Most compatible Bluetooth OBDII unit to buy for 2008 Prius UK
Discussion in 'Gen 2 Prius Technical Discussion' started by Data Daedalus, Feb 16, 2014.
  1. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    What is the best (as in most compatible, reliable) Bluetooth OBDII unit to buy for my 2008 Prius T Spirit? I have both a Nexus 7 and Dell Streak 5 Android devices either of which I'd like to use in the car with Torque Pro installed on them.
    There's so many choices out there - and apparently quite a few non kosher clones too. I want the real deal / the most compatible there is.
    Advice will be appreciated :)
    iPad ? HD
  2. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    OBDLink MX
  3. FreydNot
    FreydNot Member
    210
    37
    Seattle, WA USA
    I've never has a problem with my PLX Devices Kiwi Bluetooth adapter. I guess I would call it the gold standard. However, it also costs a lot of gold.
  4. Data Daedalus
    1,022
    1,183
    Wembley, London
    Thank you both :). I've checked out the OBDLink MX; the reviews praise it to the heavens. It's allegedly 5 times better than the average Bluetooth adapter - and correspondingly costs about 5 times as much. I'm very tempted indeed. I'll go check out the PLX Devices Kiwi BT adapter too. Thank you!! :D
    Nexus 7 ?
