Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. fuzzy1
    10,437
    If your use of 'B' is short enough to keep a hand off the the wheel for the entire duration, you don't really need 'B' in the first place.
    This mode is meant for extended mountain descents.
  2. WE0H
    WE0H Senior Member
    3,247
    528
    I use it for descending passes and coming up on an exit ramp while running down the Interstate. Works excellent.
    Mike
  3. Thomas&Kathy
    Thomas&Kathy New Member
    West Australia
    I thought it would be for the Tollway card or similar!!
  4. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    The vertical line in the middle of the HSI disappears when in reverse - don't know why it took a year and a half to notice that.:cool:
  5. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    When in EV mode, the "ECO" light goes out.
  6. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    I take it you have only driven automatics. If you were to drive with a standard transmission, you would use your left foot for the clutch, right foot for the gas and brake, left hand on steering wheel and right hand for steering wheel and shifting. This does not include the left hand for turn signals and headlights or right hand for wipers, radio, nav, etc.
    Just on observation...:)
    2 people like this.
  7. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Another obscure Gen III fact: The 17"-wheel Prius has a fibrous liner in the rear wheel wells whereas the lower trims lack the liners.
    See attached pics of a V/Five and a II/Two.
    3 people like this.
  8. fuzzy1
    10,437
    So your hand has sufficient wingspan to hold the shift lever and steering wheel simultaneously?
    If not, then I suspect you have not driven a manual transmission down the sort of long steep twisty winding descent of which type Geodosch was speaking. While the right hand may leave the steering wheel many times during that process, it most certainly does not spend 100% of the time off the wheel, glued to the shift lever to keep it in low gear.
    Not even on my Subaru when I suddenly learned of the (known to Subaru) defect where on a really steep hill, the pressure could pop it out of First gear into Neutral. Sharp corners had to be taken in Neutral with both hands on the wheel. And of course, foot riding the brake.
  9. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    Wingspan......??? Who mentioned wingspan......???
    I'd better stop before this gets out of hand.
    So, I'm going to pull out of this portion of the thread.
    Thanks..........
  10. sa68ta
    sa68ta Junior Member
    30
    Slovenia
    Asymmetric roof. Due to installation manual for Thule roof bars, rubber pads for front right and front left have different part numbers (unlike rear rubber pads).
  11. Tideland Prius
    16,554
    I was wondering how they didn't do it for the Prius but did so for the Camry and Avalon. I suppose it's to filter out the extra noise from the 17" alloys?
  12. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    I had to check this out myself, but you're right, and I stand corrected. I was surprised to find how much brake pressure is needed to activate the brake lights. I thought I had read the thing about the speed difference in the manual, and while that's true, it's not the 1-2 MPH difference I had thought it was.
    Thank you for setting me straight!
  13. geodosch
    geodosch Member
    182
    27
    New Jersey, USA
    2013 Prius Plug-in
    Actually, this and my 2007 Prius are some of the few cars I've ever owned that didn't have a manual transmission.
    There's a big difference between momentarily using your right hand to change gears and keeping it on the shifter for an extended stretch (which BTW is very bad form)
  14. lindajm22
    lindajm22 New Member
    34
    CT
    And actually, it's not just the 3 lights on the driver's door switches that go out. If you engage the window lock, the window switch lights on ALL the doors go out. I thought my new car was broken until I read your post and then tried it out for myself.
  15. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I tried to stick my magnetic Boston Red Sox "B" from my last vehicle on the back of my 2010 Prius next to the number plate. It must be plastic because it didn't stick.
  16. macman408
    macman408 Electron Guidance Counselor
    1,179
    367
    I believe it's aluminum, actually, along with the hood. Saves weight, and keeps you from stirring up a riot if you happen to drive past Yankee Stadium.
  17. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    Bob G IA and Jbio like this.
  18. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Unless you happen to have one of these.
  19. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    It's plastic. I usually have many stickers, all of which I have put on magnetic backing. It was a little disappointment for me, but I'm willing to do it for better fuel mileage, and Mother Earth.
  20. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    I agree, especially after the Bosox swept the Yankees last weekend. Tends to ruin Yankee fans' sense of humor. Although I used to remove the magnet anytime I got south of Hartford.
