Most HV miles per Tank
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, Jun 22, 2014.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes! You are!(y)
  2. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Hmmm, both of those may need some explanation.(n)
  3. El Dobro
    El Dobro A Member
    7,106
    3,282
    My coffee is brisk.
  4. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Brisk is easy to explain.
    Owner commonly make the assumption that using the gas engine means an efficiency penalty. They are unaware that it runs in an optimized manner, taking advantage of having a power-split-device interacting to 2 electric motors and a battery.
    Accelerating with generous pedal will often result in a lot of electricity being generated on-the-fly, the result of the gas engine settling in on a RPM with minimal waste. Some of that electricity is consumed immediately for propulsion power and some goes to recharging the battery. The operation is quite dynamic.
    In other words, the overall MPG is what to consider, not the acceleration itself. Far too often, owners see the power-bar spike and believe that is a bad thing. The design reveals it typically is not.
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    It needs to be pointed out that, contrary to our intuition based on our experience with traditional ICE systems, rapid acceleration to a given speed does not inherently use more energy than accelerating to that same speed at a lower rate. The laws of physics simply state that it takes a certain amount of energy to accelerate a given mass to a given speed. What differs is the efficiency of the power source in the various acceleration scenarios. The power split device is an elegant solution to this problem. The electric motor has a very flat efficiency curve over quite a wide range of RPM. And if power from the ICE is needed, the strategy is to have it running at an RPM where it is most efficient, even if that mean powering a generator to drive an electric motor, or charge the battery.
  6. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Makes sense, thanks John. Driving the PiP really is quite different from driving the standard gas guzzler - very different beasts.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    I guess I'll never really know, I'm a filler upper at two pips lefter.
  8. bisco
    52,877
    i keep my whisk broom in my brisk room.:cool:
  9. retired4999
    2,652
    627
    Eau Claire, Wi.
    :unsure:
  10. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Its really a function of your usage of the car. In my case, being retired, most of my trips are local and short. Over the past 15 months I had three 2-month periods where I made no long trips. My EV miles for those "tanks of gas" have been over 1000 miles and the tanks of gas have been about 4 to 7 gallons. On the other hand when I have gone on longer trips 4 tanks of gas corresponded to less than 100 EV miles each. So asking how many EV miles per tank of gas is sort of like asking "How tall is a tree?" :)
  11. markabele
    5,084
    1,782
    Nebraska
    Would love to see some more numbers so we can get some more people on our list in the first post. :)
  12. bisco
    52,877
  13. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    I am surprise to see only 500, 600 miles range, I thought most of you are running on EV and will get way more than that. I get 600 miles plus easy with only one charge per day and drive about 40 miles. Probably get over 700 miles if I dare to push that blinking fuel light a little.. ;)
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    Yes, but the OP is asking how many miles in HV only. ;)
  15. bisco
    52,877
    exactly, LA, you are misunderstanding the premise. if you want to know total miles per tank, start a new thread, or there may be an existing one.
  16. markabele
    5,084
    1,782
    Nebraska
    I am extremely surprised we aren't having more people post numbers. Are people just not keeping records? Maybe that's it.
  17. LA2014Prius
    103
    2014 Prius Plug-in
    Sorry guys... I am new to Prius, only got it 2 months... IC what this is now... No charging, just use the PIP in hybrid mode, correct?
    The only time I can do this is when I am going on a long trip, like from LA to Vegas... I will do this sometime in the future and let you know.
    #37 LA2014Prius, Jun 26, 2014
  18. GregP507
    GregP507 Senior Member
    3,002
    481
    I managed to get 3.8 L/100 km this morning, (pure HV mode, no plugging in) which is almost 62 MPG. It was all city driving; my regular commute, where 4.2-4.4 is a typical number most days.
    The only thing I may have done differently is that since I was a bit early, I was easier on the accelerator than normal, careful not to let the indicator get into the red "pwr zone" on the HSI.
  19. john1701a
    12,840
    5,312
    58
    There's no reason to red "pwr zone".
    The point of the indicator is to tell you to avoid staying in it for too long. Brief usage will not bring down overall effiicency.
  20. GregP507
    3,002
    481
    Good advice, but it seems logical that if less is good, then none is better.
