Most Obscure Gen III Facts (way out there)
Discussion in 'Gen 3 Prius Main Forum' started by hill, Jul 13, 2009.
  1. 60MPG
    60MPG Junior Member
    24
    38° 53′ 42.4″ N, 77° 2′ 12″ W
    That's so cool - specifically for Virginia:
    Qualified hybrid motor vehicles - Toyota Prius and Honda Insight model year 2007 or earlier, and the 2010 Toyota Prius. All Toyota Prius and Honda Insight models are subject to the $2 per year emissions fee when renewing the vehicle registration as required by the DEQ, Virginia Code § 46.2-1182.1.
    (Per Commonwealth of Virginia Department of Motor Vehicles)
    Does that make a 2010 Prius driver an elitist?!?!? ;)
  2. 60MPG
    60MPG Junior Member
    24
    Gerald - re-evaluating those pictures, it looks like you have a right-sided mount steering wheel. If so, the plan I was considering of buying the card holder panel and swapping it out isn't going to work, since it's molded for the right side of the car - not the left :(
  3. hill
    8,805
    Maybe Doug already did, Dianne, I just stuck this on the hybrid news thread earlier ... see the first bullet point ... as of this year, you're good to go:
    Clean Air Stickers - High Occupancy Vehicle (HOV) Lane Usage
    All you gotta do is wreck your Prius beyond repair ... off to the salvage yard, then fill out the DMV papers, to switch 'em to you new prius. But don't forget ... they expire in about 1 1/2 years.
  4. geraldc
    geraldc New Member
    32
    Singapore
    Yes this is true for the Japanese domestic, Aus, UK and some Asian models. But you could get the European (continental) one, which is on the correct side.
  5. Dakine50
    Dakine50 Member
    148
    22
    Nor-Cal
    I was messing with the sun visor one day and flipped the visor forward into a horizontal position and noticed that the light for the vanity mirror doesn't come on unless the visor is tilted in the vertical position!
    Personally I would have designed the light to go on if you slid the door to expose the mirror no matter what the position of the visor was in! Props to the Toyota design/ engineering team!
  6. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Useful if you are new to the car, not real necessary when you have memorized all four positions, only 2 of which you use with any frequency and one which it will stay in only if you hold it there (N).
    Now, how many people are going to rotate the shifter 180 degrees after deciding that pushing it forward to go backward and backward to go forward is pretty stupid? :) Yeah, I know, based on European manual trannys. Except that they have several forward gears so you really have no choice but to push the shifter backward to go forward in some gears so it is minimally excusable. Still another 'other cars work this way' design 'feature' that should have been 'rethunk' WAY back.
  7. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Which actually isn't nearly the financial pain of Nav vs no NAV in the '04, especially considering that the 2010 NAV includes the display which was already in every '04 built and you could not (and CAN not) get a OEM backup camera for the '04. I think the 'step up' in the '04 from the next package down was about $2700. There were a couple of other minor features as well but I don't recall what they were. Maybe the security system which isn't real important where I live.
  8. bruceha_2000
    3,054
    302
    Northwest VT
    2018 Prius Prime
    Perhaps they figured you didn't need the light if you couldn't see in the mirror. However, (maybe not on the 2010, don't know) the map lights are hardly directional and there is no 'barrier' so if the passenger has their map light on, the driver still gets a lot of light. Maybe the visor light COULD have been used as a single seat map light.
  9. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Or the hot light up against the headliner (little cooling) was melting something over a long period of time, or at the very least, wasting energy or bulb life?
    Gen II had the same behavior w/ the vanity mirror/light.
  10. dsviv
    dsviv Member
    170
    Eastern PA
    Notice where geraldc lives. It is obvious that the US version doesn't have the card holder or the HUD. It looks like the display is in reverse.
  11. KJF
    KJF Member
    75
    17
    Small town - north central Idaho
    I looked in the two fuse areas (inside left of driver's seat and right side under the hood) to see if the extra fuses from my old dearly beloved 1987 Toyota Corolla would work in the 2010 Prius (they won't). I noticed that there are three different spare fuses under the hood in that black fuse box - a 30, a 10, and a 7.5. Thoughtful!
  12. 60MPG
    60MPG Junior Member
    24
    I just find this odd ... according to the 2010 manual:
    Hybrid battery air vent: There is an air intake vent on the side of the rear right seatback for the purpose of cooling the hybrid battery (traction battery). If the vent becomes blocked, the hybrid battery may overheat, leading to a reduction in hybrid battery output.
    I'd have put it somewhere else but maybe that's why I don't design cars...
  13. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    It's where it needs to be - right where the battery is -- the area has to accomodate the venting in proximity to the battery. Kinda like why we keep the pots and pans in the kitchen and not in the bathroom!
  14. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    I'm with 60MPG on this one... I mean seriously, through the seatback?!? I did actually study hybrid design in college (had one on the drawing board long before the Prius was even a twinkle), so I'm not totally without experience here. If the battery needs to be vented, fine... but through the effin' seatback? Looks like an afterthought to me.
  15. jay_man2
    jay_man2 jay_man_also
    1,246
    144
    Manassas, VA
    But does the oven really need to be vented along that wall? :p
    I noticed that vent placement too, and it bothered me a bit. Why not along the floor like the Highlander, or in the same place on the other side, which is the side less likely to have a passenger in it or more likely to be flipped down for extra cargo area (hence less likely to be blocked by someone's body).
  16. Tideland Prius
    16,557
    That would be the most compact design. The Gen 1 had it outside (not good for car washing!). The Gen 2 had it on the same side but higher up, near the top of the seatback. That meant routing the pipe to the top... but the battery's at the bottom, underneath the floor so for Gen 3, it's at the bottom of the seatback.
    Putting the vent underneath the seat meant raising the seat bottom which will reduce headroom. Fine in an SUV where you have headroom to spare, but not in a hatchback with that kind of a sloped roof.
    Any other questions?
    Robert Holt and jim256 like this.
  17. Tamyu
    Tamyu New Member
    126
    42
    Nagoya, Japan
    Wow, thanks for sharing that. I didn`t notice it at all, even when we tried the son`s car seat in the back for size on the test drive... We may have been totally covering it! I`ll have to note that somewhere so we don`t cover it bringing the car home from the dealer (or, well, forever - since once we put the seat in it isn`t going to be moving for a while!)
    That does seem like a bit of an awkward location, even if it is the "best".
    About the card holder mystery. In the Japanese version of the car, you can choose to have an ETC unit factory installed in that spot. ETC is... Electronic Toll Collection (I think that`s what it stands for) and it allows you to stick your ETC card or ETC compatible credit card into the slot and simply drive through ETC compatible toll gates without ever actually stopping the car. It`s great in Japan as pretty much all the highways are toll and all use the ETC system.
    If you choose not to install the unit, instead of leaving an empty hole you get a plastic card holder type thing in the spot. (Basically a fake ETC unit.)
    3 people like this.
  18. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Now this makes a lot of sense.
  19. hnfleming
    hnfleming New Member
    Orlando, FL
    So, if I have my son's carseat on the right side in the back, is it possible for me to actually damage the car? He only has the booster section and he probably doesn't cover the whole vent. Opinions?
  20. 60MPG
    60MPG Junior Member
    24
    I'm dropping a car seat in there as well and, while I don't think it will be an issue, it just seems like the wrong spot. I'm assuming that vent allows cool air in to the battery compartment, as opposed to letting warm air out. If I'm correct, I'd have rigged a small air intake under the car, just ahead of the battery compartment, allowing the movement of the vehicle to push air past the battery. (Water shedding, of course.)
