More coolant debate lol
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by #1 Toyota salesman, Jul 16, 2018.
  1. #1 Toyota salesman
    110
    70
    GSP, SC
    Just like to stir the pot
    Look what I just found at Wal-Mart...
  2. Mendel Leisk
    38,720
    Most importantly: what colour is it?
    Interesting, that it's a 1/2 gallon: more in line with what a DIY'r needs, just for topping up. And good price.
    Still, I would stick with the Toyota fluid: you need to buy a full gallon, it's kinda steep (around $25) but you can sleep at night, and eventually you can use it all, with a coolant change.
  3. #1 Toyota salesman
    110
    70
    GSP, SC
    Red, I would assume...look at the label...the background is red, like the dex cool bottle
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Saw that. I would use it except I already/still have a lot of the old concentrated stuff.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,228
    5,912
    Columbia, SC
    One gallon sizes available also for about $15.
    From website:
    About This Item
    We aim to show you accurate product information. Manufacturers, suppliers and others provide what you see here, and we have not verified it.
    Prestone 50/50 Prediluted Antifreeze/Coolant for Toyota vehicles is specially formulated for use in Toyota, Lexus, and Scion vehicles**. Prestone, the #1 Branded Engine Protection*, fights the spread of corrosion, helping a vehicles cooling system run more efficiently and last longer. Prestone Antifreeze/Coolant for Toyota Vehicles will not void warranty, works with ANY color antifreeze and is compatible with Asian-based POAT technologies. Prestone provides protection up to 5 years or 150,000 miles when flushed and filled per manufacturers recommendations.
    a. * Prestone is the number one selling antifreeze/coolant brand in North America.
    b. ** Toyota, Lexus, and Scion are registered trademarks of Toyota Motor Corporation.
    • Specially formulated for your Toyota/Lexus vehicle
    • Conveniently packaged in a 1/2 gallon container
    • Trusted Prestone quality
    • Will not void manufacturer warranty
    • Fights spread of corrosion
    • Fluid color = Red
  6. Mendel Leisk
    38,720
    Yeah I'm thinking Canadian dollars at the dealership, worst case lol.
  7. #1 Toyota salesman
    110
    70
    GSP, SC
    I'm assuming the one gallon is concentrate? Otherwise cheaper by the 1/2gal
    If it's concentrated for $15, pick it up Jim, when you see it again, I'll come get it from you and try it out.
  8. JC91006
    16,482
    8,400
    Toyota has Red Long Life Coolant and Pink Super Long Life Coolant. They are not the same but they will work with your Toyota.
    Pink last much longer
  9. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Thank you for this information. Even if you use distilled water? Curious as to why....
  10. #1 Toyota salesman
    110
    70
    GSP, SC
    Yeah, I'm aware...I like to try the unconventional
    There are people on here, who have you think that any non- OE fluid is highly combustible, and your engine will suddenly burst into flames and your car will melt to the ground, if you don't use Toyota WS transmission fluid, etc LOL
    bobodaclown likes this.
  11. JC91006
    16,482
    8,400
    From memory, I believe the Red Concentrate is good for 30,000 miles vs Pink 50/50 is good for 50,000 miles.
    I think the Red formula came out first and then the pink stuff. The initial pink coolant fill from the factory is good for 100K+ miles, just the drain and fill is reduced to 50,000. They kept the red coolant for the older cars that want to use it.
    I think the reduction is because you cannot drain every drop from you car, so the remaining coolant gets diluted/mixed and needs to be changed out quicker than the original fill from the factory
    #11 JC91006, Jul 16, 2018
    Mendel Leisk, jzchen and ITBland like this.
  12. Mendel Leisk
    38,720
    Maybe too whatever is prone to go "off", say internal corrosion of coolant passages, is slower on a brand new engine. Who knows.
