Most Obscure Prime Facts (Way Out There)
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Apr 21, 2016.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    According to Jalopnik the front bumper skin consists of 3 separate sections, so in case of minor corner hit it is not needed to replace the entire bumper.
    This may explain the all-black (unpainted) center section, if it was painted then replacing and repainting a corner section could leave color non-uniformity between the sections.
    Tideland Prius likes this.
  2. hill
    8,809
    iduno ... doesn't speed factor into replacement ? as well as the vehicle you make contact with ?
    With so many flimsy bumpers now days - just a thought - there might be a few other variables.
  3. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Speed of replacement? Yes, good point:rolleyes:
  4. hill
    8,809
    Speed you get smashed into with - necessitating replacement, actually.
    tideland, the ioniq did away with the 12v aux lead/acid battery & just pulls 12v DC off the traction pack - which would mean the car necessarily won't lose its driver specific settings. Do you know if that's the case with the prime? ...
    #64 hill, Dec 15, 2016
  5. techumper
    techumper Junior Member
    Hanford, CA
  6. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Both generation 4 Prius' have 12V batteries under the hood. It's charged by the hybrid system so there's no alternator.
  7. bisco
    51,961
    i guess a 'minor corner hit' would pretty well define low speed.
    Data Daedalus and giora like this.
  8. Tideland Prius
    16,559
    No. The Prime still has a 12V lead-acid under the hood in the same place as the Gen 4.
  9. hill
    8,809
    I guess i was just hoping they'd found a way to save a lot of the data that gets lost when a car loses aux power. Maybe next gen.
  10. ttait
    ttait Active Member
    273
    163
    Southern California
    Is not some of this data written to the SD card?
  11. hill
    8,809
    I suppose it turns on which options your Toyota has. We lose auto window up functions, auto sunroof memories, drivers 1&2 seat memories, music stations etc. We've gotten around this anoyance by attaching a variable DC power supply when cleaning terminals or removing the battery for other reasons.
    Data Daedalus likes this.
  12. CharlesH
    2,797
    1,163
    Roseville, CA
    So the Prime is like the original Plug-In, in that the traction battery is physically disconnected until the system goes into Ready state or is being charged? The 12-v battery is needed to power the control system to bring the traction battery online.
  13. Tideland Prius
    16,559
    That's the way I understand it.
  14. Tideland Prius
    16,559
    Suppressing the shaking of the vehicle according to the unevenness of the road.
    Sprung vibration damping control
    By controlling the torque of the motor in real time according to the unevenness of the road surface, it suppresses vertical pitching (pitching) of the car body, contributing to a smooth and flat ride comfort.
    トヨタ プリウスPHV | 性能 | 走行性能 | トヨタ自動車WEBサイト
    This sounds similar to the Prius v's "Pitch & Bounce Control".
    This is the first time I've heard of it in the Prime.
    drash likes this.
  15. Terry Nyberg
    Terry Nyberg Junior Member
    Denver
    In Colorado this law is simplified. Headlights must be on if it's raining. Otherwise do you have to turn your lights on when you clean your windshield?
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    In my advanced, in the fuse box under the hood, there is a fuse removal tool and 3 spare fuses !
    The tool is on the lid.
    The green, yellow and red fuses on the left are the spares.
    There appears to be no extra access ports into the box.
    drash likes this.
  17. bisco
    51,961
    who determines if it's raining?
  18. Lee Jay
    5,850
    4,036
    Since I've lived in Colorado all my life, and never heard this rule, I went in search of it. I can't find it and I don't think it exists.
    The Colorado driver's manual says, "Colorado law requires you to drive with your headlights on from sunset to sunrise or when visibility is less than 1,000 feet."
    AAA says: "Headlights are required to be on between sunset and sunrise, and when visibility is less than 1000 feet."
  19. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    In the Prius Prime, after going into an automatic contactless wash, you are not left with that soapy mess under the rear tail fin.
    bps and Data Daedalus like this.
  20. hill
    8,809
    ahh . . . yes - THAT feature. iirc Tesla had that when the Model S came out - what ... 1/2 decade ago? in fact they even have the car's image, the same color as the car you're in. Is that the same as the Prime?
    :whistle:
    hard to be 1st in our uber tech-ie world.
