Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. Mendel Leisk
    41,406
    We're more just rain birds. I used the headlight washers once or twice since purchase, for the novelty more than anything, not since.
    D.O. for the fog lights: can barely tell when they're on. They look cool I guess. :rolleyes:
  2. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    One other difference is that the V has a wider turning circle. I assume that this is to maintain clearance between the wheel well and the wider tires. This will matter a lot for some people and not at all for others.
  3. Thai
    Thai Prius Neophyte
    1,197
    89
    I doubt it since the Prius already has a small footprint.
    Dancing Badger likes this.
  4. energyandair
    905
    339
    Victoria BC Canada
    One situation where its an issue is where you have dead end streets or driveways that are narrow enough for the difference in turning circle to make a big difference in the ease with which you can turn around.
    In many places such as Texas, this would rarely be the case.
    There are some other places where it can be a big deal.
  5. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I was under the impression it was thought the shocks and springs were different but it turns out they are the same. I thought I read that on the early test cars there was a difference but Toyota decided to actually use the same parts. (Although there seems to be two different part numbers listed)
  6. Thai
    Thai Prius Neophyte
    1,197
    89
    Well, no one has told you that the V/Five has more sound insulation in the rear wheel well, right? Toyota is tricky that way. They don't list all the differences in the brochure or even what is listed in the training manual for salesman. (Another unrelated example...Toyota 4runner Limited has underhood insulation, while 4runner Trail and SR5 does not.)
    Here is a good thread to read about the suspension differences: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/90563-options-four-five.html (Read page 3 and on)
    Basically, the shocks and springs for the V/Five are totally different than the other Prius (II-IV). In addition, the alignment specs for the V/Five are different. The steering motor and ratio are different in the V/Five.
  7. Thai
    Thai Prius Neophyte
    1,197
    89
    I have never felt the need for a smaller turning radius...but i do live in TX. However, i have also not heard of this "issue" from any other V/Five owners.
  8. new2hybrid
    new2hybrid New Member
    35
    Delmarva
    Is there a way to leave the car running and lock it? I did a test where I left it running, had someone else take the key away and see if I could drive it. I thought it would shut down, but no, I was able to drive it . . . didn't thnk that would happen!
    During the winter I had left it running to de-ice it. Didn't realize it could be driven away . . .
    Any suggestions? I apologize if this has been previously asked. Did a search but no luck finding anything.
    Thank you,
    Karen
  9. geekaren
    geekaren Junior Member
    New England
    Hi Karen!
    I had the Toyota dealer install a remote starter for winter, partly to get around this issue and partly because I don't have a garage. With all the snow we had last winter in New England, it was money well spent!
    Hopefully, someone will jump in to respond to your question from the perspective of not having remote start.
    Karen
  10. tomlouie
    tomlouie Member
    118
    Boston, MA, USA
    2023 Prius
    You can lock the running car with the mechanical turn key, and walk away.
  11. Tideland Prius
    16,554
    Not really obscured (unless you didn't own a Gen 2) but the Gen 3 is missing a stand for the underfloor bin lid (i.e. the cargo floor). In the Gen 2, you could open the first half of the lid, then fold the whole thing up so that it's perpendicular and then prop it up with the stand (kinda like the hood prop)
  12. ramdisk01
    ramdisk01 Junior Member
    Merritt Island, FL
    Boy, Thats my pick for most obscure!:p
  13. Tideland Prius
    16,554
    More of an interesting tidbit.
    The difference between 6 bars and 8 bars is about 41/2 5-min leaf cars or 225Wh.
  14. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    On the NAV system, each input has it's own audio controls. i.e. if you reduce the bass on satellite radio, it won't change on FM radio.
  15. Tideland Prius
    16,554
    Almost all. I found out that AM, FM and CD use the same volume setting, but SAT, BT and AUX have their own.
  16. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    FYI: Leaving your car running and unattended in MD voids your insurance and is a $500 fine.
  17. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Guess I'll have to avoid MD... I leave my Prius in Ready with the A/C turned on when I go shopping and the weather is particularly hot. I've tried several times to figure out how much that costs, and it generally comes out to something like 10 to 25 cents. Definitely worth it to me to return to a cold car instead of a blast furnace.
    I set the parking brake, put it in Park, and lock the doors with the mechanical key. Sometimes I cover the dash to hide the fact that the speedometer is still lit up.
    As for leaving the car running, that's actually a complicated situation. Unless the 12V battery is flat out dead, a Prius always has something active. Cars these days run the radiator fan even with the motor stopped. Even in Ready mode, the Prius has the motor stopped most of the time while it isn't moving. The factory remote start system runs the A/C and gas motor, but you can't drive the car in that mode. If you leave the Prius in Ready to operate the A/C, but lock the doors, is that regarded as the same as leaving a non-hybrid with the engine running full time?
    Several times people have noticed that the engine cycled ON while my car was parked. I reply that I left the electric A/C turned ON, and the engine automatically cycles ON every so often to keep the batteries charged. The general reaction is "cool, I wish I had something like that". do not know what an MD policeman would say about all this...
  18. Tideland Prius
    16,554
    It only takes one person to steal the car (if they realise it's running). A thief can break the window and drive your car away. To me, that's not worth a cool car (and why I'm happy with the Solar Roof option on the Gen 3 lol).
  19. RobH
    RobH Senior Member
    2,385
    991
    70
    True, but I thought the Prius wasn't worth stealing...:D
    But I would like your solar roof. It would definitely reduce the number of times I'd have to resort to leaving the car running with the A/C ON.
  20. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Is the rear hatch locked as well?
