Most Obscure Gen 4 Facts (way out there)
Discussion in 'Gen 4 Prius Main Forum' started by That_Prius_Car, Nov 5, 2015.
  1. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    The powered hubs that I have used will work even without power, you may want to try it if you haven't already. If it doesn't work then maybe try an unpowered hub which are inexpensive. Powered hubs are usually needed only when your devices are drawing more power than the USB port is providing, like using an external hard drive which has a motor in it. But flash drives and SSD hard drives don't use very much power.
    RCO likes this.
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    You can get hubs that are powered by the USB itself (called Bus Powered) and don't need external power supplies. It shares the power available from the host socket across each of the devices connected to the hub. For low powered devices (like USB Flash Drives) this is absolutely fine. For high powered devices, such as hard drives, charging phones, etc, you would need a powered hub.
    This is one such example: http://www.amazon.co.uk/AmazonBasics-4-Port-Ultra-Mini-Bus-powered/dp/B003M0NURK/
    EDIT: Oops! Hadn't spotted the post above before replying! :D
    EDIT 2: Fixing Amazon link to text as doesn't seem to work automatically with Amazon UK.
    #262 The Professor, Apr 11, 2018
    RCO likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,186
    Cornwall
    Great minds often think alike..... ;)
    The Professor likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Thanks - I'll give that a go!!
