more questions - charging in rain? topping off? saving EV?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by the_chinadian, Nov 16, 2012.
  1. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    A Tesla fast charge still takes over an hour, and none of these cars has one battery, it’s a bank of many, many batteries. So maybe an individual battery isn’t being charged much faster than a Prius charges an individual battery.
  2. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    You're replying to a post from 2012 :)
  3. QuantumFireball
    420
    269
    Ireland
    Your Prius has two batteries - the 12V battery, and the HV traction batteries. The traction battery contains many blocks, which contain many cells. Not many batteries.
    Your typical AA "battery" is really a single cell, and calling it a "battery" is a bit of a misnomer, as technically it needs to be multiple cells to be a "battery".
  4. Rebound
    3,995
    2,643
    Portland, OR
    What-ever
  5. Dimitrij
    Dimitrij Active Member
    405
    202
    Virginia
    I don't believe there is evidence that topping off the battery reduces its lifespan or efficiency. You don't get either fully charged battery when the indicator says 100%, nor completely empty battery @ 0% - I believe the safety margin is around 20% on both ends.
    I don't know about the Prius, but the Bolt manual tells you to keep the car plugged in very cold weather, and I don't recall it recommending not to keep it plugged in any context.
    Regarding charging in bad weather: if in doubt, the best thing would be is to ask the manufacturer the same question.
