Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Did you follow the instructions?
    1. Pull the passenger seat back lever twice
    2. Turn the dome light switch on and off
    3. Get out of the car and do the chicken dance
    4. Loosen the positive battery cable with a wet rag
    5. Push the door lock button with your nose
  2. fuzzy1
    10,462
    I don't have X-ray eyes. Those instructions were hidden on the underside of the cover.
  3. Tideland Prius
    16,559
    Hmm.... cause if you watched my VSC demo video, you'll hear two beeps - one is the VSC and the other one comes on later when I apply the e-brake.
  4. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    I use the parking brake when i park. If i go start my car without releasing the parking brake it makes no beeps warning me i'm tryig to drive with the parking brake on.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Odd, once in drive, I found the car will beep if I put my foot on the parking brake pedal enough to activate the brake switch.
  6. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    Thanks for the info. I guess I need to open the cover and see for myself. What is a frame number and why would it be something that they would have to build a cover for?? I thought it was covering the fuse box or something! :p
  7. PriusRos
    1,973
    218
    Rockville, MD
    I tried this sequence -- still couldn't get the cover off. I guess I'll never find out what the frame number is.
  8. thebeed
    thebeed New Member
    50
    San Francisco, CA
    You might want to check your chicken dance technique.
  9. hill
    8,810
    Gary, they've only been available in the U.S. (few models) for a short time ... even shorter than you've owned.
    Edit: whoops, I see htmlspinner already answered with almost the same answer.
  10. adamace1
    1,403
    193
    Charlotte, NC
    i haven't tried pushing down on the parking brake when in drive. I do know in my car i can lightly apply the parking brake, there is a warning light on the dash that says BRAKE but i can put it in gear and drive no beeps are heard. I have the reverse beeps disabled.
  11. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    On the MID screen, there is a red dot to the left of the name on all but the Settings screen that has no discernible purpose!!!
  12. Tideland Prius
    16,559
    You're not applying the parking brake then. Just because the light is on doesn't mean the parking brake is applied. IT depends on how taut your parking brake cable is.
    Try it. Apply the parking brake lightly until the light comes on then put the car in D and let the car creep. The car will move forward.
  13. garygid
    garygid Senior Member - Blizzard Pearl
    379
    23
    Orange County, CA
    Is there a USB-only upgrade kit that is not the $200 iPod/USB kit?
    Can one add the USB port with only the correct cable and wiring it into an existing (used or unused) connector?
    Is the internal software already USB-aware?
    If not, how is that part of the upgrade handled?
  14. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    The simplest resolution to a runnaway engine/car, is to Pull and "HOLD" the Gearshift into the Neutral position for two (2) seconds (pull the gearshift towards your right leg until it stops, and hold it there for 2 seconds). This will retain the HSD (which will permit power for the steering and brakes), with the engine power being reduced to idle.
    We just returned from experimenting with this procedure, and it works FLAWLESSLY!
    My wife accelerated from a stop, held the throttle to the floor, pulled and held the gearshift into "N", and held it there for 2 seconds. At that point, even though the engine was at full song, engine RPMs went to idle and the Power Steering and Brakes still had full assist, so if this had been an emergency, the car could have EASILY been brought to a calm, uneventfull and FULLY controllable stop.
    David (aka Blind Guy)[/QUOTE]
    David, thanks for this good information. I have a G2 Prius, and the owners manual says that if you push the P button while driving the transaxle is automatically shifted to "N." I wonder if this wouldn't be a better way to stop a runaway car as it might not take the two seconds that your experiment used. I have not tried this. Craig
  15. adamace1
    1,403
    193
    Charlotte, NC
    I know that, but i would think the same sensor that turns the light on in the dash should be the same one that would trigger a beeping noise to let me know the parking brake is on. I can apply the brake harder and still put it in gear and drive and there are no beeps to remind me the parking brake is on. If i apply the brake hard it will be very hard to get the car to move without releasing the parking brake, but if one apply's normal force and didn't notice the brake light on the dash. Or the added resistance they would drive away and fry the parking brake with no beeps!!
    Someone posted there was beeps to remind you to turn off the parking brake. My main point is my car will let you ride the parking brake and not beep to let you know your driving with the parkig brake on.
  16. Tideland Prius
    16,559
    Then what was the extra beep in my video? HTMLSpinnr said his beeps too. I'll try and remember to test it out again over the weekend.
    There were two beeps in the video. If it wasn't the parking brake then what could it be? The VSC is already beeping and the only thing different that I did was applying the parking brake to induce a spin.
  17. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    You don't have to be in Park and pulled off the road to use the touchscreen to set up Destinations. You can do so when just stopped at a traffic light/sign. If you need to roll before you finish, the screen just ghosts out, but will return to the screen you were just at, when the car stops rolling at your next signal/stop.
  18. Tideland Prius
    16,559
    The solar panel equipped Priuses are 15mm taller
    Oh and you lose 30mm of front headroom to the moonroof
    the solar panel moonroof combo weighs 30kg.
  19. bighouse
    822
    126
    Guerneville, CA
    But, well worth the mm's and kg's!!!!
  20. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    when you get a "bisque interior" it's not all bisque.
    belt line up and the cargo cover is a light grey.
    i feel cheated
