Most Compatible Bluetooth Phone
Discussion in 'Gen 2 Prius Audio and Electronics' started by macreative, Sep 21, 2004.
  1. Sony-Ericsson T610 or T616
    0 vote(s)
    0.0%
  2. Motorola V600
    0 vote(s)
    0.0%
  3. Siemens Phones
    0 vote(s)
    0.0%
  4. Other Bluetooth Phones
    100.0%
  1. kkister1492
    kkister1492 New Member
    355
    Fremont, CA
    I have the RAZR and love it. It rings through the speakers, sound quality is great, easy to use. I highly recommend it!
  2. larkinmj
    larkinmj New Member
    1,996
    I have a Motorola mpx220 and it works great with the Prius. I use Auto Phone Ripper to merge my contacts into one file, then upload that file via Bluetooth whenever I need to update the car's phonebook. A lot easier that beaming one contact at a time.
  3. geminione00
    geminione00 New Member
    Motorolas with bluetooth are very compatible with the Prius. Well, in my case, with the PEBL, cousin to the RAZR. I think SLVR, also, a cousin of the Razr, works well with the Prius. From what I can remember from a different thread.
    If you want a phone with good sound quality, no pauses between people talking over one another and actual ringing through the speakers, go with either these three phones. You won't regret it.
  4. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    I just picked up a PEBL (T-Mobile), and it works great... except...
    It will not automatically connect when I turn the car on. I have to manually turn Bluetooth on using the phone menu, and then it connects to the car. My old V600 connected flawlessly every time.
    I'm sure that there's some setting that I'm missing, but darned if I can find it. I have "Auto Hansfree" set to "On," but no go.
    Any hints are greatly appreciated! I love the phone (and the car, too, of course!) but this is really annoying.
    [ed.] -- never mind! I messed around and found the answer. Thanks anyway!
  5. AndyGB
    AndyGB New Member
    <div class='quotetop'>QUOTE(jabecker @ Mar 6 2006, 08:46 PM) [snapback]221390[/snapback]</div>
    Hi there,
    I'm the happy owner of a brand new Prius T-Spirit and am having that same problem with my Motorola PEBL; what trick did you discover to make it auto-connect to the car?
    Thanks for any advice!
    Andy
  6. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    :D Motorola Q on Verizon...... works great, transfers phone book just fine, and has every extra feature anyone could ask for on a smart phone. :D
  7. suzieyoga
    suzieyoga Junior Member
    <div class='quotetop'>QUOTE(kkister1492 @ Feb 17 2006, 11:26 PM) [snapback]211410[/snapback]</div>
    although your post is old we have the same pri and the same package and the same phone. others say that if i update the razr I'll be able to upload my entire addressbook in one fell swoop. What have you done? I will not enter each number individually.
    Also, the sound quality is unreliable. I get more complaints then compliments on sound.
  8. cindyslove
    cindyslove New Member
    I have a BlackBerry 8100 T-Mobile and was able to download address book and use - bluetooth drain is higher than I expected but other than that I love it.
  9. larkinmj
    larkinmj New Member
    1,996
    <div class='quotetop'>QUOTE(larkinmj @ Feb 25 2006, 03:49 PM) [snapback]216515[/snapback]</div>
    Last fall I replaced the Motorola with a Cingular 3125 Windows Smartphone. Works great also.
  10. alkarajo.com
    alkarajo.com New Member
    Can you share with us what the answer was? I have the same problem.
    Thanks.
    Thanks.
  11. pkittie
    pkittie Junior Member
    50
    LaLa Land
    I have a Blackberry 8100/T Mobile. No problems. But am waiting for the 8800 (with camera)...
  12. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I have a Samsung T519/Trace from tmobile, It works great! the only thing it doesn't do is, show the signal strength or the battery life on the Prius screen.
    My boyfriend has the Samsung T509 and it works well also.
    One thing Toyota should have done is have the Bluetooth system 'prioritize' phones that way you don't have to keep selecting phones when you get in and out of the car.
  13. o2cool
    o2cool o2cool
    48
    Palo Alto, CA
    <div class='quotetop'>QUOTE(Vegas Prius! @ Feb 17 2006, 02:18 AM) [snapback]210991[/snapback]</div>
    I have a Treo 650 and a 2006 Prius, and the Treo does not work at all with the Prius. I called Palm (mfr of Treo) and they said that they are not compatible. They suggested that I get a Treo 700. My Treo is from Verizon, but I would not think that it should make a difference. Any suggestions?
  14. RobertG
    RobertG New Member
    166
    Northern California
    <div class='quotetop'>QUOTE(o2cool @ Mar 28 2007, 12:42 PM) [snapback]413687[/snapback]</div>
    I have the same situation, a 2006 Prius and a Treo 650 with service from Verizon Wireless. The Treo worked okay at first, once I learned here at this forum that I needed to make a call on the Treo 650 to have the connection setup with the Prius finalized. For one reason or another, I deleted the phone and now it does not work. I will get notice that the Bluetooth connection was successful, but the phone won't be available literally seconds after I see that successful connection message.
  15. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(macreative @ Sep 25 2004, 01:33 PM) [snapback]41654[/snapback]</div>
    I have a 2005, so I can't enter phone numbers manually. I use the Verizon e815 for normal use, but couldn't send the phonebook. I got a used Sony-Ericsson T68i (T-Mobile) off eBay, put the phone numbers in that, and then sent the phonebook to the Prius.
    It paired right away (following the instructions) and was able to send the whole phonebook in one shot.
  16. Bearcatzzz
    Bearcatzzz Junior Member
    97
    <div class='quotetop'>QUOTE(RobertG @ Mar 28 2007, 04:55 PM) [snapback]413842[/snapback]</div>
    Be sure that you have the most current software on your Treo. Until I upgraded I couldn't keep a sucessful connection. Once I upgraded, and worked my way past the lock barrier(this prevents others from hacking into your devices), I made a successful connection. I have had no problem since. Works beautifully.
  17. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Didn't see it mentioned so I thought I would list it. We use PPC-6700's (Sprint or Verizon) in our prius and they connect flawlessly, although as mentioned before the prius will not detect 'which' phone is in the car, so my wife has to manually connect :)
  18. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Rangerdavid @ Mar 22 2007, 04:33 AM) [snapback]410070[/snapback]</div>
    How were you able to transfer the phone book? One at a time or what was the menu command to move the entire phonebook?
  19. MegansPrius
    MegansPrius GoogleMeister, AKA bongokitty
    2,437
    27
    Chicago, IL
    LG 8300 with Verizon. Works great, can transfer phone book 10 entries at a time.
  20. hill
    9,038
    MegansPrius , Does you thread even address which server you're talking about prior to you mentioning you've found 10 at a time entries work on Verizon? Ok, so we're talking Verizon? Yea, Verizon has been successfully sued for their dispicable behavior . . . deliberatly crippling their phones so that for the most part, the O.P.P. function (pushing your directory into the Prius) is disabled.
