Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. Dominic
    Dominic New Member
    Halifax, Nova-Scotia
    actually, no. the wipers were on, but just on normal setting. hence why i was believing it was the radar who couldn't detect ahead. but i'm not sure
  2. Tideland Prius
    16,554
    Ohh ok. The manual said that warning comes up if the wipers are on HI.
  3. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    I had a 2000 Maxima with auto headlights, and I just got a 2010 Outback with an auto setting. So I think it's safe to say that there were, and are, US vehicles with them.
    It is bad to use cruise control in the rain, for among other reasons if the car started to hydroplane it could be difficult to cancel it quickly enough. That said, the story about the woman's car that rocketed out of control because it hydroplaned with CC on is an Urban Myth. Cruise control senses the vehicle speed based on the speed of the drive wheels. If the car started hydroplaning, and the wheels started spinning faster, the CC would interpret that as an *increase* in speed, regardless of the car's actual speed, and back-off on the throttle.
  4. Tideland Prius
    16,554
    The Hill Start Assist is on a timer (and I don't mean when you lift your foot off the brake).
    I found this out by accident. I was at the drive-thru and after a while, I noticed that the line is moving very slowly so I decided to use a trick I learned here and activate Hill Start Assist so that I can relieve some pressure on my right foot over the brake pedal.
    Well after a while, I heard the usual two "beep beep" and the HSA cancelled! I was sure I didn't change the amount of pressure applied to my foot. I checked the consumption screen and sure enough, I've been waiting for a while.
    I didn't catch the exact timing but it's somewhere between 2 and 5 mins (I was just switching btwn the 1 min and 5 min consumption since I really wasn't paying attention to the time/clock).
  5. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I swear mine cancels after like 5 seconds...
  6. Tideland Prius
    16,554
    You're not pressing hard enough after engaging? It will cancel after 1 second if the pedal is released (or at least not enough pressure to apply braking power if you were to be in motion).
  7. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Oh you still have to keep pushing the break? What's the poinnt then? I use it on super steep hills to prevent the car from rolling back when I go to push the gas. What's the point of engaging it then holding.the brake pedal? _
  8. guinness_fr
    guinness_fr Junior Member
    68
    france
    Well that allows you to press only lightly on the brakes while still making sure that the engine is no longer creeping.
    You indeed have to be careful in traffic jams because if you press too lightly on the brakes the engine might still be creeping and wasting some precious electric energy.
    The actual true reason is that you can activate HSA when you stop instead of just before starting, which saves some milliseconds...
  9. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    The Gen 3 is so much better about the wasted energy than the Gen 2...
    Good point about the HSA activation when you first stop. Though I just wish it were on everytime you stop. My friend has a 2010 Passant and you can set the car to apply HSA every time you stop. Even if you roll to a stop. To creep you have to give it a little gas. I love it!
  10. Tideland Prius
    16,554
    That's not really HSA. The Passat has what is essentially "Auto-Hold" in Lexus speak where it holds the brakes every time you stop. Slightly different from HSA where it activates even when you take your foot completely off the brake pedal.
    I prefer my smart's HSA setup to Toyota's. Toyota requires that I activate it manually and then flash the Slip Indicator (which confused the heck out of me when I drove the HiHy and before I got the 2010 Prius). The smart automatically activates it every time you come to a stop. No beeps, no flashing lights. Just press the accelerator when you want to go like you normally would. If you want to creep, just let go of the brake a second earlier and let HSA cancel on its own.
    yeah like guiness_fr said. it's just a side trick of HSA.
  11. Lebowdia
    Lebowdia New Member
    Cincinnati, Ohio
    No card holder on my 2010 Prius. Its a base model with the JBL's and bluetooth. Bummer!
  12. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Apologies if this has already been noted in one of the 650 prior posts:
    The power window switches on the driver's side each have a small somewhat dim LED.
    If you push the button to disable power windows (disabling all but the driver's), the 3 LED's on those switches go out. So, at night, you can see the state of the window-disable button.
  13. Jon S
    Jon S Member
    185
    84
    The Aloha State
    regarding the random shuffle of the cd player.
    My Prius has MP3 files on all four CDs. The CDs have the music in folders... e.g. my country CD has a folder for Willy Nelson, Garth Brooks, etc. If you select a folder (like Willy Nelson) and tap the random button to get a short beep, the Prius will randomly select the songs from that particular folder. If you hold down the random button and get a long beep, the Prius will randomly select songs from the whole CD from all the folders.
  14. Chrisjul
    Chrisjul Junior Member
    FL
    Don't worry....I live in S FL and tint is also a requirement....GPS works fine!
  15. Tideland Prius
    16,554
    Doing that with regular discs will activate the Disc Random (i.e. play songs from all CDs in the slots).
  16. johalareewi
    johalareewi Member
    393
    44
    uk
    The basic CD player in my T3 (your series II?) will play MP3 and WMA files from a CD but will not play lossless WMA. :(
  17. rleepac
    rleepac New Member
    44
    Manteca, California
    We actually fit a soap box derby car, production camera gear and tool boxes in my Gen II prius - all with only one seat folded down so my 8 yr old would still fit too. It was quite a sight but it all fit!
  18. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    The temperature setting can be adjusted from (Low, 65F to 85F, High) using the Temp+, Temp- controls on the center console or steering wheel.
    Press the temp +/- once, and the setting will change by one value. Press and hold, and the value will keep increasing/decreasing, until it hits 75F after a few seconds.
    This is a nice way to get to a known temperature setting without having to peek at the temperature setting display.
    Tom
  19. Eoin
    Eoin Active Member
    593
    116
    Long Island
    The rear windows slow down just before the top and bottom, but the front windows do not.
  20. Lsegovic
    Lsegovic New Member
    78
    Instead of that you get an advanced VFD "green" screen :D because I don't see any colors there!! with the ATARI 2600 computer type software t!! HEY WE HAVE TO PAY for retro design !! LOL :rofl:
