a little more about the problem, specifically: Has the cause of this infantile failure been identified and fixed? Is the fix incorporated in my new part, or is the new part just picked from inventory?
    (*"infantile failure" is a technical term that refers to very early failures where a relatively new part fails way short of its expected lifetime. They sometimes are evidence of material or process defects.)
  9. bisco
    51,901
    no one has come back to complain about their replaced unit, so it's probably fixed. unlikely that toyota would want to keep paying to replace defective units. what's puzzling is how the '15's are getting out of the factory with bad units.
