Most Obscure Gen 4 Facts (way out there)
Discussion in 'Gen 4 Prius Main Forum' started by That_Prius_Car, Nov 5, 2015.
  1. Prodigyplace
    12,554
    11,773
    Central Virginia
    Actually, my 2017 is strange. With nobody in the back seats, all 3 position seat belt lights come on. If somebody is seated in a position, that light does not come on. That may be because they have the belt buckled, though.
    Perhaps the sensors were added to the higher trims.
    kithmo and RCO like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I hadn't noticed before, when did you change up to a 17... Or did I forget?
  3. Prodigyplace
    12,554
    11,773
    Central Virginia
    I forget. :D
    I bought a 2017 last October and then joined PriusChat. I also have a 2008 Corolla & a 2000 Tundra pickup truck. I lurked on PriusChat for quite a while before joining.
    My oldest son's first car was a 2005 Gen 2 Prius. He then moved to a 2015 Prius v 5 to take his dogs to dog shows.
    We regularly have both Prii in our driveway.
    RCO likes this.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I thought that was 16 and you had a bad e experience with your cloth seats. Plus, did you get a 17 in October 2016??? (n)
  5. Prodigyplace
    12,554
    11,773
    Central Virginia
    Never had a 2016. When lurking I considered the price of a 2016 Three tp get spare tire & safety features. I actually looked more at a new Corolla.
    They have that ugly big black grille and we determined it might be too small inside for the medium sized dog we wanted then. Two weeks after getting the Prius my son & wife drove it from Virginia to Michigan and back to get our Miniature American Shepherd, Hannah.
    EDIT: Images appear to be broken. Hannah is black & white. This news page has some examples.
    News | Dynasty Miniature American Shepherds
    #185 Prodigyplace, Sep 15, 2017
    RCO likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks, must be just another of my increasingly frequent 'senior moments'.....
    .. well, at least I've done the time!!
    kithmo likes this.
  7. Prodigyplace
    12,554
    11,773
    Central Virginia
    You and me both!
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    +1 :confused:
    RCO likes this.
  9. Hank Chinaski
    Hank Chinaski Junior Member
    US
    Four Touring
    It's the door sensor. When the car detects the rear door being opened, then the car started, it assumes someone is in the back seat and changes the settings for the airflow to reach the rear passenger.
    RCO likes this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Thanks for the feedback and Welcome to Prius Chat.(y)
    Prodigyplace likes this.
  11. Prodigyplace
    12,554
    11,773
    Central Virginia
    Welcome!
    That is not what the owners manual says. No mention of S-Flow changing to the rear seats.
    EDIT: You may be correct but that has not been my experience. S-Flow stays on for me.
  12. Tideland Prius
    16,555
    It may be one of those idiosyncrasies where you have to press S-Flow then press the AUTO button again on the climate control.
    The Prius/Prius Prime is the first car with automatic S-Flow (other Toyotas/Lexuses have had S-Flow but you have to change the setting yourself by pressing the S-Flow button)
    RCO and Prodigyplace like this.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Across the pond, I know, but I've found I can toggle my S-flow using the button without affecting the auto climate. The flow diagram is displayed briefly showing where the air is going, so best tried while parked the first time.
  14. Tideland Prius
    16,555
    Right. But we're trying to get S-Flow to automatically turn on/off depending on whether the rear door was opened. This may require pressing the AUTO button to ensure everything is in auto mode.
    RCO likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I see, we only use the back doors to set bags in the rear as a rule. On our few hot days of the year I've set the flow to the rear for battery cooling, but don't know whether it needed it. Seldom gets above 23°C/73.4°F in our summer.
    Tideland Prius likes this.
  16. Tideland Prius
    16,555
    That's pretty pleasant! It can get up to 30°C here!
    pilotgrrl and RCO like this.
  17. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
    Did we ever get confirmation on this? Documentation on Toyota Canada site clearly states that with the Advanced Technology Package you get laminated side glass. There is no mention of this on the Toyota USA site. My old 2006 Lexus LS430 Ultra Luxury had it and you could easily see the two layers of glass with some other material in the middle. Maybe a Canadian member with ATP could take a photo so we could compare down here. Not a big deal but would be nice to find the answer. My 2017 Prius III just has the standard front side glass.
    RCO likes this.
  18. Mendel Leisk
    41,413
    What's the purpose of this? UV protection? Holding the glass together even if shattered? Would it work against you, in a submerged car with the doors jammed?
    I've looked at Toyota Canada site, see "side laminated glass" noted, without further explanation. Strangely succinct.
    On this site it's noted as being for noise reduction:
    2016 Toyota Prius Technology Road Test Review | CarCostCanada
  19. Tideland Prius
    16,555
    No but hopefully a Four and a Four Touring owner can take a look at their window for us.
    It's for noise reduction. Basically it's double-pane glass but the middle is a laminate sheet rather than air or radon. The glass is tempered but with the laminated sheet, I wonder if it'll act like the windshield if you try and break it i.e. it'll come out as one sheet of glass because of the laminate holding the two pieces of glass together vs. shattering into many pieces.
    Our windshield is an acoustic windshield for noise reduction too.
    CoolPrius, RCO and Mendel Leisk like this.
  20. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Not sure if it'll help - but if you look closely, there is an inscription - I think mine says "TEMPERLITE", but it's hard to see, and I think that means it's a tempered glass which will shatter.
    I've got aftermarket tint - and I'm told that it's near impossible to smash open, particularly if underwater.
