More codes after changing 12v battery a week ago
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by av8erdunn, Dec 23, 2014.
  1. Patrick Wong
    18,210
    6,517
  2. Patrick Wong
    18,210
    6,517
    Replace ABS #2 relay now. DTC C1313 is pointing to that.
    If DTC P0607 persists after you replace the relay you may need to replace the hybrid vehicle ECU as well.
    #22 Patrick Wong, Jan 5, 2015
  3. av8erdunn
    av8erdunn Junior Member
    78
    Mobile AL
    OK. Is there a preferred site to buy from? And when you say now does that mean there is a possible unsafe situation I need to worry about? I just don't want to put my wife and kids in it if its unsafe. Also is abs relay 1 & 2 the same part numbers? I'm not at the car so I can't pull them right now.
    Thanks for the help.
  4. Patrick Wong
    18,210
    6,517
    I say "now" because the Prius is continuing to experience the same problem. It's up to you to decide whether you want your wife/family to deal with that or not. Of course you could swap cars with her while you are figuring out what to do with the Prius.
    I buy my Toyota parts from AutoNation Toyota Gulf Freeway, Houston, TX. Just call the parts dept and ask for their price on the ABS #2 relay.
    Or try to find the relay on their website: AutoNation Toyota Gulf Freeway Parts
  5. av8erdunn
    78
    Mobile AL
    Sounds good. I'm gonna call them in the morning.
    Thanks again
  6. av8erdunn
    78
    Mobile AL
    Replaced relay last night and the dash lights came on again this morning but the cruise light wasn't flashing as before.
    As soon as she gets home I'm gonna scan it. I will let you know the diagnosis. This thing is gonna drive me nuts.
  7. av8erdunn
    78
    Mobile AL
    Now its c1249 open circuit in stop light switch circuit. This seems like it always happens when she's in a drive thru.
    I'm going to go bang my head now.
  8. Patrick Wong
    18,210
    6,517
    Replace the stop light switch which is located near the brake pedal assembly. You may need a crowfoot wrench of the appropriate metric size.
    It is certainly possible your car had two separate issues.
  9. av8erdunn
    78
    Mobile AL
    Will do!!
    Is that a fairly common problem with these gen 2's?
  10. Patrick Wong
    18,210
    6,517
  11. av8erdunn
    78
    Mobile AL
    Well the problem seems to have shown again. I'm at a loss s to what to do. Any help would be appreciated. The codes are in the pic.
  12. Patrick Wong
    18,210
    6,517
    In post #28 I suggested that you replace the brake light switch. Did you do that replacement back in January?
  13. av8erdunn
    78
    Mobile AL
    I did indeed.
  14. Patrick Wong
    18,210
    6,517
    And the problem went away from that point, until the beginning of May?
  15. av8erdunn
    78
    Mobile AL
    That's correct. The codes have been few and far between at times.
  16. bisco
    52,855
    trade it in on a v?
  17. av8erdunn
    78
    Mobile AL
    As much as I'd like too I would rather just find out what's going on with this thing. yeah I could trade it in but I'm kinda fond of the ol girl.
  18. Patrick Wong
    18,210
    6,517
    DTC P0607 is a code that appeared in the photos you posted in January as well as today. That code did not appear in your OP.
    P0607 means that the hybrid vehicle ECU has a failure. The ECU has two processors. The code is logged when the two processors do not agree that the brake pedal has been depressed to stop the cruise control function. At this point the cruise control feature is disabled and the DTC is logged.
    You could buy a new HV ECU (89981-47212) for $277 here:
    2006 Toyota Prius Parts - AutoNation Toyota Gulf Freeway Parts
    Or you could buy a used HV ECU for $77 here:
    06 09 Prius Hybrid Vehicle Control Module LKQ | eBay
    If you are serious about a DIY repair, I suggest you download the relevant info at techinfo.toyota.com as you will need to disassemble much of the dashboard to gain access to the HV ECU located behind the glove compartment. Verify the part number on the original equipment ECU before you buy a replacement.
    #38 Patrick Wong, May 3, 2015
  19. av8erdunn
    78
    Mobile AL
    Hmmmm.... Im a serious DIY but I have never liked taking the dash out of things. Its always a pain to do by yourself.
    The parts cheap enough but Im gonna have to think about this one.
    As always, thanks for the help.
  20. Patrick Wong
    18,210
    6,517
    Are there any driveability symptoms other than the warning lights being on? If not, then I suppose you can continue to drive the car as-is for a while while you consider whether you want to perform that ECU swap.
    You might also want to make sure that your brake light switch is actually working, by parking so that you can see the reflection of the rear lights in your rear view mirror, and pressing the brake pedal to test the switch's operation.
