Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    [quote="walter Lee,
    4. The Prius will beep if you leave it (move away from it) without turning it off and the door lock switch won't lock if the Prius is still powered on.
    .[/quote]
    But you can physically lock it with the emergency key.
    Dancing Badger likes this.
  2. rj250
    rj250 Junior Member
    22
    San Diego
    If you hear a loud annoying warning noise, and a warning message comes up on the dash saying “Shift to P Position", alternating with “Shift to P Position when Parked”, and the yellow triangle is flashing. The drivers door is ajar. What brilliant engineer thought of that?
    The surprising thing is I was so distracted by the flashing triangle light, and warning message I did not even notice that the door open icon was on.
    jgilliam1955 likes this.
  3. knite75
    knite75 Junior Member
    46
    If you unlock the front passenger door first, all the doors unlock as well.
  4. GBC_Texas_Prius
    218
    38
    gbc texas
    I turned the car off and realized that I forgot to close the windows. I quickly hit the window buttons and the windows closed even though the car was off. There must be a grace period.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! Until you open the drivers door.
  6. El Dobro
    El Dobro A Member
    7,088
    3,270
    It's about 20-25 seconds.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    I just knew I was wrong! But I knew I would be corrected, Thanks!
    I just knew every time I would forget to roll up my windows. I would open my door and then go oh darn and try to roll up the windows, and they would not go up. Never thinking about it being a timed thing.
    Operating the power windows after turning the hybrid system off
    The power windows can be operated for approximately 45 seconds even
    after the “POWER” switch is turned to ACCESSORY mode or turned off.
    They cannot, however, be operated once either front door is opened. :)
  8. El Dobro
    El Dobro A Member
    7,088
    3,270
    I figured it was something like that.
  9. Nora
    Nora Member
    128
    44
    CO
    You weren't wrong, both are true. I roll up or crack the windows with the power off a lot, but there have been many times I wasn't thinking and opened the door first. Darn.
    retired4999 likes this.
  10. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Another little known fact that you may not be aware of: If you power on the car (in ready mode) but forgot to get something from the trunk/hatch area. You get out and try to open the hatch, it won't open at all even with the fob. You'd have to put the car in gear then back in park in order to open the hatch. Obviously a safety feature so an intruder can't open the hatch as soon as you power on the car.
    Nora likes this.
  11. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    my 2010 prius and 2012 camry keep the lights on as long as the hatch or trunk or any doors are open after turning the engine off.
    I believe that is to stop the glare of the sun.
  12. Oskar
    Oskar Member
    249
    96
    Massachusetts
    2020 Prius Prime
    This is a great thread, but what's interesting is most of this stuff is in the manuals. Yeah.... I read the whole darn thing, more than 500 pages. Trouble is I've forgotten most of it. ;)
    Sampino35 likes this.
  13. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    It's red on mine.
  14. Mbarton557
    Mbarton557 Junior Member
    Mississippi
    I was pleasantly surprised to find out the Premium HDD navigation JBL green in my 2014 Prius 4 is also a DVD player. While parked u can watch a DVD put in in gear and it changes to voice only. I wonder if it could be directed to screens in the back and play going down the road.
  15. Mbarton557
    Mississippi
    Also i had a 2013 4runner. It had a button to deice the windshield wipers. I thought that was really cool. Wish my Prius did that
  16. Mbarton557
    Mississippi
    Business card for roadservice or dealer?
  17. Mbarton557
    Mississippi
    My 2014 USA has a HUD. Heads Up Display. Shows speed and turns for Navi. Love mine
  18. Sampino35
    Sampino35 Junior Member
    23
    NC
    When Prius is locked, and u unlock it and don't open any doors, within abt 60 seconds, it locks itself back up. Safety feature in case the unlock button is accidentally pressed.
  19. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Needless inconvenience in case the unlock button was purposely pressed and you find other things to do before opening any doors.
  20. Ashlem
    Ashlem Senior Member
    754
    502
    WI
    2017 Chevy Volt
    Well, if you have something that's going to occupy your time for 60 seconds after telling the car to unlock, then it's probably better that the car locks itself up. I'm sure if you ran back into the store or something like that, you wouldn't want someone opening your doors and stealing whatever you have inside.
