Most decent way to run your 115V essentials out of Prius Prime
Discussion in 'Prime Technical Discussion' started by Krzysiek_KTA, Jun 7, 2020.
  1. fuzzy1
    10,402
    In Liftbacks, it is worse than that -- when in N, it can't even start the engine. So this inverter arrangement could simply keep draining the traction battery so low that it is unable to start the engine even when the operator later shifts to P.
    This why a Liftback driver must not coast down steep hills in N with the engine not spinning. Above a certain speed, the engine must be spinning to prevent overspeed damage to MG1, but the engine can't be started up in N, as all the MG fields are disabled.
    And this MG-disabling N mode is a safety feature for other reasons, so I don't expect it to go away.
    It would be a bit of a bummer if there is no override of that auto-shutdown. Earlier LIftbacks can operate continuously as backup power sources, for days, no driving breaks required. Though with much smaller traction batteries, the engine must cycle On and Off much more frequently.
    #21 fuzzy1, Jun 8, 2020
    Salamander_King likes this.
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,946
    New England
    Well, I am currently testing my PRIME to see if such auto-shutdown feature exist. My 2020 PRIME LE has been parked for over two weeks now and I have not had chance to use the traction battery, but the 12v battery is continuing to drain. It would be a good opportunity to use the traction battery to charge-up the 12v battery without driving. So far, 2 hours, the car has not shut down. It is just sitting PARK enabled in READY. No A/C and no lights or radio. With minimal load on 12v battery the traction battery is nicely charging the 12v battery at 14.1v for the last 2 hours.
    I am not sure why the OP's PRIME is shutting off after 30-40min on P in READY. It maybe due to heavy load on 12v from the inverter attached, but I honestly don't know.
    #22 Salamander_King, Jun 8, 2020
  3. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    [QUOTE="Salamander_King, post:
    I am not sure why the OP's PRIME is shutting off after 30-40min on P in READY. It maybe due to heavy load on 12v from the inverter attached, but I honestly don't know.[/QUOTE]
    I left my Prime fully charged in "P" mode last night in garage without inverter connected. When I checked it out this morning the car was off. Maybe it is related to "EV" mode as default?
    I have not tried leaving my Prime in "P" mode while not in EV mode.
    I am doing another test as we speak. Thx for feedback!
  4. fuzzy1
    10,402
    Did something here change with the Prime's 2020 refresh? I seem to be vaguely remembering something related to this auto-shutdown, but not with enough detail to track it down.
    Krzysiek has the original 2017, while Salamander has the refreshed 2020, so this might account for some differences.
    Salamander_King and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    Again, you're a few minutes ahead of me. LOL!
    Do 2020 models have auto engine shut-off? | PriusChat
    (Google search is much better than the forum software's search. :whistle:)
  6. Salamander_King
    11,016
    8,946
    New England
    While that thread is about auto engine shut-off, there is a relevant comment there for auto hybrid system shut off with a quote presumably from the manual. But I can't find this in either 2017 or 2020 PRIME manuals. So I don't know what vehicle this "Automatic hybrid system shut off feature" applies. I feeling is it only applies to 2020 Gen4 Prius AWDe.
    Edit: OK, I downloaded 2019 and 2020 Prius owner's manuals. I found above quote ONLY in 2020 Prius owner's manual (this include AWDe, but applies to all models of non-plug-in Prius). There is no mentioning of "Automatic hybrid system shut off feature" in 2017 PRIME, 2020 PRIME and 2019 Prius owner's manual. So, this seems to be a new feature added to 2020 Prius models, but not to PRIME.
    This makes so bizarre that OP's 2017 PRIME is somehow having this feature, but not my 2020 PRIME.
    #26 Salamander_King, Jun 8, 2020
    jerrymildred likes this.
  7. Krzysiek_KTA
    159
    125
    Houston
    This makes so bizarre that OP's 2017 PRIME is somehow having this feature, but not my 2020 PRIME.[/QUOTE]
    My test of leaving my 2017 Prime in "P" mode is going on.. 3 hrs and the car in"P" remains on (full traction battery at the beginning), but this time I left the FOB inside the car. I guess that might be the difference. Prime works on with FOB detected, otherwise it shuts down... I guess.
    Just another 5 cents from me.
