Most EV miles on one charge?
Discussion in 'Prime Main Forum (2017-2022)' started by MarkOlin, Aug 9, 2021.
  1. MarkOlin
    MarkOlin Member
    78
    39
    Buffalo, NY
    2020 Prius Prime
    Curious on how many EV miles current owners have gotten on one charge.
    For me it's 44 (personal record). Normally its 32-36 miles with no heat or a/c.
    Lots of angry honks and dirty looks to get it.
    #1 MarkOlin, Aug 9, 2021
    TGrracie and lbligh like this.
  2. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    We are looking forward to answering this question, as we explore the capabilities of our new Prime.
  3. Priusmanold
    Priusmanold New Member
    France
    2017 Prius PHV
    Bonjour
    En ce qui me concerne en été j’arrive à faire 48 km. pour 65 affiché au TDB ; et cela en roulant normalement sur route départementales.
    Prius 4 PHV mise en service en octobre 2017
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Without causing a traffic jam behind me, on my 2021 PP, I am currently getting 37-38miles out of a full charge on a good day (meaning no HVAC). With AC on, it averages 34-35miles now. This number, although still a small sample yet, is substantially better than what I was getting on the 2017 PP on a full charge. The average summertime EV range was never that high. It was more like ~32 miles. In wintertime, I was happy if I could get 20 miles out of a full charge with the heater on. I will see how the new 2021 PP will compare to that in Jan and Feb.
    #4 Salamander_King, Aug 9, 2021
  5. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    i've gotten 40....well like 39.7 but close enough :)
  6. Washingtonian
    Washingtonian Senior Member
    726
    621
    Does this imply that there is a mechanical or electrical difference or different battery between the 2017 and the 2021? I use the AC in Summer, don't try to hypermile, and believe the EV miles readout on my HUD. Getting between 30 and 31 miles now; 20 to 24 in the coldest part of the Winter.
  7. mrchowmein
    mrchowmein Member
    73
    56
    San Francisco, California
    2020 Prius Prime
    How fast are you going and is this mostly around town or on the highway?
  8. Trollbait
    12,831
    Could something like a tweak in the software.
    Or nothing at all, and this is just do to the variance between cars, where they are driven, and the driver.
  9. Henrik Helmers
    Henrik Helmers Active Member
    100
    148
    Norway
    2020 Prius PHV
    My best is 70km, which is about 43 miles, but I consider anything above 50km a great success. When using the AC at full power and just pressing the pedal I get around 30km.
    But even that it is enough to let me accomplish most errands on electric power. Which is what I hoped the plug-in would let me do.
  10. Salamander_King
    11,024
    8,980
    New England
    Nothing physical has changed AFAIK, but comparing 2017, 2020, and now 2021 PP I have owned, the 2020 and 2021 are taking more charge from the wall for a full charge session. I suspect that Toyota changed the SoC threshold to be used for EV drive. With the 2017 PP, I was averaging less than 6.5kWh/full charge, but now with the 2021 PP, it often takes more than 6.7kWh/full charge.
    Average ~35mph, top speed ~55mph, all on rolling hills and valleys on rural roads (some state highway, some residential part of town) with relatively light traffic.
    See above. I suspect Toyota changed the SoC threshold used for the EV range. I want to confirm this, but I am having a problem connecting my phone app (Hybrid Assistant) with my 2021 PP. With HA reading, my 2017 PP was consistently using real SoC from 80% to 14%. If they changed this threshold to widen the SoC used for EV range, it explains the >0.2kWh more of charge from the wall and a few more miles of EV range in 2021 PP compared to 2017.
    #10 Salamander_King, Aug 9, 2021
  11. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    When I was commuting I could drive the 39 miles to work in all EV with anywhere from 25% - 38% left, depending on traffic and the stop lights. It was a 1,500 foot net elevation drop over those 39 miles (about 9 inches per 100 feet), but there are intervening hills. It definitely helped, but I don't know if that's even enough slope to get the car rolling on its own.
