More Details on Active Grille Shutters (Video)
Discussion in 'Prime Technical Discussion' started by Tideland Prius, Oct 26, 2017.
  1. Tideland Prius
    16,683
    Posted this in the Gen 4 section but I'm not sure how many of you wander over there (should be more cross browsing since they are share a number of things) but just in case you don't, here's an interesting video.
    LightningBolt, iplug, jpep11 and 5 others like this.
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Does the Prime actually have the active shutters? I looked when we picked ours up and didn't see them, and I don't see any mention in the owner's manual of them (thankfully I have a PDF version I could search through rather than having to read through the whole thing!).
  3. Prodigyplace
    12,720
    11,852
    Central Virginia
    Do you still have the 2015 Prius?
    Please update your user profile.
  4. Tideland Prius
    16,683
    I thought it did.
    I don't see active grille shutters mentioned in the 2016 Prius owner's manual either.
  5. Mark57
    2,945
    2,740
    OK
    From the 2017 Prime Technical Handout page 4.
  6. Tideland Prius
    16,683
  7. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Prodigyplace likes this.
  8. walterm
    466
    202
    34
    2022 Prius Prime
    Yes, the 2015 is mine - the 2017 Prime is my wife's (she lets me drive it once in a while....). She's not a PriusChat member, I just relay messages of interest to her.
  9. Macguru
    Macguru New Member
    The Villages, FL
    Where did you get the center caps?
  10. Prodigyplace
    12,720
    11,852
    Central Virginia
    BTW, that is only part of the story. See
    Prius Caught on Fire | PriusChat
    The user has not told us the results of the official investigation. The winter mode may explain what happened.
    1. Dealer gets Prius in winter mode and notices shutters do not fully close.
    2. Dealer installs EBH (engine block heater) with power cable routed through the shutters, since they do not fully close.
    3. Shutter close warning when weather heats up. Cable is rerouted to clear the error.
    4. Prius catches fire and the cause appears to be the EBH power cable.
    Other equipment in the garage suffered smoke damage. Fortunately, nobody was injured. Since the user has been gone for many months, I suspect they purchased a different vehicle.
    If my theory is true, then Toyota US (@Prius Team ) needs to be more diligent in dealer training. Vehicles & lives could be at stake.
  11. Mark57
    2,945
    2,740
    OK
    Part Number: 42603-52170
    from Amazon