  8. Salamander_King
    11,016
    8,946
    New England
    That might be the difference. Yes, PRIME will detect fob not being inside of the car and warning will come on the MID. Maybe without fob, it forces the undocumented automatic hybrid system shut off. I had my fob inside for my testing. I can try removing the fob and see what happens.
  9. Krzysiek_KTA
    159
    125
    Houston
    With FOB inside and Prime in "P" for over 6 hrs (no inverter connected) the car was was still on. Then I took out FOB. After after several minutes the following popped up on the dashboard along warning sign:
    "HYBRID SYSTEM STOPPED, POWER STEERING LOW"
    Then I left the car on like this and after 40 minutes the car shut down.
    There might be something going on with my particular car ?_?
    BTW. After 8+ hrs testing Prime in "P" the displayed range dropped from 30 miles to 22 miles.... (no inverter connected, no A/C, no lights etc.. on neither) .. strange.
    The other day I run Prime with 1000W inverter(running 250-750W loads) connected for over 9 hrs in "N" and the traction battery was depleted from 31 to 17 miles of range...
    I will stick to keeping car in "N" for long inverter loads since there were no warnings and no shut downs in that mode. Maybe will try "P" with FOB inside if tired of exiting via passenger door... :)
    Thanks for all your feedback!. I think I am ready for hurricane season here in Houston. Cheers!
    #29 Krzysiek_KTA, Jun 8, 2020
  10. fuzzy1
    10,402
    In a Gen3 Liftback, the power steering warn is an indirect indication that the gas tank has run dry, ICE has stopped, and the traction battery is getting too low. The Prime may have other or additional causes for this warning.
    [WARNING] Running out of gas (Gen III) | PriusChat
    I suggest that you be very careful about "N" gear, be damn sure that the electric range is never allowed to drop to 0 miles. Such cases are where "P" ought to be a better and safer mode than "N".
  11. Salamander_King
    11,016
    8,946
    New England
    I have a feeling there is something going on with your car. Is your 12v battery healthy? After ~4 hours on P and Ready with a fob inside, I removed my fob. I get the warning on MID "Key not Detected Check Key Location". The car beeps when I exit from the driverside, but that's it. The car was on P and READY for another 3.5 hours without any other warning or the car shutting itself off. After 7.5 hours on P and READY, I turned it off. The traction SoC was reduced from 98% to 74%. But my 12v battery was charged up from 12.62v to 12.97v. The graph shows the 12v battery voltage monitored by the battery monitor. During the entire 7.5 hours, the DC-DC inverter was charging the 12v battery at ~14v, it never stopped at any time.
    #31 Salamander_King, Jun 8, 2020
    fuzzy1 likes this.
  12. Krzysiek_KTA
    159
    125
    Houston
    Really?
    I would say be careful with "P" gear mode for prolonged times - see below.
    I did some prolonged "P" tests (without inverter load) and I can confirm that in "P" Prius Prime DO NOT charge 12 V battery ( at least not with full current) - at least in my Prime...
    I just luckily checked my car after it shut down after I took my FOB out and found that 12V LOW BATTERY warning on the dashboard and all lights flickering inside and head display disabled. I could not start the car neither.. ( say it was left in "P" mode for 11-12 hrs+)
    Luckily I managed to plug in the car and force it to "charge it now" mode. Note that Traction Battery was at 20 miles range at that time.
    To my understanding how I see it my Prius Prime does not charge 12V battery in "P" mode.That is it (at least for my case).
    To my surprise the "N" mode in my Prime is much more like normal "N" in any car. I will stick to that.
    I do believe what I see and experience.
    Cheers!
    #32 Krzysiek_KTA, Jun 8, 2020
  13. Krzysiek_KTA
    159
    125
    Houston
    You might be right.
    Thx for shared data
    I did not experience anything wrong until I run the car in"P" for over 12 hrs or so (without inverter load). Strangely enough in "N" mode with Inverter connected there was no issues at all with drawing 25-750W out of my 12V battery. Let me do some more trials and share feedback. Will see..
    To the hour it seems that My Prius Prime is not sufficiently charging the 12 V battery in "P" (at least fat full rate), but indeed it does in "N".
    I it weird or it is standard for EV and plug - ins? (My Chevy Bolt don't charge 12V in "P" only "N" works sustainably for me)
    just a thought to share...
