Most efficient braking?
Discussion in 'Gen 3 Prius Technical Discussion' started by Joe Z, Oct 24, 2013.
  1. Joe Z
    Joe Z Junior Member
    Hi all. There are frequently situations when you can make a choice about braking. If you can't just coast to a stop you can brake lightly over a long period of time or get closer to the stop point and brake a little harder for a shorter period of time. Assuming no one is behind you, which is more efficient at energy regeneration? How far should the bar go left into the charge zone to accomplish max regeneration efficiency? When, exactly, do the brakes engage - which I assume should be avoided when possible. I know brakes engage at 6mph, but where on the charge indicator bar? Thanks, JoeZ.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I would say that it is better to brake lightly over a longer period of time. If you live in a warmer climate the hard braking results in higher regen braking current and increase in HV battery temperatures.
    The friction brakes engage below 7 mph as you say and that would be when the charge indicator bar is at zero regen.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Watch the white bar on the left of the power display. When it maxes out you are no longer regenerating. In my experience this means very gentle braking over a longer distance. The higher the speed the more gentle you have to be on the brake pedal to stay in the regeneration "zone".
    Just to be very clear, coasting is the most efficient. Braking, at best, is about 50% efficient if you can stay in regeneration. If not it's total loss braking.
    So very conservative driving. Which of course makes other drivers mad. They want to rush up to the red light and wait.
    And that's probably what causes Prius hate. Morons!
    hybridbear likes this.
  4. Former Member 68813
    3,524
    983
    US
    From what I observed, people do that, so they can text while stopped. Some people are so engrossed in it they miss green light change and wait it out entirely. I've seen it myself from a next line!
  5. rcf@eventide.com
    173
    85
    Sedona
    This is a more interesting and complicated question than it seems. In a vacuum (literally!), braking slowly would seem to be the best bet since batteries like a charge at lower Amps and longer times somewhat better. But in the atmosphere, for every second you are travelling at a higher speed more of the car's kinetic energy is being used to heat the atmosphere and less to charge the battery. That would argue that you should brake somewhat more aggressively to get the vehicle speed down to 20 or so mph where there is little air resistance, and put as much of the KE into the battery as you can. Of course, braking too aggressively in that regime is also problematic since it might engage the friction brakes.
    My intuition is that a tautochrone-like braking curve would be pretty efficient and smooth. But try to stop braking at 7mph and let the car coast until the light changes or you finally have to stop.
  6. bwilson4web
    16,535
    I'm a fan of 'pre-emptive' braking if traffic permits. When I see a light that I am likely to have to stop, I brake a little harder to get my speed down to 25 mph and then "N" coast to the end of the line or the light.
    Done correctly, my speed approaching the light or line of cars will be 20-25 mph and the light will change before I have to come to a complete stop. I simply follow the cars or accelerate without having lost that last bit of momentum (i.e., kinetic energy.)
    ksstathead, OzPrius and hybridbear like this.
  7. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    I've heard that, electrically, the most efficient thing to do is to brake moderately strongly, without exceeding the CHG bar; there are some fixed losses in the inverter, and so to minimize the percentage loss, you want to minimize the length of time that you're moving energy through the inverter. (This was from the GII, I believe, but the same should apply to GIII.) Of course, if you exceed the CHG bar, then it's using the friction brakes, and you've lost all your efficiency gains from braking "quickly". I use quotes because even maxing out the CHG bar (especially at high speeds) is still very gentle relative to how many people drive, as others have noted.
  8. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    This is a great question, from a theoretical perspective, but the answer likely has limited practical value. I doubt that the difference between braking that nearly fills the regen display stores, over a short distance, a significantly different level of battery charge than less aggressive braking over a longer distance. Furthermore, undue attention to a dashboard display during braking, in an attempt to store a couple of extra milliamperes, can detract from the reason that you are braking, in the first place. Stating the obvious; the best way to brake is CAREFULLY.
  9. Joe Z
    Joe Z Junior Member
    Thanks for all the replies, guys! Insightful. Agreed that not a lot of practical application, but understanding the way these things work may give you a hand full of things to work on to become habitual, and together they'll make a difference.
    From when I got my 2010 till now my mileage has improved a lot - probably more than 6-8 mpg because of this forum. That's huge!
    Thanks again
    Joe Z
