Most Obscure Prime Facts (Way Out There)
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Apr 21, 2016.
  1. Tideland Prius
    16,556
    For 2020, the base/LE models get Entune 3.0 with the 7” headunit. The Upgrade/Tech/XLE/Limited models with the 11.6” screen don’t. So no Prime Apps.
    Salamander_King likes this.
  2. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    what possible reason could there be for them to remove useful functionality like that?
  3. Tideland Prius
    16,556
    Poor timing between audio units and model years? It’s either the Prime doesn’t get CarPlay until the redesign or they shoehorn a temporary fix.
    Again, I have mentioned that Entune 3.0 has been designed for their 7” and 8” units so the Prime’s unique 11.6” screen puts it at a disadvantage and we’re seeing that disadvantage now.
    drash likes this.
  4. evpv
    evpv Active Member
    691
    338
    West Coast
    2019 Prius Prime
    The rubber part of the center console cup holders have a tab that makes them easy to remove for cleaning.
  5. Tideland Prius
    16,556
    It stays in PWR mode even after turning off the car (In the Gen 3 Prius, it defaults to normal)
    Henrik Helmers and Chazz8 like this.
  6. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    Even driving 10 mph past speed limit (flow of traffic) people still cut you off.
    pghyndman and ctscoob like this.
  7. DavidA
    2,345
    1,821
    Chicago western burbs
    I'd bet that's not only Prius as a factor - it is because some people are just jerks.
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Yeah, it doesn't matter what you're driving. At 5 over, so many people pass me so fast that I keep checking my mirror to see if there's a Tyrannosaurus Rex coming up from behind.
    dbstoo, huskers, brugan and 2 others like this.
  9. DavidA
    2,345
    1,821
    When I think it is just me, and my Prii's I've had, I notice the jerks are still passing crazily every other car/SUV/truck up the road for miles ahead. It is usually them, not us.
    fuzzy1 and jerrymildred like this.
  10. Tideland Prius
    16,556
    The Energy Monitor screen doesn’t show battery SOC (it shows it on our 2016 Prius)
    The compass screen display is tied to your compass display in the nav. If you have North Up set in the nav, it’ll be North Up on the compass screen on the MID for example.
  11. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    What kind of mileage do those get?
    dbstoo and jerrymildred like this.
  12. jerrymildred
    11,517
    14,152
    Tampa, FL
    I don't know, but I'm guessing it's even worse than the cars and trucks they are chasing. :LOL:
  13. Diemaster
    Diemaster Active Member
    295
    260
    so. cal
    I didn't look though 12 pages of this thread so it may have been said before. If you call some one or someone calls you, you can use the "green" phone button on the steering wheel to answer. If you press it again while in a call, it will mute the mic (good for drive thoughs.) Press it again and it un-mutes.
    Tideland Prius likes this.
  14. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    The purpose of having headlights on when using wipers is not for you. It's for other drivers -- to make it easier for them to see you.
    Kind of like headlights in a well-lighted urban area where there's plenty of street lighting to see to drive. Mostly important to help others see you. And also why you sometimes see drivers with their headlights turned off while driving downtown. Because they can see fine, they don't think to turn their lights on.
    Also, I was under the impression that the USDOT required that turning on the wipers also turns on the headlamps. However, I'm not sure if this requirement has been implemented. It's certainly been under discussion for may years. Here is a clipping form the New York Times way back in 1991:
    Does anyone know if this has become a Federal safety requirement? It seems that many auto-makers have implemented this feature.
    GSK likes this.
  15. hill
    8,805
    That article, reminds me of a peculiar anomaly in Canada (where headlights turn on automatically, all the time). Wasn't too long ago I read the greatest fatality Source are moose. I guess they don't understand headlights.
    #235 hill, Nov 29, 2019
  16. fuzzy1
    10,452
    Those are DRLs, not legal headlights. Required in Canada since late 1989.
    I remain quite unaware of any such federal regulation.
    #236 fuzzy1, Nov 29, 2019
  17. Tideland Prius
    16,556
    Did not know this! Thanks!
  18. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Charging door charging light lights up as you approach the car with your keyfob. For this to work, the car must be locked.
    iPad ? Pro
  19. Tideland Prius
    16,556
    2020+ models have the clock settings menu in the MID between the "Info" menu and the "compass" menus (i.e. 2nd menu option). 2017-2019 models have the clock settings buried within the "Settings" menu
    pghyndman and Salamander_King like this.
  20. Salamander_King
    Salamander_King Senior Member
    11,019
    8,953
    New England
    Humm, I have changed the time in both 2017 and 2020 but didn't notice the difference.
