Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. Tideland Prius
    16,555
    There are at least 9 different radio combinations for the Prius worldwide.
  2. fjpod
    fjpod Member
    419
    72
    New York
    Hmmm...I should be getting my Package IV with a Bisque leather interior next week. I'll let you know what I get.
  3. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    you will get the same as i got with my bisque interior
    and like it!! dammit
  4. fjpod
    fjpod Member
    419
    72
    New York
    I opted out of waiting for the IV with leather bisque. I took a II bisque and the floor mats are black. Oh well. I think a silvery grey would have gone better with the silver trim on the doors...
  5. fjpod
    fjpod Member
    419
    72
    New York
    Don't know if this fact has been mentioned. There is a small spotlight from the ceiling that shines on the gearshift. It amazes me that such a technically advanced car can't manage to have a light in the glovebox or under the dash. (on a II).
  6. Tideland Prius
    16,555
    Err... it doesn't have a glovebox light? seriously? I'm sure it's standard equipment.
    Not a lot of cars have footwell lighting.
  7. fjpod
    fjpod Member
    419
    72
    New York
    I had the glove box open last night before I left the car. No light. 'Will check today in daylight to see if there is a bulb there.
  8. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    The top part does not have a light. Just the bottom.
  9. fjpod
    fjpod Member
    419
    72
    New York
    Nope. My bottom doesn't have a light...that works anyway. Gotta get under there and see if there is a loose or dead bulb...Or maybe the II doesn't come with it??
  10. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    A couple interesting items:
    - When walking up to the car, the LED on the keyfob blinks as the fob talks to the car. (LED comes up even when not pushing any buttons.)
    - When you first turn on the car with a cold engine, the computer runs the ICE at exactly 1280rpm to warm up the engine and charge the battery. (It is applying a load to the engine to help warm it.) The ICE will turn off when coolant temp reaches 103F. (If you aren't driving) If the battery is at 2 bars or lower, it will stay running to continue to charge...
    While warming up and below 103F, the computer uses battery power to motivate the car and the stay at exactly 1280rpm even if you push the HSI past the ECO middle line. As you approach the right side of the bar, it will start to raise the RPM to generate more power, but it will return to 1280 as soon as you let off and when it does rev up, it does it much less than normal. This behaviour minimizes engine wear when the engine is cold.
    Between 103F and 159F the car uses the ICE more often to help warm it up, but it will auto-stop when fully stopped and even when cruising under 43mph... It just runs it more often.
    160F and over the car shuts off the ICE as much as possible and much more frequently than under 159F.
    - It is impossible to attain great mileage with the ICE under 160F. On the same drive through slow city streets, I might get 40mpg with the ICE under 160F and 65mpg with above 160F.
    - Using the heater removes a lot of heat from the cooling system. With the ICE off, the computer has to run the water pump to get warm coolant into the cabin heat exchanger (to generate warm air.) I am not sure if the coolant runs through the radiator in this mode, but I notice that coolant temps drop pretty quickly with the ICE off.
    With my normal 3 mile drive to work, with the heater on (and a 60F day) I can only briefly get about 160F -- and when I do, the coolant temp drops again. By the time I get into my parking spot it's usually in the mid 140's again.
    Without the heater, I would be at 175-180F in my parking spot.
    If you want to maximize mileage on cool days, do not run the heater so you can stay above 160F.
    6 people like this.
  11. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    heater on at 60, up north we would running the AC on :p
  12. LeeB
    LeeB Junior Member
    99
    Henrico, VA
    Bottom glove box light comes on with headlamps/parking lamps on my V. Looks similar to the "orange" footlamps. Not sure if all models have the glove box lamp.
  13. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Found this little oddity today...
    We all know about the NAV lockout when moving. But today I found out that the FM radio has a lockout as well. When you are moving, the "Message" text that would normally have artist and track info if the station broadcasts it, instead reads something to the effect of 'for safety, messages not displayed while driving'. Of course, the warning is well longer than the artist name and track info, and at least this first time, occupied considerably more of my attention than reading 'Coldplay' or whatever it was. Of all the stupid things to lockout... sheesh.
  14. fuzzy1
    10,438
    My Model II has it.
  15. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I'm quite sure my III has the "orange" box light too...
  16. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    LOL! Well, I just keep the car on auto and 73F so it does what's needed. (A/C off when it's not raining or not hot out.) I love automatic climate control!!
    But I know, it's all relative. When the car says 59F on the outside temp (like it did the other day) my teeth were nearly chattering!
  17. Tideland Prius
    16,555
    Funny eh? You know what's even funnier? Sat radio info is available.
    Thank you for the informative post!
    Might wanna double check. It should be standard. Remember that your lights must be on (either parking lights or full headlights... i.e. anything but the OFF position)
  18. fjpod
    fjpod Member
    419
    72
    New York
    I found the glovebox light in my II. The other night it didn't go on when I could hve used it. I don't remember if I had the car started or not, but it didn't come on. In non-hybrids, it would come on regardless of the engine being on. So now I'll have to check if it comes on only with the car started or with the headlights on.
  19. fuzzy1
    10,438
    It has varied in my pre-hybrids. My Subaru is just like my Prius, it comes on only with the headlights.
    Having once had a glovebox with a troublesome latch that could pop open at any time, even when parked, this was a Very Good Thing.
  20. Tideland Prius
    16,555
    Disabling the power windows will turn off the illumination for those switches. Freaked me out the first time because I was trying to think how I managed to blow another fuse cause both the driver's side switches and the passenger side switches had the lights out (except the driver's window switch).
