Most Obscure Prime Facts (Way Out There)
Discussion in 'Prime Main Forum (2017-2022)' started by Tideland Prius, Apr 21, 2016.
  1. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Today I drove my Prime down a mountain from 6000 feet to 2000 feet. It was in B most of the time. When I started the battery was at 1% and when I finished it was about 60% full. All automatically done.
    Craig21029 and bisco like this.
  2. DavidA
    2,345
    1,821
    Chicago western burbs
    Did you also test out Charge mode?
    Prodigyplace likes this.
  3. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    Would it have charged slower if you were not in B mode? I read in other threads that B mode is the same as D+brake in that it has the same effect on regen and efficiency. True or false?
  4. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    The cannot recharge EV greenwashing efforts successfully trickle into ordinary questions. That's quite annoying.
    There is *NOT* limitation as they infer.
    My proof of this was driving down from Mt. Rushmore. It was very nice to witness firsthand.
  5. CraigCSJ
    287
    144
    San Bernardino, CA
    I have not tried Charge mode.
    I take this trip frequently, but always use B as that needs less manual braking. I doubt that D+brake would increase the recharge, but have not tested it.
    #125 CraigCSJ, Jul 13, 2017
    NJ-PrimeAdvanced likes this.
  6. pineprius
    pineprius 15th Hole #4
    245
    134
    NC
    North Carolina also has the same law, but many Tarheels have no idea. New to the state, but wish hands free phones was also required like California. Lots of head on accidents on 2 lane roads in NC. Texting is a real problem.
    HPrimeAdvanced and pilotgrrl like this.
  7. Tideland Prius
    16,559
    The Prius Prime in the Energy Monitor (4.2" MID) in the European-spec cars has US-spec wheels.
    Data Daedalus likes this.
  8. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    I tried it out the 2nd day after I got my Prime. Tried it after we went to Saturday apple farm in some rather higher hills (~1,100 ft) back to my daughter’s house. Started with 3 EV miles left and still got over 50 mpg, primarily because it’s a mostly shallow decline. Not enough to feed the pack but enough to keep your foot off of the gas. Manually shut it off after the decline stopped (~about 15 minutes) and had over 15 miles EV left. Used that to drive the rest of the way to my daughter’s house and then to mine.
    You could feel the whole car sort of get dragged down through the gas pedal and hear the ICE revving a little more. Turning it on reminded me of turning on A/C in an small ICE only car. Got my curiosity out of the way and haven’t used it since. But that may be the only good use case for it for me.
    Unsupervised!
  9. Tideland Prius
    16,559
    time to update your profiel, @drash !
    drash likes this.
  10. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Thank you, Oops. Changed my signature, forgot the profile. How's that?
    Also wanted to say I used the grocery bag hooks built into the back of the Prime.
    #130 drash, Oct 27, 2017
  11. Tideland Prius
    16,559
    Yeah the grocery bag hooks are "about time!" haha.
    We had two built into the cargo net hooks in our old Camry and they were useful.
    HPrimeAdvanced likes this.
  12. Tideland Prius
    16,559
    The forward-facing parking lights in the Prime are the high beams at reduced intensity.
  13. DavidA
    2,345
    1,821
    The screen showing energy distribution accurately shows the 5 groups of main traction batteries layed out front to rear, matching how the pack is really built.
    Tideland Prius likes this.
  14. SHDL
    SHDL Junior Member
    23
    43
    SW Portland Area
    Here's an "obscure" tip about Prime Advanced pull-out tonneua cover. All the pictures of cover that I've seen show that the hard, not retractable portion at the back of the cover hanging down when the cover is retracted. That hanging flap is in the way, and blocks a some of the cargo space. Did you know that the flap can be flipped over and tucked under the head rests? That puts the flap out of the way, and looks much nicer. Here's a couple of pictures...
    View attachment 143625 View attachment 143626
    bruceha_2000, Airboss, benagi and 4 others like this.
  15. DavidA
    2,345
    1,821
    Didn't know about the tucking. That's good to know.
    I just remove the entire cover from the car unless I know I'm going to use it. That saves even more room and weight. And no flapping noise when the car hits bumps in the road.
  16. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    AM radio pauses too, at least on my Advanced. If my Garmin requires my focused attention, or whatever, I pause the radio, and can continue listening later. Not used that often on AM as on FM, but still useful; just hold down MODE button on steering wheel. To restore, I just tap the down arrow on the same switch.
    benagi and I'mJp like this.
  17. DavidA
    2,345
    1,821
    I think you're confusing the Mute function with Radio pause with that Mode button hold and up or down volume press.
    Mute (the Mode button trick) doesn't stop the radio to continue later. It just cuts out the sound.
    Radio Pause function actually pauses the program (shuttles it off into system memory) to resume play later, limited to 15 minutes or less.
  18. benagi
    benagi Active Member
    525
    280
    Utah
    I think HPprime is talking pause not mute. I did what he did the other day with the mode button and it paused my radio and when I hit it again, it started the song right where it left off. I wish this radio had a rewind feature. I heard there are some radios on the market with that feature now .
  19. DavidA
    2,345
    1,821
    Radio Pause is activated by The [ II ] button within the radio extra controls. The [ > ] button unpauses. Page 89 of the Prime Nav. Screen manual.
    Radio (or any audio) Mute function uses the [ MODE ] button. Must hold that down for ~2 seconds. Volume Up or Down unmutes it. Page 116 of the same manual. The manual says that holding down the [ MODE ] button unmutes, but that has never worked for me, so I just hit the volume up or down on my steering wheel to unmute.
    #139 DavidA, Feb 3, 2018
  20. benagi
    525
    280
    Utah
    I’ll have to go and try that again. I could have sworn that when I tried that the other day it paused. Thanks for the clarification.