    It seems that Prime is quite different from other Prius hybrids like Gen 4 as it is Plug-in vehicle...(at least my specimen. LoL)
    Thx for support
    Much appreciated!
    #33 Krzysiek_KTA, Jun 8, 2020
  14. Salamander_King
    11,016
    8,946
    New England
    I now think there is definitely something wrong with your car. PRIME certainly charge 12v on P and READY. On the contrary, I have shown charging the traction battery by connecting to the EVSE does not charge the 12v battery. So, if your 12v battery was depleted while you had your car in P and READY, the first thing you have to do is to check your 12v battery and charge it with an external charger. Still, I think your 12v battery is not healthy. That may explain bizarre warnings and strange behavior you are seeing on your PRIME. If I were you I would not use the inverter until I know 12v battery is in good condition, regardless of shift position. But I would never try using any inverter on the "N" position in my car.
    Hicksite, jerrymildred and fuzzy1 like this.
  15. fuzzy1
    10,402
    In other Prius models and generations, the 12V is charged all the time the car is "READY", regardless of gear mode. But while the ICE can charge the traction battery in "P" and all moving gears, it cannot charge that big battery when in "N", so there is a risk of running it very low.
    It will eventually shut off the hybrid system to protect the traction battery from complete depletion, saving it from inverters tied to the 12V bus, but then the 12V gets drained. And the car will not protect itself from inverters tied directly to the traction battery, as certain users do (with different equipment) for higher power capacity.
    I'm trying to follow what differences the Prime has from other models, and trying to think of how something might be odd about your setup.
  16. Krzysiek_KTA
    159
    125
    Houston
    Thanks a Lot! I will certainly check my Prius Prime out. And stick to what I know works for my purposes. Thanks again for your input!
    #36 Krzysiek_KTA, Jun 8, 2020
  17. Krzysiek_KTA
    159
    125
    Houston
    #37 Krzysiek_KTA, Jun 8, 2020
  18. jerrymildred
    11,517
    14,147
    Tampa, FL
    Something weird is going on for sure. I have a volt meter plugged into the 12V outlet between the seats. When I start the car, it briefly displays a 12.X volt reading (maybe for a half second) until the DC/DC converter wakes up Then it jumps to 14.x. Car is still in park at this point and is obviously charging the 12V. As the charge level in the 12V increases, the displayed voltage will drop to a maintenance voltage just north or south of 13.0V. It's no longer charging the 12V because the 12V is already charged; it's just maintaining that voltage against the load placed on it by the car's systems. (Well, you could say it's letting it discharge a tiny bit and then very lightly charging it back up.)
    It treats the 12V like that in D, B, R, P, and N. However, as repeatedly pointed out here & in the manual, the ICE does not charge the traction battery in N because that would require spinning one of the motor/generators to generate charge current and that would make the car move, which wouldn't be very Neutral.
    So, looking at the voltage of the 12V won't be a reliable indication of whether the car is charging anything because it might not need charging at the moment. But looking at the gear position is a 100% reliable indication of whether the car will charge the traction battery if the traction battery needs to be charged. It's easy to verify by using up the EV range, leaving it in Neutral, and watching the energy flow monitor on either display. You'll see it leaving the traction battery and not flowing from the ICE to the battery.
    Hicksite likes this.
  19. Krzysiek_KTA
    159
    125
    Houston
    Indeed it is weird.
    I fully charged the car and left the it in "P" READY for several hours the other day without any electrical loads
    and 12V baterry got depleted (see my previous posts) despite the traction battery was at 70% charged at the end.
    On the other hand I run 1000W inverter for 9hrs having Prime in "N" without any issues.
    BTW my inverter has Power draw/delivery display and I observed exact same behavior of battery voltage as above both in "P" and in "N" mode.
    One thing is for sure. To keep Prius Prime on the FOB needs to be inside, Otherwise the car will shut in in 20 min regardless of gear/mode it is.
  20. jerrymildred
    11,517
    14,147
    Tampa, FL
    Better get that thing to a dealer then. Here's my aux battery voltage with the car in Park:
    This is to be expected. UNTIL the point where the EV range is gone and the engine starts. Then you will have issues because it won't charge the traction battery. Try it, but watch it carefully or it could get very expensive. Note: this is completely unrelated to the charging of the 12V aux battery.
    fuzzy1 likes this.