    One time I got a road rage driver for the opposite reason. I was heading down a hill and already at 100% SOC. I knew I was going to have more regen and didn't want the ICE to kick on, so I jackrabbit started from the light in EV mode to burn up some charge and hopefully make the next light that was getting ready to turn. I guess the guy next to me had planned to race ahead, cut me off, and make a turn right at the next block because about two seconds after I took off from the line I hear his motor go all out. He barely pulls next to me and starts swerving into my lane to threaten me, but I just acted like I didn't see him. He was so focused on me that he didn't see the red light in time to stop, so he ended up running it. Too bad there weren't any cops to see it.
    #11 PiPLosAngeles, Aug 9, 2021
  12. Salamander_King
    11,024
    8,980
    New England
    Yeah, if elevation drop helps, you can drive as long as gravity pulls the car. That can be 100miles on EV if there is such a route in the US. Round trip is always more informative for this reason. My commute is 35.4 miles round trip without any detour, I was able to pull the entire round trip on EV mode only twice in 3 years with the 2017 PP. But with the 2021 PP, I already accomplished this feat, 3 times I drove the same route since I purchased the car a little over a month ago. And I was not even trying.
    dig4dirt likes this.
  13. PiPLosAngeles
    1,551
    724
    I bet you can't go 100 miles on a 0.75% slope in EV with stop and go traffic and stop lights.
  14. Salamander_King
    11,024
    8,980
    New England
    Stop and go is another energy eater for sure. What makes me think my 2021 is getting more EV range than my previous 2017 PP is that we now have one additional stoplight on my routine commuting route which we did not have in 2017. The two times I drove complete round trips on a single charge, I distinctively remember that I was lucky and did not get caught on the red light at all. But last three times on 2021 PP, I did stop at least 2 or 3 more times and still got home without the engine starting.
    #14 Salamander_King, Aug 9, 2021
  15. PiPLosAngeles
    1,551
    724
    Even the 0.75% slope. It's barely a slope. That's a quarter-inch per yard.
  16. fuzzy1
    10,713
    Has anyone tried Truckee to Roseville (80+) or Sacramento? Sierra-At-Tahoe to Folsom (70+) or Sacramento? Absent elevation restrictions, records would go to these types of routes.
    For a Gen3 non-plug-in like mine, that slope is enough to provide a 25% MPG boost even at highway speed. For a newer more efficient model, driven at lower speed on a mountain road, it could provide an even larger percentage boost.
    #16 fuzzy1, Aug 9, 2021
  17. PiPLosAngeles
    1,551
    724
    Just going by potential energy of rolling a Prius down a 1,500-foot slope, it "adds" 1.7 kWh to the trip. So, 25 - 38% left would be about 0 - 10% left after 39 miles on level ground.
  18. PiPLosAngeles
    1,551
    724
    That's a steep enough slope to roll the car in neutral, so it won't take any accelerator to keep moving. That can go on indefinitely as long as there is hill to ride. 0.75% is not enough to coast. If it takes 250 Wh to move a mile on level ground, it will take about 210 W/h to move a mile on a 0.75% slope.
    Records, as it were, should be corrected by subtracting out the potential energy realized by the descent.
  19. Salamander_King
    11,024
    8,980
    New England
    That sounds about right. I was able to drive 35.4 miles on EV and had 6% SoC left on my round-trip commute. Here is the round trip elevation profile of my commuting route. I used a map app for this to route using out and back round trip. For an unknown reason, the profile is not perfectly symmetrical. Maybe the right lane and the left lane have a slight difference in elevation? This is not an interstate highway in which roads in opposite directions are separated by a big median. It's basically two lanes (one lane in each direction) rural roads.
    or same chart but with grades
  20. PiPLosAngeles
    1,551
    724
    It's always more complicated than the net elevation difference because going uphill uses far more energy than is recovered or avoided going downhill. My commute includes 1,100 feet of elevation gain and 2,600 of elevation loss. I would guestimate that the 1,100 feet of climbing nearly wipes out the gains of 2,600 feet of descent.
