Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    I'm amazed. I thought the fuzzy felt pillar covering was a cost-cutting measure across all models. Never guessed it's an upgrade! It looks like a dust and dirt magnet that will be next to impossible to clean. I'd much prefer the plastic covers that can be freshened up with a little Vinylex.
  2. Tideland Prius
    16,559
    There's a warning chime if the car is moving and the parking brake is applied
  3. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    Cannot put the car into gear if the driver door is open
  4. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Huh.
    Did exactly that yesterday (put both in reverse and forward with driver door opened to move the car by a few cm. Works.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Not necessarily true, however opening the driver's door while still in Drive will yield a nasty warning message.
  6. deltron3030
    437
    64
    Lakewood, CA
    Ahh! You're right, I never actually tried "going". To rephrase, if you have the door open while shifting IMO gear, you get a "shift into park" message
  7. maomao
    maomao New Member
    93
    DC
    What do you mean they are different? Are we able to set the sound features separately for each source? But we know for fact that the different sources do produce different sound qualities. How do we know the differences are from the source, or from the settings?
  8. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    By looking at the equalizer settings
  9. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    the overhead console light switch detents don't line up with the pictograms, especially the "on" (right one)
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Lexus has this same "mouse fur," albeit with much shorter naps.
  11. thetuxedo
    thetuxedo New Member
    Gatineau, Québec
    On my Prius I set:
    • AUX: Bass to -2 & Volume to 20 (iPod audio books)
    • CD: Bass to 2 & Volume to 8
    • SAT: Bass to 1 & Volume to 6
    • FM: Bass to 3 & Volume 10
    • I think also the Blutooth volume can also be set to a different value
    I've noticed that feature with volume when switching between FM and AUX.
  12. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    What volume?
    If I set my volume at 6 or 8 I would not be able to hear anything.
  13. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    my car does not do this. :(
  14. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    What is that thang?
    What is this?
    What is this rectangular plastic piece on the floor in front of the front passenger seat? It looks like a cover. On its right (facing up in the picture) it says PULL (or maybe it's PUSH) and there's an arrow. The text in the middle says FRAME NO.
    Please don't tell me to RTFM because I have no idea where to look.;)
  15. fuzzy1
    10,474
    I looked. It is to cover two holes on the floor. Those holes are needed to accommodate the mounting tabs of the cover.
    RTFOM won't solve it. I can't RTFSM.
  16. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    The main driver's window control switch has an indent and odd shape to the top of it making it feel different to the fingertips from the other switches.
  17. PriusRos
    1,973
    218
    Rockville, MD
    It's a cover to cover the holes that hold the tabs that hold the cover? :eek:
    How did you take it off to look? I tried pushing (or pulling) in the direction of the arrow but it wasn't moving. I've never been very good at removing battery covers, either.
  18. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    That plastic cover that says "Frame No." covers the frame number. Quite an elaborate scheme to cosmetically hide the frame ID number.
    Must have been thought up by the same Japanese workers that program the user settable features. They probably just do that to american cars.
  19. fuzzy1
    10,474
    I pulled up in the middle and sprung it. The right hand side tab has a small catch that should release or slide if you push it a bit to the left. The left side tab has a very large protrusion and cannot release, only break, unless the other tab is free and the cover is rotated up.
    If there is any frame number there, it is hidden underneath the carpet.
  20. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    And they say the Japanese don't have a sense of humor. :bounce:
