Most Obscure Gen 4 Facts (way out there)
Discussion in 'Gen 4 Prius Main Forum' started by That_Prius_Car, Nov 5, 2015.
  1. krmcg
    2,592
    2,392
    Whittier, CA
    I used this feature with my 2008 Prius to mark my route in a rural mountain road in Nevada City where the street names were incomplete and the Nav couldn't reconcile a route. Once I found it I laid down "breadcrumbs" and never had a problem finding that location again.
  2. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    Okay, I can see how using it to return to a place I've been before could be useful, if the system has trouble routing to "Previous Start Point" or the like. But how do you decide when to use it, or what is the recommended use case? I turned on the option and only later noticed what it actually did -- by then I had breadcrumbs criss-crossed over the greater Houston metro area (not very useful). When I turned the option off, it asked if I wanted to save (said 'no') and the dots were gone. If you answer 'yes' does it leave the dots on the map (despite turning the display option off)? Otherwise, it seems to add and add and add... making the dots less useful, particularly (I'd think) if you were making many different trips within in a smaller area?
  3. krmcg
    2,592
    2,392
    Whittier, CA
    I think it has a very limited value in small cases. In 8 years I only really needed it the one time.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Mine has no mention of "passenger seat cushion airbag" - maybe only some markets. I've never actually heard of them in the cushion, but they could well be.
    The side airbags are in the side of the backrest - centred roughly. The stitching is designed to split, and seat covers for the past 6 yrs +/- have had gaps - just check that you put the correct ones on the correct side of the car. Check out this video about 54 seconds in.
    Official Toyota Prius 2016 safety rating
  5. Tideland Prius
    16,555
    It first debut in North America on the Yaris then the iQ. The Prius c also had it at since 2012.
    The idea is that it's an anti-submarining feature - it's designed to prevent you from sliding under the seatbelt. Or rather, prevent the lap belt part of the seatbelt from riding up and potentially injuring your organs.
    alanclarkeau likes this.
  6. Tideland Prius
    16,555
    These are your heated seat settings for the "LO" and "HI". It dictates the part of the seats that get heated (and I guess the temperature too?)
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Yes, and I believe that is the area of the recall I just received. Front passenger seat airbag.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Is this the same for Gen4 2016 and 2017?
  9. Tideland Prius
    16,555
    This is for the Gen 4 (2016+). The Gen 3 only had a single stage heated front seat (except the PiP, which had two-stage)
    RCO likes this.
  10. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    I posted this in another thread, but it's still something I consider an "obscure" fact. I noticed last summer when I would use cruise control, which was usually when I was cruising at 65-70 MPH, EV mode never engaged. Even down a hill at 70 with CC on, no EV icon until I took it off CC, the EV icon would pop up a moment later. The other day, I learned that the Prius will still switch to EV mode while in cruise control at 55-60 MPH. I don't see it go into EV at higher speeds with CC on, though. But I didn't really play that much with it. I assume that at a certain speed with CC on, the system decides to keep the engine spinning to protect something. Wonder what speed though.
    KnightRider2016 likes this.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Perhaps not in CC mode, but depending on road conditions it will using DRCC.
  12. benlovesgoddess
    benlovesgoddess Active Member
    135
    158
    Yorkshire
    Awesome - I wondered why they didnt do that! I'll try tonight...
    That_Prius_Car and RCO like this.
  13. benlovesgoddess
    135
    158
    Yorkshire
    Yep it worked - if i pushed the stalk forward then back after switching off, swish!
  14. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    One of my sisters used to call the sounds my 2G Prius made immediately after shutting it off "the dialtone". That always made me laugh. I haven't heard any interesting sounds from the 4G yet, but I've never been inside it five hours after turning it off,
    kithmo and Tideland Prius like this.
  15. KnightRider2016
    KnightRider2016 New Member
    Always wondered what might happen if that button was pushed while doing 70 down the freeway. What will the park button do?
    pilotgrrl and RCO like this.
  16. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    It's in the manual - page 645.
    Either press and hold or press three times in quick succession to disable to hybrid system.
    #116 kevinwhite, Aug 5, 2017
  17. Tour de Prius
    Tour de Prius New Member
    23
    Michigan
    Three Touring
    OK, I got one...very, very obscure. Anyone notice that when you have the Prius vehicle charging display on the screen, you see the wheels spinning. But did you notice the wheels actually spin faster if you get up to highway speeds?
    pilotgrrl, ATHiker and Mendel Leisk like this.
  18. Mendel Leisk
    41,419
    I notice Prius cabbies always show that screen, never the Hybrid Synergy Display, lol.
    RCO likes this.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Disgraceful of them and IIRC, why the taxi?
  20. Mendel Leisk
    41,419
    Just once in a blue moon circumstances.
    RCO likes this.
