Mornings getting colder
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bobzchemist, Nov 11, 2016.
Tags:
  1. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    ICE can't run without spark, pulling the ignition coils will prevent spark. Should be able to drive without the ICE kicking on and wasting gas. It'll probably throw a check engine light, but who cares? They do seem rather buried down in there, so if you were going to constantly be taking them off and putting them back on you may want to come up with something else (a kill switch maybe?) but if you are really worried about the ICE running for such a short period of time this would stop it.
  2. Mendel Leisk
    42,330
    To completely pull out 3rd gen coils, you need to remove wipers, wiper motors and bottom-of-windshield cowl. Fourth gen, probably worse.
  3. MrMischief
    426
    443
    Denver CO
    first time, maybe. All you need is to pull the connector off of each coil pack. Looks like once you got the plastic out of the way and safely stored in your garage you could reach in and unclip or clip all four. They seem to be held close enough on their own you won't even need to label them to sort out which goes where.
    52,827
    i wonder if danny sells the block heater in the priuschat shoppe?
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Man I hope this is totally TIC.
    :eek:
  6. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
  7. Mendel Leisk
    42,330
    I toyed with the idea, with a previous car, but went with block heater. Both have benefits, but I think block heaters (coolant heater) have caught on much more, maybe more effective.
  8. FinToy
    FinToy Active Member
    145
    141
    Finland
  9. bisco
    52,827
    thank you!(y)
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    FYI there was an electronic hack that was quite popular for Gen2 and lesser extent Gen3 to minimize the warm-up MPG hit. Search on "Thermistor hack" if I recall.
    Prius is a 50-state car which means we all have California cars, so the Prius is going to jump thru hoops to meet the CARB start-up emissions.
  11. Gshadow325
    Gshadow325 Junior Member
    If you're in Atlanta area I can probably install one for you for less than the cost of the OEM part.
    ONEPLUS A3000 ?
  12. FinToy
    145
    141
    Finland
    If you need help finding heating accessories I might be able to help you. My country is far north and we have these heater kits preinstalled in most of the new cars sold here. Just ask. Sending stuff is quite expensive, Finnish post is costly but if you just cannot find the equipment anywhere else that might be the only choice.
  13. bobzchemist
    507
    342
    That sounds like a good deal, but do you mean the remote starter or the block heater? The OEM remote starter costs nearly $300, which is too much by itself, let alone installed. If I was going to install a remote starter, it would have to be something much, much cheaper, like the Fortin EVO-ALL.
    I'm in Kennesaw, just north of Marietta. I'd be happy to travel anywhere in the Atlanta area to get a block heater installed.
  14. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    That happens if you have the heater turned on. The engine has to run to warm the coolant which the heater uses to warm the cabin.
    Instead, set the heater to MIN and warm yourself using the (electric) seat heater. If the windshield starts to fog, turn on the (electric) rear defroster and blow cold air on the windshield (defrost vents) and turn on the AC. This will direct dry air onto the windshield which will defrost it.
    And that's how you drive in the cold without your ICE starting up.
  15. ssdesigner
    ssdesigner Active Member
    304
    241
    california
    2013 Aqua
    It happens with or without the heater turned on. In my case, I always have it off. Windows are just starting to fog as I pull into work, but the ICE always fires up regardless.
  16. Mendel Leisk
    42,330
    Rebounds in a PIP.
  17. Rebound
    3,996
    2,645
    Portland, OR
    The climate control temperature must be set to MIN. And you have to drive a PiP. Yeah.
  18. FinToy
    145
    141
    Finland
    OK, I now see that we're talking about totally different temperatures here. The AC stops working when the temp drops to +5C (41F?) and we're having here temps like -30C (-22F) so there's no use for AC and we MUST use the heater also. That's why the engine block heater and interior heater are a "must have" in my country.
    Prodigyplace and Rebound like this.
  19. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    I found these two posts fascinating when put together. So in the far north, the block heater is raising the coolant temp up to about 0C / 32F, right? And the oil in the pan isn't being directly heated at all. So "stone cold start up" is something well below freezing.
    Here in MA, we get maybe a couple weeks where the morning temperature is in the 0 to 10F range, and the engine warms up past 32F probably by the time I've backed out of the driveway, so it's not spending much time at all in such cold conditions. After driving half a mile, I have to accelerate up a moderately steep hill and the heater comes on strong at that point :)
    I've only experienced trying to start a car at -25F once in my life, and first had to bring the (practically new) battery into the hotel room to let it defrost before the car would crank. When it did start, it was only on a couple cylinders and made some horrific noises. Yeah, a block heater is definitely needed at those temperatures. Any colder and I don't know how you even get the fuel to vaporize.
