More on Regeneration in EV mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by giora, Sep 3, 2010.
  1. Snake
    Snake New Member
    89
    Hey! That's a good point. It would also make those out of warranty have an easier time replacing missing parts... but I think either way Toyota wins.
  2. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Please refer to the following official numbers.
    TOYOTA: News Releases > TMC Introduces 'Prius Plug-in Hybrid' into Key Markets
    battery capacity: 5.2 kWh
    battery consumption: 3.56 kWh
    Then, it uses 68% window.
    Ken@Japan
    2 people like this.
  3. pEEf
    pEEf Engineer - EV nut
    720
    580
    Berkeley, CA
    FYI, I was able to get the whole page with the specs. Interesting read!
    4 people like this.
  4. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    "Battery charging power consumption" of 3.56kWh is, I assume, what you get on your electicity bill, allowing for 10-12% charging losses you get to my numbers.
    60% or 68% does not matter, what matters is that Toyota feels confident enough with the Lithium-ion battery to increase the window considerably.
    Giora.
  5. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I don't know how the charging loss was affected, but Toyota specification says as follows;
    Electricity efficiency: 6.57 km/kWh
    Electric vehicle mode cruising range: 23.4 km
    It consumes exactly 3.56 kWh for the 23.4 km drive.
    It is still exactly 68% window.
    Ken@Japan
  6. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Sorry Ken, you have not convinced me...
    The "Electricity efficiency" of 6.57 km/kWh means that (under Japan test cycle) you invest 1 kWh and get 6.57 km. This investment must include charging losses, any other presentation of data will be misleading.
    One can argue whether charging losses are 8% or 12% and we do not know exactly, we do know that charging process is not perfect and has losses.
    Giora.
  7. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I can read...
    Drive battery Capacity: 5.2 kWh
    23.4 / 6.57 = 3.56 kWh consumption
    3.56 / 5.2 = 0.68
    That's all where I can read.
    Ken@Japan
  8. matrix_uam
    matrix_uam Junior Member
    Madrid, Spain
    I think we should analized PHV as part of a new technology research program and not as a market version.
    For those who think that one pack regeneration capability is not enough you should see how larger are these packs vs Prius III packs are. How long we should drive dowhill in order to get a full charged pack by regenerating energy?? I think that in almost 99.9% situations it´s impossible.
    We have to realize that regeneration capabilities are small. We will need more than a hour to get full charged packs by plug-in in order to drive a max. 20kms so by regenerating maybe 4 hours driving downhill..??
    In my opinion the new larger main pack it´s more than enough to increase regeneration capabilities in this car.
    Sorry, I know I should improved my writting english skills
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    I think you greatly underestimate the regen capabilities of your Prius.
    As far as I recall, regen is limited by the battery (about 90-100A if I am not mistaken) MG2 as a generator can supply more.
    Twice a week, I am going downhill (850m elevation difference) with my Prius gen3, starting with two bars on the battery meter I find myself with "full" 8 bars half way down and go to "B" mode rest of the downhill drive to minimize friction braking.
    Giora.
  10. pEEf
    720
    580
    Berkeley, CA
    Regen is limited to about ~20kw due to the hardware limitations of the boost converter. Any more than this would also likely result in high loss in the battery (and thus high heat).
    MG2 could generate about 50kw without any problems however, but there's no where to put it.
    The question is, did they upgrade the boost converter in the PHEV? If they did, which would be sensible to allow better EV mode acceleration, then regen would technically be enhanced to similar levels if they wished to allow it.
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    It is Gen2 number, and the Gen3 has more capability.
    Ken@Japan
  12. masini
    masini New Member
    It is true but for now, Gen 2 it is good for us. That is only my opinion.
  13. pEEf
    720
    580
    Berkeley, CA
    Ken, do you know what the Gen III can do? (kW)
  14. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I don't have regen (charge) number, but the discharge number is 25kW on Gen2 and 27kW on Gen3.
    Ken@Japan
  15. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
  16. pEEf
    720
    580
    Berkeley, CA
    Yes, you can peak numbers like that, but the average maximum is about 20kw. (gen II)
    You wouldn't be able to sustain much more than that without popping your 125a battery fuse in any event, so that is your ultimate limitation.
