Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. Blind Guy
    Blind Guy New Member
    352
    194
    Springfield Missouri
    :rolleyes::DIn the previous generation Prius, just like the current model, the Headlights will go out in 30 seconds (or whatever time they have been programmed for) ONCE the drivers door is opened.
    However, those conditions have been changed to include the passenger's door as well.
    I read in another post that someone had stopped their car, turned it OFF (leaving the lights ON), her husband got out on the passenger side, while she remained in the car and 30 seconds later, the Headlights went out!
    Today (10/2/2009) my wife and I duplicated that feat, and were rewarded with the SAME results!
    So NOW, OPENING either the PASSENGER or DRIVERS door while the Headlights are on, and the car has been turned OFF, the Headlights will extinguish automatically.
    David (aKA bLIND gUY)
  2. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    WOOOT! a *solution* to daytime running lights! I know someone here had the dealer reprogram them to zero seconds....wondering if you can program any value between 0-30? i'd like 10 seconds, maybe 5?
  3. Blind Guy
    352
    194
    No doubt, many of you have read the posts on the California Highway Patroleman and his family, who were killed in a crash due to his inability to turn off a runnaway car because of a stuck throttle pedal, possibly/probably as a result of being stuck on an unsecured All Weather Floor Mat.
    There have been many Threads/Posts on this subject, and many have wondered how this affects the Prius. With the Push Button Start and a hung Throttle Pedal, it is possible it could suffer the same fate, UNLESS you know how to turn OFF the HSD.
    Those who have NOT read through their Owners Manual, need to be alerted to the fact that in this event, the system can be disabled by pressing and holding the Start Button for 3 (three) seconds, this wil stop the engine from its runnaway condition and turn OFF the Hybrid Synergy Drive (HSD), however, since NO Power is supplied to the Power Steering or Brakes, they will operate at an increased effort level (they are still FULLY functional, they will require a little more muscle).
    The simplest resolution to a runnaway engine/car, is to Pull and "HOLD" the Gearshift into the Neutral position for two (2) seconds (pull the gearshift towards your right leg until it stops, and hold it there for 2 seconds). This will retain the HSD (which will permit power for the steering and brakes), with the engine power being reduced to idle.
    We just returned from experimenting with this procedure, and it works FLAWLESSLY!
    My wife accelerated from a stop, held the throttle to the floor, pulled and held the gearshift into "N", and held it there for 2 seconds. At that point, even though the engine was at full song, engine RPMs went to idle and the Power Steering and Brakes still had full assist, so if this had been an emergency, the car could have EASILY been brought to a calm, uneventfull and FULLY controllable stop.
    David (aka Blind Guy)
    19 people like this.
  4. Tideland Prius
    16,556
    On the Canadian models, the Technology Package has the felt-lined interior pillars but the lower models don't. I'm not sure how it's split in the U.S.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I know the Prius II has plastic, and the IV/V has felt. I couldn't say on the III.
  6. Bruno_S
    Bruno_S New Member
    130
    68
    sound settings are per input not global. e.g. the radio can be set to have more mid range and the sat set for more bass. This is on the nav version.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    You only get 0, 30, 60 ,or 90 seconds. I suggest reading section 6-2 Customizable Features in the owners manual before you pay them to change it. That way if you want something else changed they can do it at the same time.
  8. Tideland Prius
    16,556
    Maybe leather interior = felt for a more upscale feel??
    which probably means only the Tech model gets it in Canada lol.
  9. Blind Guy
    352
    194
    You ARE correct, in the U.S., the leather equipped models (IVs and Vs) get the Fuzzy inner A and B pillars.
  10. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    when moving in reverse the MID actually has the prius wheels going in reverse
    i type too fast....dammit :mad:
  11. Tideland Prius
    16,556
    wow... I didn't know that! That's definitely obscure!
  12. HTMLSpinnr
    5,341
    920
    251
    On the MID topic - the Hybrid System Display will display a touch of "power" if you're creeping at 7mph or lower.
  13. stoneea
    stoneea New Member
    Virginia, USA
    If you load up a USB thummb drive with MP3 files, you can stick it into the MP3 AUX and the car will treat it like a MP3 Disc with Song Titles and Directories.
    eas
  14. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    You can play WMA and MP3 cd's in the cd changer.
  15. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    Where is the USB MP3 AUX?
    Thanks.
  16. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    As stated in the manual. You can't play MPEG4 alas... (iTunes).
  17. deltron3030
    437
    64
    Lakewood, CA
    I do not know if this was mentioned already, but The rear 2 windows in my prius slow down for the last 1/4 of the travel when rolling them up. It's either a safety feature, or a result of my recent window tinting
  18. thetuxedo
    thetuxedo New Member
    Gatineau, Québec
    Something nice I noticed lately. It's with the audio system (JBL). When you set a volume/bass/treble value it's different for each: Sat Radio, CD, Aux and FM.
  19. HTMLSpinnr
    5,341
    920
    251
    Newer NAV equipped vehicles come w/ USB connectivity in the center console. With this, one can connect an iPod or a flash drive w/ MP3 or WMA files. Existing NAV equipped Prius III-V's can be retrofited as well.
  20. Tideland Prius
    16,556
    Variable speed power windows. It first debuted on the LS460 and now makes its way into the Prius. Toyota still keeps 4-window variable speed for Lexus models.
    Yet another Lexus feature on the Prius
