more questions - charging in rain? topping off? saving EV?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by the_chinadian, Nov 16, 2012.
  1. markabele
    5,084
    1,782
    Nebraska
    Huh? What's the point of having a plug in then?
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    The point I was trying to make, was not to add any additional charging cycles more than necessary.
  3. markabele
    5,084
    1,782
    Nebraska
    Make sure to shift into neutral before you brake then so you don't get any regen.
  4. GregP507
    3,002
    481
    Thanks for the suggestion, but I'm not about trading all fuel economy for longer battery life. Topping up excessively not only degrades the battery faster, but it shortens the life of the charging cable, and contributes very little to fuel economy.
    Sarcasm noted.
  5. markabele
    5,084
    1,782
    Nebraska
    You are using terms that could mean a lot of different things. Maybe we should define "excessively?"
    And lol to "shortens the life of the charging cable."
    Another ambiguous statement: "contributes very little to fuel economy" Please explain.
  6. GregP507
    3,002
    481
    I don't think you need scientific data to make the assumption that using the cable twice as much will make it last half as long.
    If I plug in with 75% of my EV range left, instead of plugging in when it reaches zero, I will have plugged in 4 times more than necessary to achieve the same effect.
    "Excessive" or "unnecessary," take your pick.
  7. markabele
    5,084
    1,782
    Nebraska
    I personally don't get this one man. Spending a dollar to save a dime.
  8. GregP507
    3,002
    481
    Where am I spending more? Have I confused you somehow? I can't imagine how I could make it simpler.
  9. markabele
    5,084
    1,782
    Nebraska
    Burning gas when you could be using electricity. That has a very fixed amount you save every time. Using the plug each time has a very indefinite amount (and probably very small) that it costs you each time via wear and tear.
  10. GregP507
    3,002
    481
    How does topping up use less gasoline than letting the EV range hit zero before plugging in?
  11. markabele
    5,084
    1,782
    Nebraska
    haha - with that one I have to be done...clearly no use in arguing with you if you just asked that question
    JBumps likes this.
  12. GregP507
    3,002
    481
    Off you go laughing then, but I fail to see where you successfully supported your arguments or refuted mine.
  13. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    You do realize that regenerative braking is far harder on the battery on a regular basis than frequently charging it during the day? Anywhere from 4 to 20 times what we can draw from the wall.
  14. GregP507
    3,002
    481
    I wasn't talking about charging current, I was referring to the number of charging cycles. Both affect battery life, but at least I have some control over the number of times I plug in.
  15. devprius
    devprius /dev/geek
    979
    291
    Are you disagreeing with me, or the OP? Like you, I also have an outdoor hard-wired EVSE that is exposed to the elements all the time (no snow, though, just rain) and never had a problem.
  16. GregP507
    3,002
    481
    Personally, I'd put the charging cable in some sort of shelter in such a case. Keeping it out sun and rain is never a bad idea.
  17. CharlesH
    2,796
    1,163
    Roseville, CA
    As I understand it, the recharging limitations with LiIon are the number of FULL charging cycles; that is, there is no essentially no difference between going from 23% SOC to 85% SOC once, and going from 23% to 54% SOC twice.
    markabele likes this.
  18. GregP507
    3,002
    481
    According to the Tesla FAQ, high-amperage charging has absolutely no effect on battery life.
  19. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    I thought they did say it affects slightly but i cannot remember where. And Tesla Li-Ion is slightly different make up of toyotas, not sure how much(if any) it will affect the end result
  20. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I have two answers:
    The connector at the car is extremely safe, there are rigorous protocols to keep you safe.
    The connector at the wall is not safer than any other 120 volt plug. If this outlet is in the rain, you are only protected at all if you are protected by a GFCI outlet where you plug in.
